Question about Whirlpool Dryers
I have a Whirlpool LGR7646JQ0 Gas dryer. It wasn't heating. I took it apart and used a meter to check the list of things in a video linked to me here. Turned out to be the coils. Replaced those and the dryer worked fine for a couple weeks. \r\n Now its shutting down mid cycle. I put the load in, tuen it on, it starts up a bit loudly, then within a few minutes it shuts down and I have to unplug it, wait, plug it back in and start the laod again only to have the same thing happen. What could this be? I would have a repairman come out, but the warranty is useless since the shop I bought it from used went out of business and I cannot afford to pay repairman fees.
  • melbel615 Sep 15, 2010
    Also, my brother and I were messing with it as he has to work soon and needs his uniform dry. If you turn the dryer off, unplug, give it 5-10 minutes, plug it back in, hold the door latch down and manually turn the drum while startingit up it goes just fine but if you just try to start it up it makes a very loud sound and starts hit or miss.
  • Whirlpool Master
  • 16,376 Answers
Lack of airflow can cause the unit to overheat and shutdown. Check all the vent pipes for obstruction. IT could also be the high limit or the thermostat that is bad.
Posted on Apr 03, 2017
2 Suggested Answers
kel1guy2002
  • 3740 Answers
SOURCE: Whirlpool Gas Dryer Model #
Hi and welcome to FixYa. I am Kelly.
Your power for the burner assy goes on a series circuit from the timer to the high-limit thermostat to the operating thermostat to the thermal fuse to the gas burner assy, thru the motor centrifugal switch to the door switch. EACH of these must be functioning for the burner to light.
This manual will help with some of the how to do it as far as component access, removal and replacement of parts.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/4829abde74a34d7f85256ab000620794
Also this link has loads of information on what to check.
http://fixitnow.com/wp/2006/09/19/how-to-check-the-burner-components-in-a-gas-dryer/
The 3 most common failures are
Igniter:
Gas Valve
High Limit Thermostat
Compnents : http://fixitnow.com/appliantology/gasdryer.htm
Note the LINKS!
Here is a 9 min video that pretty much covers everything you need to check: http://www.howcast.com/videos/371390-How-To-Troubleshoot-a-Gas-Dryer-That-Wont-Heat
Thanks fo choosing FixYa.
Kelly
The
Posted on Aug 20, 2010
Heating unit on whirlpool dryer not working
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Jan 23, 2011 | Whirlpool Dryers
Ive changed the ignitor, sensor, thermostat, fuse-thrml, and thermostat-fix.. my dryer still is only heating for only 5 min then goes cold. what can i do? model: LGR7646JQ0
This is usually the dryer coils have failed. They tend to fail as they heat up. They are inexpensive and easy to replace. Here is a video on replacing the dryer coils.
Nov 11, 2010 | Whirlpool LGR7648KQ Dryer
My dryer will not heat up. I took the machine back off and could not see a flame when the machine is turned on. How do I get to the burner? Do I need to take the drum out? Any diagrams would be...
You remove the kickplate in front on most models. 01209c1.jpgThe first thing to check it the flame sensor. It must have continuity to turn on the ignitor.333fe98.jpg
The ignitor must have continuity also.4f11e40.jpg If both of those are good you want to look for an open thermal fuse/limiter. Duet dryer manual
OLD school whlp dryer training manual
Oct 06, 2010 | Whirlpool Dryers
Whirlpool Gas Dryer Model # LGR7646JQ0. Bought it used, warranty useless since the shop I got it from went out of business. Everything works fine. The drum turns, the timer works but the thing doesn't heat...
Igniter:
Gas Valve
Note the LINKS!
Kelly
The
Aug 20, 2010 | Whirlpool LGB6300 Gas Dryer
Whirlpool Cabrio - How do I tell if my heating
If you are comfortable useing a volt meter and a ohm meter I can walk you throught the steps otherwise you need to call a repairman, If you are not getting any heat and the tumbler is turning it is possible the element is bad again only a test meter can tell for sure or you can take the dryer apart and look at the element to see if it is broken make sure the power is turned off at the breaker first also unplug the dryer.
Apr 16, 2010 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
Dryer does not release any heat
Is yours the gas model? If so I need you to look for some things. Open back door panel and see if while trying to light the igniter is glowing orange. Sea Breeze
May 22, 2009 | Whirlpool LGB6300 Gas Dryer
Kitchenaid superba dryer won't heat Where is the heater fuse located?
Q - My electric dryer runs but will not heat, what could stop my dryer from heating?
A - Things that could stop a electric dryer from heating:
- house fuse or breaker ( needs two of them ), heating element, burnt wire, thermostat(s), thermal fuse ( not all models ), motor heat switch, timer, selector switch, burnt power cord/plug.
A ohm meter test for these parts is here.
Q - My gas dryer will not heat, what could stop my dryer from heating?
A - Things that could stop a gas dryer from heating:
- glow bar igniter, thermal fuse ( not all models ), coils on the gas valve, gas valve, thermostats,motor heat switch, timer, selector switch, sensor.
A page for checking gas dryers is here.
Meter testing and usage tips.
1. Power supply-check power supply at terminal block where cord enters the dryer. Should read 240V. If you read 240V here, tested with a volt meter, unplug dryer and test components with ohm meter.
2. Thermostats-Cycle and safety thermostats-read them with an ohm meter. Should show continuity . How common thermostats work.
