Question about Epson Office Equipment & Supplies
Only prints top part of each page - Epson Office Equipment & Supplies
  • 72 Answers
Change the drum or the catrirdge of ur printer
Posted on Sep 15, 2010
It prints multiple pages in reverse order. How does one change that so that Page 1 comes out on top.
Most inkjet printers print the first page on the bottom, second page on top, etc. To get the first page on top, you can check the "print in reverse order" in the printer setup dialog.
Jul 21, 2015 | Brother MFC-J470DW Inkjet All-In-One...
Tally genicon 6605 is printing from top to bottom of the page...what could be the problem
I think it depends on what you mean by printing from top to bottom of the page.
If you are describing the print being rotated by 90 degrees so rather than a line of print going across the page from left to right, the print goes up and down the length of the page.
The most common cause of this is that you are printing from a Windows application and you have set the page orientation to LANDSCAPE rather than PORTRAIT.
With in the application you are printing from look for the PAGE SETUP options ensue you select PORTRAIT.
This should rotate the print.
Oct 18, 2013 | TallyGenicom Office Equipment & Supplies
Which way do I insert the transparency into my front loading MP 560 Canon Printer.Shiny side up or down Thank you V
It depends on which side you want to print on. For transparencies, you want to print on one side only. Most likely, you want to print on the shiny side; essentially as if it were a glossy photo. Load the transparency so that the shiny side gets printed on. Don't know that part? Front loading printers are the easiest to determine which side is printed on. Look at where the paper goes in and where it comes out. Think about it; for single sided printing, the paper isn't being turned around inside; merely rolled around an internal roller, then back out. Watch what happens to the paper the next time you print on a single side. See if the top of the printed page came out first, or last.
The most common designs of front-loaders have the paper come out above where it went in. The paper curls around the bottom of the internal roller and comes right back out on top. Therefore, the printed side started out on the bottom, then curled around the internal roller and came out with the printed side up.
Most front loading printers have the top of the printed page come out first; therefore, the same edge that went in first, got printed on first. With that in mind, if you ever want to print on the unprinted side of a piece of paper (that is already out of the printer), obviously keep the printed side up, but since the top of the printed side came out first, you need to make sure the top goes in first to come out first for the back side.
Your Canon 560 printer has duplex printing, so it is a good idea to run your test to see what happens when printed on a single side, and what happens if you use the duplex-mode. For duplex mode printing, after printing on one side, the printer pulls the paper back in to print the other side automatically. Think about how much space is inside the printer. Depending on how much data the printer can store, either the first page is printed, then the second page, or the second page is printed first, then the first page. It depends on how the printer wants the page to come out. You can run a simple test and see exactly what happens.
Since the printer cannot easily turn the paper around, it merely starts with the opposite end of the first printed side when it prints on the back. If the top of the page came out first for the first printed side, the printer prints the bottom lines of the second page of text working back to the top in reverse order. As a result, the bottom of the page comes out first, with the top coming out last.
Some duplex printers can store so much data that the determine how the second page will look, print it first, then print the first page. Watch to see what yours does.
Worse comes to worse, mark a sheet of paper in one corner, insert it into the printer, then print a document that contains only the period character and see where it is printed. By knowing how you put the paper in, and where the period was printed, you can tell how to handle any situation. By the way, the period character was chosen because it will be so small that most likely you can use that sheet again.
Jan 07, 2011 | Computers & Internet
Is there anything I can do to print closer to the top of the page? Even when I have my top margin set to zero it starts printing an inch from the top. I have it set to center on the page. In print...
if you print web pages, click File, then click Page Setup, from there, adjust the top margin. Do the same on the application you are using for the document or file you are working on.
Aug 29, 2010 | Office Equipment & Supplies
In Print Preview my booklet looks like it will print correctly. When I print my book the 1st page of the 2nd half of the book prints on top of the last page of the 1st half of the book. I have tried...
rint Preview my booklet looks... Solve In Print Preview my booklet looks like it will print correctly. When I print my book the 1st page of the 2nd half of the book prints on top of the last page of the 1st half of the book. I have tried
Sep 11, 2009 | Microsoft Office Professional 2007 Full...
My printer is only printing half of the page
half page? just half top page (top-bottom), or left and right. If just left half page, set page setup as actually paper wide that inserted. because, if actually paper wide is smaller than page setup, some epson printer jsut print half. before starting printing, the paper sensor measure paper wide first.
Jun 08, 2009 | Epson Stylus Photo 925 InkJet Printer
Unable to configure the HP C6380 for double-sided printing
Here is the step by step right from the user manual. also here is a direct link to the manual.
http://h10032.www1.hp.com/ctg/Manual/c01527492.pdf
Let me know how it works out for you.
Print on both sides of the page
You can print two-sided pages with the HP All-in-One manually. When printing two-sided
pages, make sure to use paper that is thick enough so that images do not show through
to the other side.
To print on both sides of the page
1.
Load paper into the input tray.
2. On the File menu in your software application, click Print.
3. Make sure the product is the selected printer.
4. Click the button that opens the Properties dialog box.
Depending on your software application, this button might be called Properties,
Options, Printer Setup, Printer, or Preferences.
5. Click the Features tab.
6. In the Paper saving options area, select Manual from the Two-sided printing dropdown
list.
Perform special print jobs 83
Print
7.
For binding, do one of the following:
• For binding on the top like a notebook or calendar, select the Flip Pages Up check
box.
This causes the odd and even pages of your document to print opposite of each
other top-to-bottom. This ensures that the top of the page is always at the top of
the sheet when you flip the pages up in your bound document.
• For binding on the side like a book or magazine, click to clear the Flip Pages
Up
check box.
other left-to-right. This ensures that the top of the page is always at the top of the
sheet when you turn the pages in your bound document.
3 5 1
8. Click OK, and then click Print or OK in the Print dialog box.
The product begins printing. Wait until all the odd-numbered pages are printed before
removing any of the printed pages from the output tray.
A dialog box displays instructions on the screen when it is time to process the second
side of your job.
9. Click Continue when done.
Nov 28, 2008 | HP Office Equipment & Supplies
HP 1300 printer prints 2 or more pages into 1 page.
Is it actually printing 2 pages on top of each other or is it 1 page with shadows on top?
Oct 24, 2008 | HP LaserJet 1300 Printer
Only prints top of page
How does the test print page work? Does it still only print the top bit...
May 02, 2008 | Brother HL 5250DN Laser Printer
22 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
