Question about Intel D102GGC2 Motherboard
I have 2x1Gb of DDR2-800 RAM. when slot in these two ram to the motherboard i can boot up my pc as usual, but there is not output screen even my mouse and keyboard have no light. when i took out 1GB, everything just fine. any clue what is happeining?
    Problem Solver:
  • 16 Answers
I think that one module is malfunctioning.
Check it with a tool called memtest86:
http://www.memtest.org/#downiso
Posted on Sep 15, 2010
Acer desktp internal ram installation needed
I'm a bit confused....did you have all four of these in the ACER and are trying to put the 2x1GB into the Emachine? And that the 2x1 GB wouldn't work in the Emachine but they did in the ACER and that the 2x512 Acer cards worked in the emachine?
If that is what happened here is my best guess. The ACER MOBO will support 533/667/800 MHZ DDR2 RAM. The Emachine will only support 533 RAM. Iys possible the 2x1GB are either 667 or 800 MHZ and are not compatible with the Emachine but will work in the ACER.
Jan 23, 2012 | E-Machines T5082 PC Desktop
I am using Intel D865GBF board having Dual Channel DDR400/333/255 SDRAM memory support. It is of 3GHZ, 256 MB RAM. The other day I bought 1GB RAM of Transcend and tried fitting the same. But the PC never...
Yes it can support 1GB ram. Max capacity up to 4GB of ram, meaning 1GB each on each slot. Make sure that the memory that you will be installing are either DDR400, DDR333 or DDR266. It could be the RAM is faulty if the one you bought is the DDR's that I mentioned
Oct 11, 2010 | Intel D865GBF Motherboard
Trying to upgrade t5082 emachines from 1/2 to to 2g. the only way it will boot is if I leave the 1/2g in slot one & put one of the 2g in slot 2. Is there a way to make slot 1 read the 2g?
Your motherboard has a 1GB limit per slot so the 2 GB sticks are simply not recognized. Take them back and replace them with a 2x1GB set if you still want to upgrade the RAM.
Aug 04, 2010 | E-Machines T5082 PC Desktop
I have a asus p5vdc-mx mb
ok the board supports up 2GB of ram but you can only use 2 slots at a time you cant use 3 or 4 slots as they are diffrent ram chips so to use the full 2GB you can only get away with either 1X2GB ram or 2X1GB ram
Sep 25, 2009 | ASUS P5VDC-MX Motherboard
My computer keeps booting every 2 seconds and I just can see motherboards first screen during 1 second then cant see anything else
I am almost positive it is the ram, because it gets to windows but crashes after loading windows partially. I once had a similar problem. Just make sure all the Power Supply connectors are properly connected.
Try these steps too:
1. Full power down. Unplug the power cord from the Power supply. Then hold down the pc power button (this discharges any residual power in the capacitors).
2. Open the case and reseat the graphics card, hard drive, and RAM.
3. Take out one of the RAM sticks if there is 2 or more. Swap the RAM sticks in different RAM slots. Try one stick at a time to see if you can get the PC to boot. If this works, then the remaining ram sticks are damaged.
4. Set the Cmos jumper to clear. Power up the pc. Power down the PC. Set the Cmos jumper back to normal position, power up the PC.
5. Unplug and replug all the power supply cables.
6. Check the powersupply function. Either by a powersupply voltage checker (20-25 dollars at local PC shop), get the supply tested at a PC shop (usually a free service), put the powersupply in a different pc, or try a different powersupply in the problem computer.
If the Powersupply checks out ok, then you will have to do a process of elimination to find out what part or parts are the culprit of the No-Boot.
Start by pulling all the ram sticks if you have not already. This is the easiest components to check and usually a culprit.
Jul 07, 2009 | Intel D865GBF Motherboard
Two rams stopped working in intel d101ggc from today
You've got either mismatched RAM memory or 1 of your sticks are bad. You can isolate this by booting 1 stick at a time. If the machine boots fine with both sticks (one at a time) then they are mismatched or your motherboard isn't configure to handle the 2 sticks together (not very likely but a possibility) Hope this clarifies your problem All the best!
Greg
May 12, 2009 | Intel D101GGC Motherboard
Memory installation
bev,
all the DIM's must be of same type and same size to work, otherwise it creates problem, like no boot, boot with lowest memory etc.
There is no problem in your PC, its technical issue you can not use two ore more different type RAM at the same time in a motherborad.
Thanks
Iqbal
Apr 08, 2008 | Acer Aspireā„¢ T180 PC Desktop
Pc hangs up oftenly or show blank screen
Set your C Drive as Master and other all Drives as Slave
I Think this will slove your problem
Try IT
Mar 07, 2008 | Intel D845GVSR Motherboard
Doesn't boot with 3Gb of ram....
Your board can only handle 2Gb of total memory.
2 x DDR2 SDRAM DIMMs, Dual Channel DDR2 533/667/800.
Check your manual.
Dec 29, 2007 | Foxconn 6100M2MA-RS2H Motherboard
Intel D102GGC2 Motherboard Logo
54 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
