Question about Brother Multi-Function Center MFC-240C All-In-One InkJet Printer
When turned on it says cover open. reinstall ink cartridges and close cover, i have reinstalled ink cartridges several times and it continues to say the say. everyonce in awhile it will say insert yellow ink cartridge and close cover. nothing i have done has changed the situation. i am beginning to get very angry due to i have not been able use my printer thingy still and i have had for quite some time
    New Friend:
    Problem Solver:
  • 13 Answers
Hello
There is a possibility that you have forgotten to pull off the protected clear tape on the cartridge and therefore, the printer does not recognize its existence.
ilona
Posted on Aug 02, 2017
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 147 Answers
Use bin and purchase new. Repair costs are high.
SOURCE: ink
If you don't have the cartridges seated properly you will get this message. Pull them and try again. Myself, I tried to save some money, and bought Brothers refilled ink cartridges. They wouldn't work, so only use new Brothers ink cartridges. Unplug the printer from the wall for it to recycle, don't use the power button. Good Luck
Posted on Apr 25, 2007
SOURCE: replaced yellow ink(cyan) with new one
Putting a piece of tape over each cartridge window, solved the problem for me. I used some very thin white tape. Make sure you shut the printer down completely and restart it after doing this. I got the warning that all the ink levels were low and would need to be replaced, but no longer prevents you from printing. I did a test page all is well.
Posted on Sep 13, 2008
SOURCE: Just changed my black cartridge (LC41BK); scrolling in window:
This happened with mine too.
I had to remove ALL the cartridges before the computer realized it was ok again.
Hope it works for you
Posted on Mar 17, 2009
  • 9 Answers
SOURCE: Changed yellow ink to new cartridge. Printer won't recognize.
I contacted the Brother site, the support function there. Pursuant to what I found there, I unplugged the printer for ten seconds and replugged. The message display then told me that cyan was empty, and that magenta was near empty.
I installed a new cartridge in place of the empty cyan, and that fixed it.
Posted on Jun 05, 2009
  • 526 Answers
SOURCE: After installing new cyan cartridge, display reads No Cartridge
look at the ink cartridge and and first see if the ink covers the top of the cartridge. there is a little part of the ink cartridge the best way to explain it, is there is a tab,. that tab goes into a sensor. if the tab has ink on it, then you mostly like have a problem with the sensor itself. but if there is no ink, the printer is correct. i have had several people bring printers with those type of problems, and when they bring the cartridge i look at it, and they are practically empty.
thanks
Posted on Jun 26, 2009
I am refilling the black ink of my canon printer using continuous ink container but the black color doesn't flow into the end of the hose and it didn't print at all, please help
  • Check the printer's power/alarm light. If it is flashing orange, count the number of flashes. Look up the flash code in your printer's user manual to diagnose the problem.
  • 2 Remove and reinstall the ink cartridges if the power/alarm light flashes 5, 7 or 15 times consecutively. This indicates that the issue is a cartridge error, an incorrectly installed cartridge, or an unrecognized cartridge. These errors can be fixed by reinstalling the ink cartridges. Make sure that you are using the correct ink cartridges for your Canon printer.
  • Turn on the printer and open the front cover. The ink cartridge holder should move to the replacement position.
  • 4 Verify that the colored ink cartridge is inserted in the slot on the right and the black ink cartridge is inserted in the slot on the left. Swap the cartridges and reinstall them in the correct slots if necessary.
  • 5 Check to see that both ink cartridges are level with one other and parallel to the top of the ink cartridge holder. If either cartridge is wedged at an angle, gently apply pressure to the cartridge until it clicks into the correct position.
  • 6 Close the front cover of your Canon printer and wait while the printer initializes the newly installed cartridges. This can take a minute or two.
  • Jun 12, 2011 | Office Equipment & Supplies
    Cartridse error
    If you see a message saying that you have an incorrect ink cartridge, a flashing cartridge light meaning a bad color cartridge or you are told to remove the color cartridge, you should follow these steps to correct the problem if you are sure you have installed the correct color ink cartridge.
    Instructions
    Reinstall the ink cartridge
    1. Turn on the printer and open the cover where the ink cartridge is located. Remove the cartridge.
    2. Place the ink cartridge back in the carriage. Close the cover. Turn the printer off for a minute.
    3. Turn the HP printer on. Use the printer to print a test page. If this does not correct the problem, continue reading.
    Wipe down the cartridge contacts
    2. Remove the cartridge an use a clean, lint-free, dry cloth to gently wipe the contacts.
    3. Wipe from the top of the contact to the bottom. Do this for each contact.
    4. Place the HP ink cartridge back in the carriage. Turn the printer off for a minute.
    5. Turn the HP printer on. Use the printer to print a test page. If this does not correct the problem, continue reading.
    Reset the Officejet printer
    1. Turn on the HP printer.
    2. Unplug the power cord from the back of the printer and wait one minute.
    3. Plug the power cord back into the printer. Press the on button and hold until printer turns on.
    4. Print a test page to see if this has fixed the problem. If not, you will need to buy a new color ink unit.
    Jun 04, 2011 | HP Officejet 5610 All-In-One InkJet...
