Question about Echo Garden
No spark Backpac blower New plug - Echo Garden
  • 1,040 Answers
You have a bad coil. This is the part that is connected to the spark plug.
Jim
Posted on Sep 16, 2010
CHANGE SPARK PLUG ON TORO CCR 3650 SNOW BLOWER
First disconnect the spark plug wire from the spark plug. Then use a socket wrench to remove the spark plug. Install the new spark plug into the cylinder head and reconnect the spark plug wire. The Toro CCR 3650 uses a NGK BPMR4A plug gapped to 0.032".
Jan 25, 2016 | Toro Garden
Why is it failing?
open gas cap and see if it will run again. m,any times the gas tank vents clog and the engine can't draw gas after a few minutes.
another thought is the oil mixture.. 50:1 with oil made for air cooled engines....not boat engine oil
Apr 02, 2014 | Husqvarna 150BT 50CC Gas Leaf Backpack...
I can not get my craftsman leaf blower to start. I put a new spark plug and fresh gas. Won't start.
Not to sure without seeing or hearing it being pulled over. Compression? Very likely needs some carb work/kit.
Apr 04, 2013 | Garden
Husqvarna model 125b Hand held blower (Gas) No
If you have tried a new spark plug and you still have no spark, then your Ignition Coil, (Module) has gone bad. They aren't cheap if you buy it new. Try to find a used one if you can for around $10.
Good Luck!
Jim
Aug 02, 2011 | Husqvarna Hand Held Blower 125 B Grass...
Not getting any spark. what should I check first
Check the obvious first.
  • Is the spark plug in good condition? No cracks
  • Try a new plug
  • Are you sure no wire is shorting?
  • Have you done any recent repairs?
  • Does a new plug get spark??
Try to change the plug with correct gap new plug.
Jul 04, 2010 | Weedeater 2 Speed Gas Blower FL1500LE ()
No Spark, plug is good
Hi
If you have a good plug in still no spark you will need to install a new coil.
Sam
Jan 07, 2010 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Leaf blower won't start. I think it's the module
If you haven't done it already, install a new plug. It's possible you're being fooled by a faulty/fouled plug. A fouled plug may not spark visibly - like if there is dirt down in the recesses of plug around the electrode. It would be a good idea to check it with a new plug before spending $80 bucks for a new ignition module.
Aug 10, 2009 | Troy-Bilt Garden
POWER BLOWER Won't start
You could unplug the the wire on coil and chek again for spark, Good luck.
Mar 23, 2009 | Husqvarna Backpack Blower 25cc, 140 Mph,...
Diesel fuel in homelite leaf blower !
this is not a problem
you need to remove all the fuel
and remove your spark plug add new fuel and with the spark plug out pull it over many times to purge the system now install a new spark plug and you will be fine
Nov 25, 2008 | Homelite Consumer Products MightyLite...
Garden Logo
178 people viewed this question
Top Echo Garden Experts
Jim London
Jim London
Roland W VanLue
Roland W VanLue
colesmowers
Are you an Echo Garden Expert? Answer questions, earn points and help others
