Question about Coleman Grilling
Regulator for coleman stove #9948 - Coleman Grilling
3 Suggested Answers
  • 3 Answers
SOURCE: coleman instastart propane stove regulator wanted
Check to see if Coleman has an attachment to replace the regulator, so that you can use a five gallon cylinder with your stove and your own regulator.
Posted on Jun 29, 2008
hunter19_46m
  • 7482 Answers
SOURCE: Hi I lost my regulator assembly for the camp stove
Hi bearsmommy19...
Yes you can use a generic regulator/coleman on your brinkman...just make sure the threads all match, if not, then adapters in brass can be bought at the local hardware HomeDepot,Lowes,etc.
Then you can install them to adapt your regulator to your brinkman grill
Please take time to rate me
Posted on Aug 28, 2011
How do you connect the propane to the stove
Assuming you are referring to the Coleman Campers Grill Stove which is a side by side grill and stove unit than it is a pretty simple set up. All portable Coleman stoves set up basically the same. There should be a arm known as a regulator that came with the stove. The narrow end of this attaches to the right side of the stove and screws in. Then the propane bottle screws into the other larger end. make sure all connections are screwed together tightly. For more clarification check out these instructions:
http://www.ehow.com/how_2106008_use-coleman-stove.html
https://www.youtube.com/watch?v=dbYil-YQ8-Y
Good Luck!
Jul 07, 2014 | Coleman Campers Grill
Regulator on colman stove 425 doesn't shut off fuel
If you mean it keeps on shooting out gas when you turn the knob, that sounds like the valve has a problem, likely a tiny piece of dirt in it. I am not sure there is any fix other than to take it out and clean it, or replace it.
If for some reason you are sure it is a regulator problem, then just change it for a new one - available at many stores that sell Coleman.
Feb 06, 2013 | Coleman 425 Camping Stove
Hi I lost my regulator assembly for the camp stove model # 842-A100-W. Where can i purchase a replacement. & can you use a different one like for a coleman camp stove???
Hi bearsmommy19...
Aug 28, 2011 | Brinkmann 842-A250-0
Why does my coleman stove regulator leak gas from the hole on the top of the regulator
Its a safety feature of the regulator. The regulator is designed with a pressure release valve. This has happened to me twice: once with a carbon dioxide tank for my kegerator and once on my propane stove. In both cases I left the regulator (designed with a max pressure rating of X psi) attached to a full bottle in the sun. The heat caused the pressure to exceed the limit of the regulator and the release valve popped. A welding supply store may be able to reset/replace the mechanism but in my case I just bought a new regulator for about $15.
Aug 14, 2011 | Coleman 2 Burner Propane Stove 5430E700
Do I need a regulator on my bulk tank for this stove or is just an adapter hose ok
Please don't try to use this stove without a regulator. It is extremely unsafe, and not worth it. If you can't find a regulator cheap online (I couldnt find one for less than $30) - just buy a new one. You can find a whole new cookstove on sale for $20-30 at most outdoor stores like Big 5, Dicks, Walmart...good luck!
Aug 08, 2010 | Coleman 2 Burner Propane Stove 5430E700
Need to fix regulator for coleman stove 5410708
Just where the regulator attaches to the burner there is a small nut that may be loose. If you look closely at this and turn the regulator (stove off and hose detached!) you may see the nut hat turns easily. Tighten it and make sure the regulator does not rotate too freely, but still turns to adjust when attached to the hose or the smaller gas cartridge, if using that. Test carefully after this.
Feb 06, 2009 | Coleman 2 Burner Propane Stove 5430E700
Coleman propane stove problem
The connector for attaching the regulator to a disposable propane cylinder has a sintered bronze filter in the tip of the brass probe tube that is prone to clogging, or the bronze pellets get mashed down over time, restricting gas flow, and this will cause a portable grill or camp stove to perform poorly. The filter is so fine that it takes very good eyesight and bright light to see that it isn't solid metal, or use of a strong magnifying lens. The best solution is to buy a new Coleman regulator assembly. If you are unable to get a new regulator assembly and have the skills and the tools, you can try drilling a very small hole on the side of the probe tube with a #60 drill bit, just below the bronze filter, but near enough the end of the tube so that the hole will be past the plastic seal when the disposable cylinder is fully screwed into place. You should avoid drilling directly into the end of the probe tube, as the end of it is used to depress the Schrader valve in the disposable cylinder to allow gas to flow. A #60 wire gauge drill bit is only 0.040 inch (1.016 mm) in diameter, but makes a hole large enough to supply sufficient gas to a portable grill or a dual-burner camp stove. If you choose to perform this work, the probe should be unscrewed from the regulator body and the Schrader valve core in the probe tube should be removed before drilling. Be sure to clean all brass and bronze particles out of the probe tube before re-installing the Schrader valve core and the screwing the probe into the regulator. Use a removable-grade thread locking compound to secure the probe in the regulator body and don't over-tighten it, so as not to crush the rubber gasket. Allow the thread locking compound to cure for several hours before attempting to use the regulator. Keep in mind that this modification increases the likelihood of dirt getting into the needle valves and jets of your stove or grill, which can cause maintenance problems in the future.1_28_2013_4_49_27_pm.jpg
Aug 19, 2008 | Coleman Gas Grill Stove
Coleman instastart propane stove regulator wanted
Jun 26, 2008 | Grilling
Grilling Logo
276 people viewed this question
Top Coleman Grilling Experts
Dan Webster
Dan Webster
Paul Carew
Raymond Ramirez
Raymond Ramirez
Are you a Coleman Grilling Expert? Answer questions, earn points and help others