    The black printer cartridge leaked a fair amount of ink in to the printer. I am getting all lights flashing and the printer won't even turn off when I hit the power button. I did some cleaning and it...
    Sorry to hear that.. here are some instructions that should help you out:
    Instructions
    things you'll need: Microfiber cloth
    1. Ink Cartridge Errors
    2. Turn the printer on and open the ink cartridge cover. Wait for the cartridge carriage to stop completely before reaching into the printer.
    3. Press on the top of each print cartridge, then pull the cartridges free from the carriage. Make sure you are only using HP cartridges labeled as "HP 60" or "HP 60XL."
    4. Reinstall the ink cartridges and close the cover. If the ink cartridge error message displays again, remove the ink cartridges as before.
    5. Clean the copper metal contacts on the cartridges using a dry microfiber cloth. If you still see the error message after you reinstall the ink cartridges, replace hem with new cartridges.
    Print using the device's ink backup mode if you do not have a replacement for one of the cartridges. Remove the cartridge you cannot replace and close the cover and continue printing. The printer will automatically use the backup mode until you install a new cartridge.
    Mar 21, 2011 | HP DeskJet F4280 All In One Printer InkJet
    Message no cartridge when installing new cartridge. I have installed new ink cartridges but the printer keeps coming up with the message 'No Cartridge' Reinstall the cartridge. I have done this three or...
    Hello ,
    Start by opening your ink cover and read the LCD screen; this will alert you as to which ink cartridge is not being recognized; make sure the cartridge that it is telling you is empty has been changed.
    If the unit is still not recognizing the cartridge you have changed, follow the steps below.
    1. Unplug the power cord for the printer unit.
    2. Open the ink cartridge cover and remove all ink cartridges.
    3. Close the ink cartridge cover.
    4. Plug the power cord back in.
    5. Reinstall the ink cartridges.
    Thank you,
    Pat
    Mar 28, 2010 | Office Equipment & Supplies
    thanks
    Jun 26, 2009 | Brother MFC-5440CN All-In-One InkJet...
    Compatible ink cartridges not working
    either the cartridge circuit is damaged or there is a problem with your printer. To make sure, you will have to try the cartridge on another similar printer. If it works on another printer, the problem lies with your printer.
    May 23, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
    Where is the ink cartridge?
    It is on the FRONT RIGHT PANEL, See below. Bud
    1. Unplug the machine from the AC power outlet, wait approximately 10 seconds and then plug it back in. If the display continues to show NO CARTRIDGE, continue to Step 2.
    2. Open the ink cartridge cover. Pull the lock release levers down and take out the ink cartridges.
    1. Reinstall the ink cartridges and lift and push each lock release lever until it clicks, then close the ink cartridge cover.
    Jan 06, 2009 | Brother MFC 240C All-In-One InkJet Printer
    Reinstalling ink
    I put a new magenta cartridge in the printer. It says to open the scanner cover, then reinstall ink cartridge. when i open the scanner cover nothing happens and i dont know how to install the ink.
    Oct 03, 2008 | Brother DCP 115C All-In-One InkJet Printer
    Flashing lights
    That flashing pattern is consistent with a stuck carriage. Here is a copy/paste from HP concerning the 5000 series and your flashing lights.
    Issue
    The print cartridge carriage is stuck.
    Solution
    1. Open the top access door on the printer.
    2. Remove the ink cartridges.
    3. Close the cartridge flaps after removing the ink cartridges.
    4. Turn the printer off, then on again.
    5. Replace the ink cartridges.
    6. Close the top access door. Issue
    The Resume light continues to blink after the cartridges are released.
    OR
    The carriage is stuck or makes a grinding noise.
    Solution
    1. Lift the top cover to the printer.
    2. Turn the printer off and then on again.
    3. Unplug the power cord from the back of the printer when the grinding noise starts. Unplug the power cord from the wall outlet.
    4. Move the carriage towards the middle of the printer (this procedure may take a couple of tries to get the timing correct).
    5. Take out the cartridges and close the top cover.
    6. Reconnect the power cord to the back of the printer. Plug the power cord to the wall outlet.
    7. Open the top cover, reinstall the cartridges, and then close the top cover.
    Oct 23, 2007 | HP DeskJet 5550 InkJet Printer
    Brother Multi-Function Center  MFC-240C All-In-One InkJet Printer Logo
    37 people viewed this question
    James Cagle
    James Cagle
    Samyfam
    Samyfam
    Jim Keysor
