Question about Coleman Mach 15 Air Conditioner
System works fine for about five minutes - blows well refrigerated air air, fan works great. Then the circuit breaker shuts it down every time. Could this five year old unit need recharging? On fan only, it operates well.
  • gunnersarm99 Sep 15, 2010
    sounds like good advice. thank you
    very quick and well explained
    President:
  • 2,777 Answers
It sounds like it does need recharging, yes. 5 years is about average for such a system, if it is used fairly regularly during warm seasons...
It could be the condenser portion has a circuitry issue as well, something causing a fault that trips the circuit breaker.... I would investigate the cost of a recharge and if it is anywhere near the cost of a new unit I would just replace it if it were me. I'd hate to have you recharge the machine only to find it still throws the breaker, and there isn't much of a way to tell without trying it..
Thanks
Tim
Posted on Sep 15, 2010
Hi I keep getting a ch 67 after the unit starts fine and runs for like five minutes fan on all units work during that five minutes any thoughts would be greatly appreciated
Low freon pressure switch is turning it off. As the coils cool down the pressure drops. As time goes on it will run shorter and shorter cycles. In warm weather freon 22 low pressure should be near 70 lb
410A freon about 150 on the low side
May 02, 2015 | Heating & Cooling
Dryer blows circuit breaker after running 10-20 minutes.
indicates problem motor , overheating in the wiring or excessive loads in the drier
Jun 07, 2017 | Kenmore Dryers
Air conditioner will cool for five minutes and then turn off. comes on and off sporatically but never stays on for more than five minutes.
could be the pressure cut off switch is working out in advance as it cut off. If there is enough cooling then it can be possible that the filter is clogged and the condenser is clogged. If by choosing a higer fan speed for blowing iff the ac goes on for more time, then clean up all the fins and filters to make it more efficient to heat exchange, if not change the thermostat/ pressure cut off switch.
Sep 25, 2010 | Heating & Cooling
SL24J30 KILLING CIRCUIT BREAKER
Here is a tip that I wrote that will help you ti find out why the circuitbreaker is tripping.
Circuit Breaker Keeps Tripping
heatman101
Jun 24, 2010 | Friedrich SL24J30 Air Conditioner
The unit runs fine, but the compressor kicks on for 2 seconds and then shuts off, this just repeats over and over every minute or so. so it never blows cold air.
It could be a capacitor problem; however, more often than not, the compressor will fail to start at all with a failed capacitor. The sytem could be low on refrigerant causing the compressor to overheat and shut down. Another item to check before hiring a tech is to inspect all of your electrical connections and repair/tighten if necessary. Loose connections can cause motors to overheat and shut down.
Because you state "the unit runs fine" I'm assuming the fans are blowing air normally across the evaporator (blowing inside the RV) and normally across the condensor coil (blowing outside). Is this correct? If so, because the refrigerant level will need checked, you will need to have a licensed service tech look at your unit and offer his/her expert opinion of what your best options are.
Without having a toolbox in hand and being onsite to repair your system, I do hope you find this information very helpful to you in items to check yourself. Let me know if you have any further questions. :-)
Mar 13, 2010 | Dometic Rooftop RV Air Conditioner
Refrigerator cools as normal. Trips 15 AMP circuit breaker.
a full size refrige has to be on a 20 amp circuit, a 15 amp is just not big enough.. you should also know that this circuit has to be on a 12-2 gauge wire.. I also highly recommend installing a 20 amp HD receptacle
Mar 19, 2009 | Refrigerators
Gateway M-1625 shutting down few times a day
I am havin the same problem at the company i work at. The problem with our machines has to do with the mother boards. But you might want ot check the power supply and make sure it is rated high enough to run your system. Next check/blow out your CPU cooler, and go into bios and see if it is set up to shut off at a certain temp.
Dec 21, 2008 | Computers & Internet
Our casablanca ceiling fan has power going to the fan and the remote works but the fan does not nor does the light
If you have the intelitouch system, It's probably the circuit board in the fan. Casablanca has great motors but touchy boards. I ordered mine from www.fanmanlighting.com and installed it myself, it wasn't too difficult. Hope this helps
Jun 25, 2008 | Casablanca Fan 3245T Ceiling
Power supply repair HP Pavilion s 7210 n Slimline
need fans on main cpu maby died replace with ball bearing blow all the dust out of it with big vac on blow ok and go nuts blowing dust out add hiend nice quilty fans mascool on newegg 10 pack 12 bucks free ship cheap nice need air flow getting to hot and power suplly cant keep up get nice dual rail one ok
Jan 10, 2008 | Computers & Internet
JENN-AIR Oven shuts off and comes back on after several minutes
they are equiped with a heat sensor it could be a bad thermastat(sensor) or
ventalation problem
Nov 20, 2007 | Jenn-Air SVE47100 Slide-In Electric...
Coleman Mach 15 Air Conditioner Logo
409 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
paulcarew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