3.Timer-The timer has a set of contacts that pass voltage to the heaters. If you can not determine by wiring picture what they are, check across the two terminals with the largest wires on them. The heater wires are almost twice as large as the others. You should read continuity with timer in heat mode.
4. Thermal fuses-In recent years the makers of dryers are using thermal fuses to let you know something is wrong with your dryer. They are generally non resetting and have to be replaced. The thermal fuses are located on the heater element housing and should read continuity if read with an ohm meter. Most blown thermal fuses are the result of vent/air flow problems or a grounded heating element.
5. Selector Switches-Read the wiring picture and determine which switch is closed. You should read continuity across closed switches.
6. Safety Switch on Motor-There is a safety switch on motor to insure that heaters can not come on unless motor is running. It is normally open when the motor is idle/not running, and closes when motor runs. In order to check with an ohm meter, remove the two large wires on motor switch and make them electrically safe. Tape them. Plug the dryer in and start motor. Check continuity across the terminals on the motor switch you removed the heavy wires from. If it is ok you should read continuity. Remember that the smaller wires in a dryer carry the 120V and the large wires carry 240V. There is no voltage on these two terminals with wires removed. It is ok to test with ohm meter.
7. Heat elements-Test heater element with an ohm meter. You will read continuityacross a good element ( 8-12 ohms is an average element ).
But darn it, I don't have a Ohm Meter....
To check the thermal fuse  - You can bypass the thermal fuse (just connect the 2 wires together) for testing purposes only.To check the thermal cut-out  - You can bypass the thermal cut-out (just connect the 2 wires together) for testing purposes only.
To check the thermostats for continuity -  - You can bypass the thermostat (just connect the 2 wires together) for testing purposes only.
To check the Element: Try removing element and physically looking at the element wire for a break in the wire.
How to take apart information for GE style dryers
How to take apart information for Inglis - Whirlpool - Kenmore dryers
How to take apart information for Maytag dryers
How to take apart information for Frigidaire and White Westinghouse
How to take apart information for Admiral, Norge, Magic Chef and Crosley
Mar 30, 2009 | KitchenAid Dryers
Whirlpool gas dryer turns on drum spins exhaust is clear and blows air but it wont ignite
  1. Changing from 3 to 4 wire hookup on a electric dryer
  2. Door switch replacement help for a common door switch
  3. Dryer basics - Venting problems and power supply
  4. Dryer basics - timers and how they work
  5. Dryer basics - power cord problems
  6. Dryer basics - dead dryer
  7. Dryer *general* repair flow chart....Click here
  8. Gas dryer smell
  9. How do dryer thermostats work?
  10. How long can my dryer vent be in length?
  11. How to change a common rear drum seal
  12. How the belt is suppose to look at the motor and idler pulley
  13. Help on replacing dryer motor  and some wiring tips for the 279827 motor
  14. Help on replacing dryer motor  and some wiring tips for the 279787 motor new25.gif
  15. Help for storing an appliance
  16. Important Disclaimer
  17. I dropped something down the lint filter area....help!
  18. Inglis, Whirlpool and Kenmore most common style dryer - how to take apart ( lint filter on top )
  19. Inglis, Whirlpool and Kenmore most common style dryer - how to take apartslide show ( lint filter on top )
  20. Whirlpool or Sears dryer with heater on the floor and four rollers for drum style - take apart helps ( lint filter in the door )
  21. Inglis, Whirlpool and Kenmore electric style dryers - no heat problems
  22. Inglis, Whirlpool and Kenmore electric element changing procedures
  23. Inglis, Whirlpool and Kenmore dryers - air flow
  24. Inglis, Whirlpool and Kenmore style dryers - noise problems....drum rollers and idler pulley information....
  25. Inglis, Whirlpool and Kenmore style dryers - belt change
  26. Inglis, Whirlpool and Kenmore dryer general motor problems
  27. Inglis, Whirlpool and Kenmore gas style dryers - no heat problems
  28. Inglis, Whirlpool and Kenmore dryers - where are my thermostats
  29. If your drum belt looks like either of these....change it!!
  30. Idler pulley slide troubles with newer Whirlpool build Roper dryer
  32. Newer style Whirlpool - Inglis - ( some ) Kenmore dryer front drum support ring install help
  33. Pilot flame help
  34. Sample wiring diagrams
  35. Test for ohm meter checking on electric dryers with no heat
  36. Taking apart an Duet or HE3 dryer for a belt change
  37. Taking apart a Whirlpool Thin twin washer/dryer to replace the belt
  38. Timers and some common Auto dry troubles and solutions
  39. What is a grounded element?
  40. Whirlpool - Kenmore dryer motor problems in the dryer with Even HeatControl....info on this is here  + new25.gifExpanded repair helps for a common "Even Heat" dryer
Mar 30, 2009 | Whirlpool LGR8648L Gas Dryer
Whirlpool Gold Ultimate Care II: No heat
didc, on a gas dryer, if the thermal fuse blows it will still rotate, but will not heat. Since this is a gas dryer, see if the ignitor is glowing. If it is, then you know the thermal fuse is good. If not, the thermal fuse may be blown or the ignitor itself and thus the reason for no heat. Catriver.7152136.jpg
Jan 01, 2008 | Whirlpool GGQ8831L Gas Dryer
Dryers Logo
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
