Question about Haier HP50B 50 in. Plasma Television
What is a pcb assy - Haier HP50B 50 in. Plasma Television
  • 2,318 Answers
PCB stands for Printed Circuit Board and assy is assembly when the the PCB is populated with all the parts/components.
Posted on Sep 15, 2010
I have an LG RU-42PX11 plasma tv. A couple weeks ago we heard a pop and the picture went blank. I can still change channels via cable box and I have sound but no picture.
6871QCH034A PCB ASSEMBLY,DISPLAY CTRL ASSY 42V6 NEW MCM(1222) LVDS
202 6871QDH066A PCB ASSEMBLY,DISPLAY YDRV ASSY 42V6 YDRV TOP ASSY
203 6871QDH067A PCB ASSEMBLY,DISPLAY YDRV ASSY 42V6 YDRV BTM ASSY
204 6871QLH034A PCB ASSEMBLY,DISPLAY XRLT ASSY 42V6_XL(4LAYER)
205 6871QRH037A PCB ASSEMBLY,DISPLAY XRRT ASSY 42V6_XR(4LAYER)
206 6871QYH029A PCB ASSEMBLY,DISPLAY YSUS ASSY 42V6
207 6871QZH033A PCB ASSEMBLY,DISPLAY ZSUS ASSY 42V6
These are the part numbers for all the boards that deal with the display. Im leaning towards the sustains as well and you need to do both at the same time cause if one is bad and you replace just one, a bad one can fry the new one.
Jan 20, 2017 | LG Televison & Video
Mfc 7360 unable to print 7a
Error code 7A
A synchronized signal of the main motor cannot be detected.
Turn the power off and then back on again.
1 Flat cable connection failure of main motor
Check the flat cable connection of the main
motor and reconnect them.
2 Main motor failure Replace the main motor.
3 Low voltage power supply PCB failure
Replace the low voltage power supply PCB ASSY.
4 Main PCB failure Replace the main PCB ASSY.
Jan 14, 2015 | Brother MFC 7360N - Multifunction fax /...
Unable to print 36
Possible Reason:
1. High voltage power supply PCB
failure
---Replace the high voltage power supply
PCB ASSY.
2. Harness connection failure of high
---Check the harness connection of the high
voltage power supply PCB and reconnect
it.
3. Main PCB failure
---Replace the main PCB ASSY.
Aug 08, 2014 | Brother Dcp-7055 Laser Print Copy Scan...
Brother dcp7055 how to fix unable to print 36
Try these:
1. Replace the High Voltage Power Supply PCB ASSY.
2. Check the harness connection of the high voltage power supply PCB and re-connect it.
3. Replace the main PCB ASSY.
Jun 16, 2014 | Brother Dcp-7055 Laser Print Copy Scan...
The USB of my Samsumg LED HDReady 32" Tv is broken. Can it be replaced? If yes, how?
The Main PCB will need to be replaced, part# depends on your model#.. ( http://www.samsungparts.com/partslist.aspx?Catalog=Parts_and_Accessories&Category=LA40B530P7R ) See Below
BN94-03079U
MAIN PCB
$116.79
Nationwide BO, Usually ships within 4-6 weeks
BN94-02930L
MAIN PCB
$116.11
More on the way, Usually ships within 3-5 business days Specification
LA40B530P7RXZN
ASSY PCB MAIN Specification
LA32B530P7RX
ASSY PCB MAIN
Nov 25, 2013 | Samsung LA40B530 40 in. HD-Ready TV
Hello experts, witch main pcb is built into Canon Powershot D10? Canon-repair told me main pcb and jack pcb assy have to be changed after corrosion. i found jack pcb assy for change but i couldn`t find...
Your camera is run by a program that is loaded onto the main board when it is replaced. This program is not available (Canon considers it propriety information) so the only way you could replace the main board would be with a used one (that already has the program installed) pulled from a salvage camera. However, this program also has color correction information and dead pixel information etc for the image sensor in the camera. You would have to replace the sensor from the salvage at the same time so that it matches. It would be cheaper to buy a used camera - check Ebay.
Sep 02, 2013 | Canon Cameras
Fuser unit failure
Remedy:
1.Replace fuser unit
2.Check the harness connection between fuser unit connector and eject sensor PCB ASSY
3. Replace the PS PCB unit
4.Replace the toner LED PCB ASSY
5.Replace the main PCB assy.
You can try to leave the machine power on for 10 minutes maybe this can clear the error. Or power on the machine while pressing the SW supporter,when the front cover is open and check that toner, DRUM and error LEDs light up, and then release the SW supporter. Check that all LEDs go off and press the SW supporter once,and then this problem maybe cleared by that press the SW supporter once again after all LEDs light up.
Apr 14, 2013 | Brother HL-2170W Laser Printer
000014-000 this the error code. When I turn the copier on ... it tries to start ... then this code come on and it says call a tech.
E014
000 After the fixing motor drive signal is generated, the clock signal does not
arrive within 3.0 sec.
Main cause The fixing motor (M19) is faulty. The DC controller PCB is faulty.
Action
1. Connector
Is the connector of the fixing motor connected?
NO: Connect the connector.
2. Main power supply PCB
Is the drive voltage (24 V) of the fixing motor supplied by the main power
supply PCB?
Main power supply PCB: between J202-3 (24VU1-S) and J202-4 (OVU1)
NO: Replace the main power supply PCB.
3. Fixing motor (M19), DC controller PCB
Press the Start key. Is the lock signal of the fixing motor present at the connector
(J312) on the DC controller PCB?
Lock signal: J312-B4 (FSRM_LOCK*)
the DC controller PCB change from 0 to about 5 V?
YES: Replace the fixing motor.
NO: Replace the DC controller PCB.
BUT FIRST: did you removed fixing assy from any reason? If you did try to repositioned it. Check for any foreighn matters inside or around the fixing assy. Try to reconect the fixing assy connectors. Check gears of fixing assy and drive assy.
Nov 18, 2009 | Canon (6981A002AA) for imagerunner 2200,...
Ilo-32HD Main PCB Assy
Hey, you can try http://www.discount-merchant.com/ They have may parts. just remember that the board you are looking for may be made buy another manufacturer and used in other displays. Part numbers might be differen but the same power supply. You can call them and ask them, they have free tech support.
Mar 23, 2009 | iLO 3200 32 in. LCD Television
Error 41 on my MFC 5460CN
Dear Naveka_R
Error 41 can be caused by
* Carriage Assy
* Print Head assy
* Main PCB
* Power supply pcb.
If it's anything other than cleaning the print head, chuck the thing away.
regards
scorpionakku
Oct 03, 2008 | Brother Office Equipment & Supplies
Haier HP50B 50 in. Plasma Television Logo
131 people viewed this question
Top Haier Televison & Video Experts
Jaime Hernandez
Are you a Haier Televison and Video Expert? Answer questions, earn points and help others
