Question about Seagate FreeAgent Pro - 500GB, 7200 RPM, USB 2.0, eSATA, External 500 GB Hard Drive
Hdd cannot be ditected - Seagate FreeAgent Pro - 500GB, 7200 RPM, USB 2.0, eSATA, External 500 GB Hard Drive
  • 11,800 Answers
In that case either it or the case is defective. Take it out and put it directly in a desktop, if now is detected then the case interface has failed - you need anew case; if it's not then it's dead, just junk it and get a new one.
Posted on Sep 15, 2010
My usb hdd is not ditected
The drive is likely failing. Return it.
Or I would suggest http://FreeDataRecovery.us they offer both online data recovery and do-it-yourself data recovery
Sep 14, 2012 | Computers & Internet
My windows server 2003 does not ditect my hdd during installation?
You can install Windows 2003 using IBM Service Guide CD. Its an image file (.iso) . Burn it after download . Then boot from cd and follow the simple wizard . Find the link below
http://www-947.ibm.com/support/entry/portal/docdisplay?lndocid=MIGR-5088993
Thanks
Oct 24, 2011 | IBM x3400 Server
I have a seagate Freeagent Go 500gb and suddenly it is not recognized by my laptop.
Try with another PC, If still not recognising, then You have to open the Casing of your external drive. If you have any Warrenty remaining for this Drive, then let company people fix this. if no warrenty then Remove the HDD from the casing, Connect HDD to the PC with another External casing, and backup your Data. If no ditection with this method, then your HDD is Dead. Keep finger crossed best of luck
Feb 01, 2011 | Seagate FreeAgent Go 120 GB USB 2.0 Hard...
Bad sector problem, and hdd is not working proparly, hdd ditecting problem
you could run the check disk utility
click start run type cmd then type chkdsk/r/f which willscan for and attempt to repair any bad sectors and automatically fix any corrupt files on your hard drive then defragment your hard drive
Nov 17, 2010 | Fujitsu 160GB 2.5" 7200rpm Internal Hard...
HDD is not detect & some sound coming from HDD.
I f ur hearing a whirling and clicking noise in ur HDD, that means it is already BUSTED and needs to replace! The internal LENS can't read the disk anymore! Taah!
Nov 13, 2010 | Samsung (MP0804H) 80 GB Hard Drive
My Hdd Has Been Not Ditected
Sounds like your drive needs to be formatted, click the start icon in your taskbar then right click "computer" and select "manage" this will open the "computer managment" window from the list select "disk managment" and your drive should be visible in the lower list on the right. Right click and select format from the list. Hope this helps
Aug 26, 2010 | Seagate 80GB 7200 rpm SATA/150 8MB Serial...
Not ditect SATA HARDISK
Hi
I know what is problem,some of mother is made only SATA HDD data transfer rate 1.5 GB per second.Now all are SATA HDD data read rate 3 up to g GB per second .Follow the instruction label on the hard drive.
If you use your Motherboard 3GB data read hard drive you can customise setting jumper source of data rate 1.5 then MSI Motherboard detect SATA hard drive.
Good Luck.
Nov 26, 2009 | Intel Motherboard
Array
its simple... just install the SATA driver for ur motherboard to ditect the SATA HDD.. u can download it from the WEB.
May 17, 2009 | Computers & Internet
My sony ps2 not working with hdd
the hard disk is not to be messed with if you do your system might crash and burn do you have a ps2 or ps3?
May 14, 2008 | Sony PlayStation 2 (PS2) Console
Harddisk Bad sector & not detecting
Hi, If your partitioning and/or formatting program is already reporting "bad sectors", then your best bet is to replace the hard drive. The mere presence of bad sectors indicates drive problem which in the normal course of time/usage would increase and eventually make the drive inoperable. Using such a drive as your "C" and/or to contain mission critical files may not be to your advantage. Hope this be of some idea/help. Good luck and kind regards.
Sep 28, 2007 | Seagate ST3250820A 250 GB EIDE Hard Drive
Seagate FreeAgent Pro - 500GB, 7200 RPM, USB 2.0, eSATA, External 500 GB Hard Drive Logo
67 people viewed this question
Top Seagate Computers & Internet Experts
Computer Links
Steve
terminalcon
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
