Question about HP Media Center m7250n (ED842AA) PC Desktop
Media Center I bought this PC with the plan to use the media center, it has never worked properly. The channel does not change in Media Center, it will not record. Overall it very disapointing. My guess is that it has something to with the infrared channel changer that communicates between the PC and the cable box (something to do w/IR speed). Has anyone here heard of this problem and do you have any ideas on a solution.
    Problem Solver:
  • 3 Answers
Contact HP? (for possible replacement?)
Posted on Jun 08, 2008
HP TSGH-IR02 Remote Control how to install
This document pertains to HP Media Center computers with Windows XP, Media Center Edition.Use this document when the remote control does not work correctly with the Media Center software.Troubleshooting the remote controlUse the following items to troubleshoot when the remote control does not respond or when the remote control does not work properly. For example, when a key is pressed the selection moves all the way to the top or bottom of a list, or moves a selection many different places instead of the item you were trying to select.Before attempting these steps, make sure that PC has been updated with all of the latest Windows updates. Many updates for Media Center, like Update Rollup 1 for eHome Infrared Receiver, can be downloaded easily through the Windows Update software Tool.
Make sure that the batteries for the remote control are installed correctly and charged.Make sure that the front of the remote sensor is unobstructed, within a 45-degree range, and is less than 26 feet (8 meters) away. Disconnect all devices that use a USB connection except to the receiver, keyboard, and mouse. Restart the PC, and then try the remote again.If a pressed button repeats itself (sticks), unplug the IR receiver from its USB connection, wait one minute, and plug in the IR receiver. If the pressed buttons continue to repeat, alter the lighting conditions in the room or move the location of the IR receiver. Other remotes and HP Media Center PCs within range can also cause this issue.Try pressing the Enter key on the remote after changing a channel.If the remote control works when using the media center software, but does not work when changing the television channels, re-configure the Media Center software settings for the cable set-top box or satellite receiver
Point the remote control towards the IR receiver and press a button. A faint red light should appear on the IR receiver. If the light appears, then the problem is probably in the software that is using the remote control (most likely the configuration of the Media Center software). Close the software, restart the computer, and then re-open the software to solve this issue.
Troubleshooting the IR receiverThe IR receiver is the small device that receives the signals sent by the remote control. Use the following steps to test and reset the IR receiver.Disconnect the IR receiver from its USB port on the computer, maximize the Media Center window if it is open, and then reconnect the IR receiver. Test again.Point the remote control towards the IR receiver and press a button. A faint red light should appear on the IR receiver. If the light appears, then the problem is probably in the software that is using the IR receiver (most likely the Media Center software). Close the software, restart the computer, and then re-open the software to solve this issue.Click Start , right-click My Computer , and then select Properties .Click the Hardware tab and then click the Device Manager button.Click the plus sign next to Universal Serial Bus Controllers.If the eHome Infrared Receiver is listed under Universal Serial Bus controllers, Windows is properly detecting the IR receiver. If eHome Infrared Receiver is not in the list, or there is an exclamation mark or a question mark on the device, perform the following until eHome Infrared Receiver appears correct in Device manager:Unplug the end of the USB cable on the IR receiver from the computer and plug it into the same USB port.Plug the end of the USB cable on the IR receiver into the front USB port on the computer.Disconnect all other USB devices, leave the IR receiver plugged in, and then restart the computer. Plug in other USB devices after the IR receiver shows up in device manager.Figure 1: IR receiver listing in Device Manager
Testing the remote controlUse the following steps to check the responsiveness of the remote control:
  1. Open the Media Center software by double-clicking the Media Center icon the desktop or by pressing the green Start button on the remote control.
  2. Click Settings , and then click General .
  3. Click Check Your Remote , and then click Next .
  4. Press the numbers on your remote control. The corresponding numbers on the numbers on the screen should glow when each button is pressed. A faint red light should also glow inside the IR receiver each time a button on the remote pressed.
  5. Click My control is working properly , and then click Next . Do not click I am having problems with my remote control as this will not do anything.
  6. Click Finish after you are done.
Dec 17, 2011 | HP Computers & Internet
How to use in built TV tuner in lenovo y560 laptop
In windows 7 - Windows Media Center will use it (NOT media PLAYER, media CENTER)
media center is actually wicked cool for watching TV because if you have cable, no more waiting for the listings channel...it pulls up to 2 weeks of listings from your provider, so you can schedule shows to be recorded, record series etc...very cool!
Mar 03, 2011 | IBM Computers & Internet
Hi, I bought an Inspiron E1405 Media Center Edition in '06 and it never really worked properly. I was never able to use the "media direct" button or any of the other feats. I thought came with? On top of...
Since XP was reinstalled and the HDD was not prepped with the Media Direct CD before XP install Media direct will not work. You can purchase a Dell Media Center CD on ebay for about $20
http://shop.ebay.com/?_from=R40&_trksid=p3907.m38.l1313&_nkw=Dell+XP+Media+Center+Edition&_sacat=See-All-Categories
I also found a Media Direct CD for a Newer Model, so I'm not sure it would work on yours. Media Direct requires that the HDD be formatted with Media Direct and then the XP installation, Driveras and applications, then install of Media Direct SW. Once done in that manner, you should be able to boot to Media Direct to play a DVD (To be honest, I never found the Media Direct function that useful)
Oct 20, 2009 | Dell Inspiron E1405 Notebook
Windows media center file issue
Some premium channels have DRM locks so that they aren't able to be copied or played on other players, which is most likely what's happening here.
Dec 25, 2008 | Microsoft Windows XP Media Center Edition...
Media Center can't find digital TV channels for TV Wonder HD 600
Just to make sure, you do have analog tuners setup right?  Media Center 2005 requires analog tuners be working before digital tuners are allowed.
Oct 11, 2008 | ATI TV Wonder HD 600 PCI PC TV Tuner...
Tv on hp media center
Have you gone through the media center installation process and got the tuner / tuners setup properly?
Jul 03, 2008 | HP Media Center PC 873n (P9875A#ABA) PC...
Media Center PC 873N My TV Video Error
media center specialist - call 0845 20 20 118 or visit mediarx.co.uk
May 12, 2008 | HP Media Center PC 873n (P9875A#ABA) PC...
Tuner not working after reinstall
go to this website and see if you have all updates to you media center. your codecs are kept in the media player bin file let microsoft run a check and see if you need some more downloads. http://update.microsoft.com/microsoftupdate/v6/default.aspx?ln=en-us
Nov 01, 2007 | Sony VAIO VGC-RA710G PC Desktop
Channels won't come in on my media center
Try making changes on the Region settings NTSC/PAL and Resolution.
Sep 20, 2007 | HP Media Center PC 873n (P9875A#ABA) PC...
HP Media Center m7250n (ED842AA) PC Desktop Logo
64 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
