Question about Whirlpool WED5100SQ Front-Load Electric Dryer
Are there fuses in the dryer? Not getting hot. Could it be the heating element?
  • 4,323 Answers
Hi
If the dryer is not drying the clothes then you would need to check for the following things-
Electric Dryer---
1. Inspect the fuses and circuit breakers they may have burned out or tripped. Usually, dryer will still tumble but not create heat if a fuse or a circuit breaker is not working.
2. Check for the amp reading at 240 V, it should have reading of 24, 21 and 3 amp (approx.) for 2 lines and neutral respectively.
3. Heating element may have turned or the connection to the element might be loose. Sometimes a shorted circuit element will keep on blowing the fuse or circuit breaker.
4. Motor wiring shorting to ground.
Hope this helps...
Daniel
Posted on Sep 15, 2010
jsrock516
  • 5911 Answers
SOURCE: Dryer Top Hot / New Heating Element Smell
Any time you perform work inside a dryer, lint can get kicked around and settle on components. It is common to have a slight burning smell for a day or so. However, your dryer getting too hot to the touch concerns me. Improper air flow is the number one cause of dryer overheating problems. You may have cleaned the lint out of the interior of your dryer, but did you check the air blower and vent duct lines? In addition, was the heating elements actually bad? Or, did you assume it was bad, because your dryer wasn't drying properly? The following link can explain:
http://www.fixya.com/support/r630242-dryer_runs_but_not_heat
Pay particular attention to the paragraph that discusses proper ventilation. I would recommend you remove the vent hose from the back of the dryer and attempt to dry another load. If the dryer dries more efficiently and the top panel does not get scorching hot to the touch, then you have a vent clog somewhere EXTERNAL to the dryer. If the dryer air flow exiting the dryer is weak and the dryer still gets too hot to the touch, you have a clog INSIDE the dryer.
Follow these steps, first and see what you find. If you verify your ventilation is clear and not kinked or clogged anywhere, then you might assume you have a component malfunction. I would hope to try to save you from purchasing parts you may not need. I hope you find this information helpful. Let me know if you require additional assistance.
PS Make sure you are using semi-rigid (metal type) vent ducting. It is crush resistant, heat resistant, does not kink easily, and resists rodents. It is what most manufacturers recommend. If you haven't replaced the dryer vent in a while, this may be a good time.
Posted on Nov 18, 2008
mark_37388
  • 100 Answers
SOURCE: Heating element is getting red hot - like a heater.
No the first thing I would check is the vent going outside may be cloged the air going across the heating element should keep it from glowing real bright
Posted on Mar 30, 2009
  • 4 Answers
SOURCE: Dryer element won't get hot
for safety reasons it has its own fuse and that may be your issue (new fuse $5)
To be safe i'd also get new thermostat ($15)
Posted on Apr 02, 2009
  • 113 Answers
SOURCE: Heating element failed twice
most dryers have a thermal fuse on the exhaust it may be open
Posted on Apr 24, 2009
canbruce75
  • 1776 Answers
SOURCE: dryer is not blowing hot air
Check the thermal fuse. It is about one inch long and is located just inside the rear of the dryer and is usually attached to the exhaust duct. Test it for continuity with a multimeter. A lack of continuity indicates a blown thermal fuse. The heating element can be tested in the same manner. Hope this helped and best wishes.
Posted on Aug 06, 2009
Dryer won't get hot
Find these five areas if your dryer is not heating up:
1. Proper Voltage
2. Heating Element
3. Thermal Fuse
4. Thermostat
5. Timer motor
Sep 15, 2016 | Dryers
Kenmore elite electric dryer runs but then gets hot and then shuts off, replaced thermal fuse, dryer vent and tubing not plugged, dryer runs gets hot blows thermal fuse again.
DRYER OVERHEATING:
Heating Element
A defective heating element can make a dryer too hot. If the element partially shorts out, it can produce heat all the time, regardless of whether the dryer is calling for heat. Remove the heating element to inspect it. The coils should not be touching each other or anything else.
Other Causes and Conditions
Air Flow Problem
Dryers need good ventilation to work properly. If the vent is clogged it can make the dryer too hot. Clean all of the vent tubing thoroughly.
Cycling Thermostat
Although not common, a defective cycling thermostat can make the dryer too hot. The cycling thermostat is supposed to turn on and off the heat to maintain the proper temperature. If the thermostat is defective it may keep the heat on too long. The thermostat is not adjustable or repairable, it must be replaced.
Felt Seal
Most dryers have a felt seal at the front and rear of the drum to keep the heat inside the drum. If the felt seal is worn away or missing, the dryer may keep heating and make the dryer too hot. This is not common.
Blower Wheel
A defective blower wheel will not spin properly and will not vent the hot air, making the dryer too hot. Check to see if there is adequate airflow out of the dryer.
https://www.youtube.com/watch?v=3m5NZvY9V5Q
GOD IS still GOOD !!!!
Apr 28, 2015 | Kenmore Dryers
My dryer is not getting hot
Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable. Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Dec 01, 2010 | Roper REX4634KQ Electric Dryer
Dryer runs but does not get hot to dry clothes
Hello there:
There are a couple of things to check if the dryer does not heat properly
There's no heat If your dryer doesn't heat, check these: Power from the house Heating element Thermal fuse Wiring Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected. Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable. Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Feb 27, 2010 | Dryers
Dryer not getting hot
Hello there:
f your dryer doesn't heat, check these: Heating element Thermal fuse Wiring f you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected. Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable. Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.) c5f4c5f.jpg
Feb 12, 2010 | Fisher and Paykel DEGX1 Electric Dryer
The dryer runs, but is not getting hot. Is there
Nov 21, 2009 | GE Profile Harmony DPGT750EC Electric...
My dryer will not get hot
Check the heating element for possible short. Replace if necessary. If the heating element is good, check the thermal fuse and the door switch. If it is the door switch, the unit will not come on at all.
Apr 18, 2009 | Dryers
Mar 17, 2009 | Whirlpool LER5636P Electric Dryer
GE Prodigy Electric Dryer not getting hot
The exhaust hose in the back will not affect whether the dryer will heat. The hose just removes the used hot air to a place outside your house. I assume dryer drum spins, but you get no heat. If the dryer has gotten a few years of use, I suspect that the heating element has gone bad. Have you noticed that it has taken longer and longer to dry clothes than it used to? If so, most probably the element is bad. The element is not unlike a heating element in an electric stove, and is housed in a duct inside the dryer.
Mar 10, 2008 | GE Profile Harmony DPGT750EC Electric...
Whirlpool WED5100SQ Front-Load Electric Dryer Logo
107 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
