Question about Craftsman 25cc Gas Line Trimmer
Weed eater bogs down when i try to give it full throttle, won,t get up enough speed and torque to trim grass. i tried new gas, spark plug, and still doesn,t help.
  • 36 Answers
Have to adjust the high on the carb. should have, 3 screws, 2 that are together is your h for high, and L for low. the one by itself is for idle. when mackine is running, squeeze throttle and adjust the high til it clears up, if it stalls real fast, back counter clockwise while off, and try to restart it, if worse, go the other way. i do mine by 1/4 turns. keep count of turns in case your going the wrong way! hope this helps!
Posted on Sep 22, 2010
Weed-eater fl1500le new carb new gas and filter new spark plug getting spark will not start
try priming it 10 times and hold the throttle wide open when trying to start it
Jun 15, 2017 | Garden
When weed eater is running in order to get the head to turn i've got to give it full throttle before i can cut the grass, and it still bogs down.
do you have two adjustment screws down in a hole in the carb?
If you do they are the carb. high and low adjustment.
What I do is take a hacksaw and cut a groove right in the housing an the screw heads .that way you can adjust them Good luck
Feb 07, 2015 | Troy Garden
Weed eater bogs out at full throttle
Make sure fuel is mixed correctly, make sure the choke isnt stuck on aswel, ive had it happen to me before when the little blue leaver sticks and it wont rev out properly.
Apr 02, 2013 | Husqvarna 128 LD Weedeater
Ryobi weed eater stalls when giving it gas
check air filter and spark plug if good carb adjustment is needed or carb may be loose. could be bad fuel water in gas will cause this
Aug 26, 2012 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Weed Eater Problems
If it runs with the choke closed then it's not getting enough gas. Check the gas filter on the end of the gas line in the gas tank. Remove the gas cap and using a piece of wire with a hook on the end, reach in the tank and pull the gas line out through the opening. Check the filter on the end of it. You could also have a burst-ed diaphragm in the carburetor. This sucks the gas from the tank to the carb. If that's the case a new weed eater may be in order unless you can find someone with the parts to repair it. Also check the gas lines for leaks or breaks, 2 of them.
May 17, 2010 | Troy Garden
I have a 31 cc ryobi weed eater start for about
I think a new carburetor kit and a good carburetor tune up is in order my friend. Sounds like it's starving for gas. If it bogs down after warm up when you throttle it, then yes it needs a carb tuning. The L screw is the low side screw and should be turned in lightly until it seats then back it out one and quarter turns (1 1/4). The H screw is your high speed screw. Also, turn it in lightly until it seats, then back it out approximately a 3/4 turn. With these settings the unit should start and may even stay running. Again, if it bogs when throttled, while running turn the L screw out a little more maybe only 1/16th of a turn and then try it again. If it does rev then you'll have to adjust the H screw in about a 1/16th of a turn. But make sure you only do this after the engine has warmed up.
Hope this works, good luck
Skidooer
Sep 27, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Echo Weed Eater bogs down.
Echo carbs have a little black plastic plug covering the High speed adj screw..CA air pulotion control bs..So get that little black blug out and give the screw a little turn open and u should be good to go..It worked for me..on a PBL 251 blower..My Echo weed wacker has the carb also..Go to Echos site and download the parts break down for your unit and look at the carb page..You will see the plug and HS,screw..happing wacking and blowing
Jul 05, 2009 | ECHO, Inc. PB-251C Handheld Blower
My te 475 weed eater wont start
Check the on-off switch? Try disconnecting the switch and see if it starts. If it does, replace the switch.
May 18, 2009 | Poulan/Weed Eater No. Te475 952711797 17"...
Craftsman 25cc Gas Line Trimmer Logo
4,720 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
