Question about HP Compaq Presario SR1300NX (PP195AA) PC Desktop
Install hard-drive i have a compaq presario sr1300nx amd sempron (tm) 3000+ i'm trying to install a sata 250 gig h/d to the existing ide 60 gig ....the system won't acknowledge that it's there.....what am i doing wrong ? . the sata will be the slave and is connected to the black connector sitting on the mobo. help
  • 77 Answers
Sata drives don't have an option to be master/slave like IDE drives, b/c the Sata cable is per device. If the computer's not pulling up the sata drive, open device manager (right click  my computer, properties, hardware tab, device manager) and look for a yellow question mark. You'll have to install drivers for it more than likely.
Posted on May 16, 2008
I took out my hard drive in my Compaq Presario V2000 laptop...and I'm not sure what type it is..like an IDE, SATA...and whether it needs a 2.5 or a 3.5
Hi
Normally a laptop computer using the hard disk type 2.5 "
Here I attach the hard drive example for your reference.
Pic 1> 2.5" IDE HDD
Pic 2> 2.5" SATA HDD
Tq and regards
Mar 21, 2011 | HP Compaq Presario V2000 Notebook
What type of dvd drive can I install on emachine w3118 IDE or SATA?
This computer has a IDE and SATA port inside it so you can either install a IDE or SATA drive on it, but what it came per built is a IDE drive.
May 19, 2010 | eMachines W3118 AMD Sempron 3100+ 1.8GHz /...
I have a Compaq Presario V3309TU Notebook PC. I reformatted the hard drive, now I could not install windows XP cd. The hard drive could not be detected. Can someone help me get the SATA Driver for Compaq...
The problem is that XP installation CD does not have a SATA driver, unless you have a Compaq SATA drive on a disk etc and can install it when XP asks for a hard drive driver, then XP cannot detect the hard disk and therefore won't install XP.
The Fix.
Go into the BIOS and disable the SATA drive, this will make XP think it is a IDE/PATA hard disk. Then install XP normally, and all the device drivers (including the SATA driver), then shut down and boot up and got into the BIOS and enable the SATA drive.
Mar 14, 2010 | HP Compaq Presario V3000T Notebook
SATA 2.5 connectors different than current Presario R4000 laptop
It seems that your notebook does not have sata connection to Hard drive. Your harddrive is IDE connection. Sorry but you can't use SATA on this laptop.
Oct 22, 2009 | HP Compaq Presario R4000 Notebook
When I try to put XP on my Compaq Presario C500, it cannot find the hard drive and will not try to load it. I have already done a diagnostic on the hard drive and it is working perfectly. What can I do?
I take it that the hard drive is a not the normal IDE but rather a SATA (newer technology) drive. Inthat case you can in some cases change the Hard drive setting in the CMOS setup from ENHANCED to IDE-MODE under STA drives. That causes the installation to detect the drive as an 'IDE" drive in which case it then can install windows. The normal windows installation cannot always detect SATA drives while installing and then reports that there is NO drive attache to the computer
Jul 06, 2009 | HP Compaq Presario C500t Notebook
I have a Compaq Presario, model #: SR2150NX W/120GB HD
You should be able to add a SATA drive to that machine (IDE should also be available to you). The spec drive in your machine is a 120GB, you may get a decent increase in speed if you use a newer SATA hard drive with a fresh install of Windows on it and simply put the existing drive as the slave or drive 2.
Mar 24, 2009 | HP Compaq Presario SR2150NX PC Desktop
Compaq presario v3700 windows xp not instaled
You require Xp Pro that supports SATA - standard Xp is IDE - you must aquire a copy of Xp that is SATA compatible.
Jan 27, 2009 | Compaq Presario C700T Notebook
Compaq presario r3000 amd athlon laptop cuts off after 10 minutes
from my experience this might be one of two things...
if it's shutting down while you're installing windows, i'm thinking you might have a problem with the motherboard channel for your CD drive. i saw this happen to a computer at work - we couldn't install windows because it cut off halfway through and blue screened on us.
it might also be a case of a bad hard drive, if you have any testing utility like drive fitness test i'd give that a shot. it sounds like a new one, but they're bad out of the box sometimes.
hope this helps
Jan 15, 2009 | Compaq Presario R3000 Notebook
Compaq Presario C734TU
Enter BIOS Menu and look for Hard Disk SATA IDE setting of AHCI. Disable this by setting to Compatible mode.
XP does not support AHCI mode.
Please rate me if this works.
Aug 05, 2008 | Compaq Presario 700 470024-192 Notebook
HP Compaq Presario SR1300NX (PP195AA) PC Desktop Logo
280 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
