Question about Goodman CLQ36AR49 Air Conditioner
Why does it gurgle through the drain pipe? - Goodman CLQ36AR49 Air Conditioner
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 23 Answers
Normally due to positive and negative air pressure mixing while the water is coming out, it means your almost vapor locked, and sounds as though the drain is not properly trapped. You should have at least 1/2 of fall per foot or run on the drain and it should be trapped with a p-trap or running trap to prevent it from a vapor lock, and to keep the air outside from mixing with you conditioned air inside by entering though the drain.
Posted on Oct 01, 2010
  • gahmsrefrig Oct 13, 2010
    you might not have enough return air creating negative pressure inside air handler...if this has recently occured it could be a very dirty filter also...also if you have a floor register single return air register, make sure it isnt blocked
Gurgling water noise
I would think that it is the ac evaporator unit and condensate in the ac box that is unable to get out the drain pipe from a blockage . It could be ice melting off the ac unit fins . check that the ac is operating properly
Apr 23, 2014 | 2001 Land Rover Discovery Series II
Mr slim makes gurgling sounds when in heat mode
the sounds it is on the condensing drain or freon pipe?
Nov 29, 2013 | Heating & Cooling
Sewer smell in house since installing the new toliet and the toliet gurgles when the washing machine is on. It started with the new toliet now the gurgling and smell is also present in another bathroom.
It sounds like a vent problem.
On top of each house is a vent stack.
There should be a vent stack above each toilet, and above kitchen sink.
Look for pipes sticking out of roof.
These pipes are open to the sewer line.
When you run a column of water down a drain, the vent stack lets air flow in front of and behind the column of water.
This air flow prevents the gurgling sound.
The gurgling sound is the drain water pushing air in front of it because of a clogged vent.
If you have a two story house, there are vents that run between floors to prevent the air flow from gurgling or bubbling sewer air into each drain as water column moves down pipe.
http://www.bradyinspects.com/plumbing-vents.html
http://chestofbooks.com/home-improvement/construction/plumbing/Standard-Practical/Venting-Part-3.html
Look for bird nest over vent pipe on top of house.
Run a snake down into pipe from roof and see if the is a stoppage.
You many need to call plumber to track down each vent and the cause.
For example if there are quick-vents installed inside a wall and the quick vent is no longer working.
You can also take advantage of fixya phone support.
Fixya expert will walk you through the steps for a price.
Dec 25, 2010 | Kohler Bath Highline K-11492-96 Biscuit...
Lately after using basement shower, the toilet will gurgle and the water will drain. Also floor drain nearby will gurgle. What's up with that?
You have a blockage in you main drain for that area and will have clear it using a pipe snake,which is the quick fix but can cost about 100 bucks or you can try a drain cleaning chemical which may or may not work. you have to be careful with chemicals for many reasons such as they are poison, and smelly. the hard ware store may have a snake you can rent. hope this helps.
Dec 21, 2010 | Home
Toilet wont flush completely. it may take 4 times or more to flush solids. i at first thought this was related to heavy rains we had been receiving in the area over a period of about 4 months. 2 days...
there is no air release. the vent must be clogged somewhere. you can take a hose up there and see if it drains all the way or floods over. since the tub drain has a trap and the toilet itself is a trap, there has to bee a good amount of air pressure coming up without a release. i would say an obstruction. possibly at the junction of the main and the vent.
Nov 09, 2009 | Eljer 091-2190-43 Platinum Patriot...
When I open and close the freezer door there is a gurgling sound
The gurgling sound , is the vacuum being pulled thru the defrost drain line . Like when you close a freezer door , and you see the gasket being pulled in tighter . This gurgling , is the drain p trap with a vacuum being pulled thru it . Normal .
Sep 25, 2009 | Kenmore Refrigerators
A/C Clogged drain pipe
Can you get to the hose in the house unit? If so canned air
May 26, 2009 | Carrier Heating & Cooling
Water drains slowly from newly-installed kitchen sink and gurgles as the last drops go down the drain
sounds like you have a partial blockage in wall pipe.take of p trap and snake pipe in wall as far as you can.
May 09, 2009 | Home
I have started hearing a gurgling sound in my diswasher air vent when I run water in my sink. Why has this begun happening? I have an /estate dishwasher Model TUD7000Y-0
Sounds like your waste water drains could be backing up and pushing water back into the dishwasher.
Firstly try pouring Mr Muscle sink and plughole un-blocker down the sink and leave overnight next morning pour boiling water down the sink and your pipes should be squeaky clean. Hopefully this will improve the flow and prevent gurgling!
Feb 21, 2009 | Miele 24 in. G870 Built-in Dishwasher
Sub-zero 650 makes loud gurgling sound
gurgling is not unusual and is caused exactly by fluid bubbling thro a pipe.
Nov 04, 2008 | Sub-Zero 650 / O Bottom Freezer...
Goodman CLQ36AR49 Air Conditioner Logo
327 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
paulcarew
Brandon Berry
Brandon Berry
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
