Question about Hannspree HF257HPB LCD TV
Hannspree 25" LCD monitor (HF257) turns on, but is an all white screen. No menus show up or anything. Is there a specific capacitor that would cause this? Thanks for the help.
  • szinger1 Sep 19, 2010
    Is there a common board that another multiple manufacturers use, or is it only a hannspree board? Thanks again.
  • 11,800 Answers
Simple test: unplug everything from it and start it again - if it's the same then the problem is inside the monitor.
No, a capacitor can't cause that. This is caused by a major malfunction of the image processor - all pixels are fully opened. The entire mainboard will have to be replaced - unless you can find one on the cheap online then replacing it will be expensive and most likely not worth it
Posted on Sep 15, 2010
  • Azrael SRL Sep 19, 2010
    Actually that board is specific to that exact model of tv - only extremely rarely the same board can be used in different models of tv's from the same manufacturer .
    So you must find out the exact board for your exact model of tv. Since Hannspree is a low volume manufacturer, finding one will be difficult.
TV shows a large white square upon turning on, almost as large as the screen. Nothing else will happen.
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
Jan 26, 2015 | Sony KDF-E60A20 60" Grand Wega LCD HDTV
Monitor fades to white.
Check the capacitors on the power supply board. The tops should be flat, no bulging or puffing up at all. The fading to white usually indicates a failure of one or more capacitors on the board. Here is a link to a repair kit if you find blown capacitors on the board.
http://www.ccl-la.com/catalog/product_info.php?products_id=241
Apr 02, 2013 | Samsung Syncmaster 940BW LCD Monitor
Have vertical lines on my Hannspree HF257 TV-MONITOR
please try the unit with a different cable or a computer check if issue persist , cos it could also be an issue with video card or cables (vga, dvi ,hdmi) -Surendar
Jun 08, 2012 | Hannspree Computers & Internet
My Hannspree 25" HF257 monitor
Ur tv have a dead 1 or 2 long board that call the LCD inverter boards.These 1 or 2 long LCD inverter boards job are to help the LCD screen panel to have a backlight to produced a picture.Tries websites like Shopjimmy.com,Ebay.com to buy those 1 or 2 long LCD inverter boards for the replacement.
Feb 28, 2011 | Hannspree HF257HPB LCD TV
I have a 25" Hannspree monitor which is only about
No - the buzzing you're hearing is probably the inverter transformer. Its' purpose is to generate high voltage to turn on the backlight to display the image on the screen. The monitor should still be under manufacturers warranty since most of them are a year. Have it repaired or replaced.
Feb 14, 2011 | Hannspree HH251H 25" LCD Monitor
The 25 inch Hannspree LCD tv and monitor screen flickers.
Need code for hannspree 25" tv to use on a dishnet remote control
Sep 11, 2010 | Hannspree HH251H 25" LCD Monitor
Hannspree HF 257 25'' monitor only stays on fo a few seconds and then gradually fades to black, another monitor works fine so the computer is not the problem. The computer was just moved to a new...
Is the power light staying on or does that go out as well?
If the power light stays on and if you darken the room, can you see a faint image still on the screen by shining a flashlight at it (close). If there is a faint image it is either the inverter or the backlight tube.
JC
Jan 31, 2010 | Hannspree HH251H 25" LCD Monitor
Dim screen ruining my Hannspree
your LCD screen backlite bulbs are bad or the inverter card the drives them is going bad
Oct 02, 2009 | Computers & Internet
I have a new HannSpree 25''/HF257 monitor and my desktop image is wider than the screen. How do I bring all images into the viewing area?
CTRL PANEL...Display(XP) or ( personalize )(Vista) select a display higher than 1024x768
please rate our help++++Thanks for using FIXYA
Sep 23, 2009 | Computers & Internet
The montinor is white
Chek the conection on the monitor,open the monitor and chek th conection of the lcd if is conected ok.i had tht problem to,and so i fixed.
Jan 17, 2009 | Hannspree HW191D LCD Monitor
Hannspree HF257HPB LCD TV Logo
438 people viewed this question
Top Hannspree Televison & Video Experts
Are you a Hannspree Televison and Video Expert? Answer questions, earn points and help others
