Hi.
If the water is cold, check the inlet hose and the hot inlet in the dual inlet valve connected to the hose. If there is no hot water the cycle will not progress, and that may be related to the drain problem.
If the machine does not drain even with hot water, check the thermostat and the pressure switch. The thermostat decides when to open and close the hot inlet, moving forward with cycle when temperature is met. The pressure switch determines among other things when to start and stop drain pump.
The thermostat is tested reading Ohms, multimeter set on impedance must read low or no impedance at room temperature on thermistor contacts. The pressure switch is replaced if there is a drain problem and the rest does not help. This part is more difficult to test.
About the drain problem, check first drain lines, drain well and drain ose at the back.
As first thing call Ariston at the number listed on the owners manual and check warranty status.
Hello - Hot water is most often 10 degrees colder when it arrives at your machine from when it leaves your hot water heater. In general hot water is 130 degrees Fahrenheit (54.4 Celsius) or above. Warm water is between 110 and 90 degrees Fahrenheit ( 43.3-32.2 Celsius). Cold water is generally between 80 and 60 degrees Fahrenheit (26.7-15 Celsius). If cold water is below 60 degrees Fahrenheit (15 Celsius), clothes are unlikely to be cleaned very well. After confirming information and it proves to be ineffective contact a professional to move forward accurately. Unit could possibly be experiencing a defective timer, temperature sensor, or water valve.
