Hello, I have a Kenmore Heavy Duty 70 Series, model #82870120. I got it from my aunt, and I'm not sure exactly how old it is but it has the woodgrain at the top. It stopped spinning and doesn't agitate either. It just makes a loud noise. Any ideas what the problem is?
watugot
  • 290 Answers
SOURCE: belt on my kenmore 70 series washing machine
Your washer should be a direct drive unit, it has no belt. If you hear the motor running but nothing is happening you probably have a broken motor coupler. The coupler is about $10.
Pop off the trim pieces on each end of the console.
Remove the two screws that hold the console to the cabinet and flip the console back.
Remove the two clips that hold the cabinet to the rear panel of the washer and unplug the lid switch harness. The cabinet will tilt forward and slide off.
Remove the clips holding the water pump and move it to the side.
Unplug the wires from the motor and remove the clips holding it.
You will see the motor coupler.
Make sure you can turn the gearcase shaft with a pair of pliers so it is not locked up.
Post back and let me know what you find or if you need any help.
Posted on Dec 12, 2007
  • 177 Answers
SOURCE: Kenmore heavy duty 70 series model 82763110
set the load size to small, fill with water.
now after it fills with water do you hear anything? motor noise?
If you hear motor noise, it probably has a broken motor coupler.
if it doesnt do anything I would look at the lid switch and activator, the lid has to close and the switch has to know it closed. did the tab on the lid break off?
Posted on May 03, 2008
  • 113 Answers
SOURCE: Kenmore 70 series Agitation and Spin Cycyle clicking
Sounds like you have a broken motor coupler. Not expensive. #13 on the diagram. Part # 285753, dave www.washermd.com
Posted on Dec 16, 2008
  • 91 Answers
SOURCE: slow cold water only fill kenmore heavy duty 70 902202
remove fill hoses and inspected for debris or cloggs ,,,,
Posted on Jan 04, 2009
jsrock516
  • 5911 Answers
SOURCE: I have a Kenmore Heavy Duty 70 Series Extra
If this is a Kenmore Top Loader washing machine, it sounds like you have a broken motor coupling. The washer filling and draining, but no agitation and spin are common symptoms with this problem. There may also be a rattling or whirring sound as the drive motor attempts to engage.
NOTE: If the washer drains, the drive motor is working. This drain pump on this washer is driven by the drive motor.
The motor coupling is located between the back side of the drive motor and the gearcase (transmission). The coupling is used in place of a drive belt, which is why this type of washer is referred to as a "direct drive". The following link explains how to access and replace the motor coupling:
http://www.fixya.com/support/r385250-replacing_motor_coupling_kenmore_top
The part number is included with the link and can be purchased at appliancepartspros.com for about $11. I have included an illustration of what the coupler looks like below.
If the motor coupling is intact upon inspection, the other source of no agitation and spin would be the gearcase. The gearcase on these washers is fairly simple to replace. If you narrow it down to a failed gearcase, the next link explains the steps for replacing one:
http://www.fixya.com/support/r699497-replacing_gearcase
I could only find your model number referenced at repairclinic.com. The gearcase on their site lists for about $160 and is listed as item 423.
I could not find any exploded view diagrams of your washer, but the majority of all Kenmore and Whirlpool top loaders are designed with the same direct drive system. You can purchase a Direct-Drive Repair Manual at repairclinic.com for about $20 (Item number 1170635) if you need a guide for reference.
If you have any questions about this repair, or require additional assistance, please let me know. I hope I've given you enough to work with in trying to narrow down the cause of your problem.
Posted on Sep 29, 2009
Kenmore heavy duty 70 series model 110-8237012
probably your drain pump leaking it has a seal right where it attaches to motor,,,,mine is leaking there but haven't replaced it yet! lol
Feb 27, 2010 | Kenmore Washing Machines
Kenmore Heavy Duty 70 Series Leaking in the back
If you bought a new washer and you still have a leak, i guess it was not the washer but where it drains into. Sink or stand pipe has a leak. unless you are useing the old drain hose from your old washer. Dry up everything and look for the sorse of water with a bright light when the washer drains .
Nov 22, 2009 | Washing Machines
I have an old Kenmore Heavy Duty 70 series washer.
its a filter inside the water hose thats still blocked or the relay inside the washer for the cold feed is not opening up fully it could just need a clean or maybe a new one fitted
Nov 05, 2009 | Kenmore 22422 Top Load Washer
Dryer wont start.
can you hear the motor or does the unit humm or vibrate when it is turned on
if yes then have a look at the belt
if not it's time sor a service call
Aug 04, 2009 | Kenmore 700 6972 Dryer
Help with Kenmore washer 70 Series
I called a repair man. The machine, it turns out is gear driven, and all the gears were shot.
May 27, 2009 | Kenmore Washing Machines
Timer knob identification
hello here's a part list sight if you have your old knob you can match it here and order the part without knowing the part # Therese also lots of other useful stuff on this sight hope this helps
http://www.repairclinic.com/Kenmore-Washing-Machine-Parts?s=b6a11c251
please rate this post
Mar 15, 2009 | Washing Machines
Kenmore 82372110 70 series heavy duty plus won't spin
If it drains and won't spin you have to replace the direct drive coupling.
Feb 25, 2009 | Kenmore Washing Machines
Kenmore heavy duty series model 82672810 hearing a
i would guess you have something stuck in the pump.
you will need to remove the cabinet and then find the hoses going into the pump. when you remove the hoses, you will find something inside the pump causing the noise.
Feb 23, 2009 | Washing Machines
Slow cold water only fill kenmore heavy duty 70 902202
Dec 30, 2008 | Kenmore 22422 Top Load Washer
Kenmore, heavy duty dryer, 70 series extra capacity, not heating
The following link explains how to diagnose a dryer "no heat" problem:
http://www.fixya.com/support/r630242-dryer_runs_but_not_heat
If you require addtional assistance, please let me know. I hope this helps you diagnose your problem.
Aug 12, 2008 | Kenmore 63942 Dryer
Washing Machines Logo
70 people viewed this question
Top Washing Machines Experts
