Where is the usb connection outlet for canon ip1700 printer
  • 3,037 Answers
There isn't one. The cable uses an adapter to make the end for the computer to be a usb connector. You just need the printer cable that it comes with.
call 1-800-828-4040 if you lost yours and they can send you a new one.
Please let me know if you need any further help, thanks
Posted on May 16, 2008
How to replace ink absorber
Maybe you can reset the absorber
Instructions
    • 1 Press the printer'sicon1.png "Resume/Cancel" button when the error message appears. This should clear the message temporarily and allow you to resume normal printing.
    • 2 Turn off the printer if Step 1 did not clear the message.
    • 3 Disconnect the printer from the computericon1.png, typically a USB cable.
    • 4 Unplug the printer from the wall electrical outlet for 10 minutes, then plug it back in. Reconnect the cable between the printer and the computer.
    • 5 Turn on the printer. Your sensor settings will reset, which should eliminate the error message.
Aug 21, 2014 | Canon PIXMA iP1700 InkJet Photo Printer
Ink absorber
Instructions
This can only be done safely once after that the printer will leak ink over what it is placed on
No imprime
Resetter canon iP 1700 and iP1300
Step 1 : Reset Hardware
  1. Turn off Canon Pixma iP1700, iP1300 Printers
  2. Hold down Resume button and press Power button.
  3. Keep holding down Power button and let Resume button go.
  4. Press Resume button 2 times then let BOTH buttons go.
  5. Green lights will flash and then stop blinking.
  6. When green lights are solid, press the Resume button 4 times.
  7. Press the Power button and the Canon Pixma iP1700, iP1300 Printers should turn off, if not, press the Power button once more.
  8. Your Canon Pixma iP1700, iP1300 Printers should respond as normal
Jul 06, 2011 | Canon PIXMA iP1300 Printer
THE INK ABSORVER IS FULL
Step 2 : Using software resetter
  1. Download Software Resetter for Canon Printers iP1300 dan iP1700 Software Resetter for Canon Pixma iP1300, iP1700
  2. Ekstrak/Unrar/Unzip the Software
  3. run GeneralTool.exe
  4. Select USB Port where the canon ip1300 or canon ip1700 installed.
  5. CLick Lock Release button
  6. Select EEPROM CLEAR
  7. Click Test Pattern 1 button
  8. Your Canon Pixma iP1700, iP1300 Printers should respond as normal.
Resetting Ink-Waste Ov
Nov 27, 2010 | Canon PIXMA iP1700 InkJet Photo Printer
Canon Pixma Ip1700 will not print, because the Ink absorber is full.
Hi there
Please under-stand at some time you will need to clean out the waste inkpads that are inside your printer or it going to be a big mess of inks coming out.
Some times the IP tools will fix it Canon Pixma iP1200, iP1600, iP2200 Resetter
1. Download software for Canon iP1200, iP1600, 2200 Printers.DOWNLOAD Service Tool Software for Canon Pixma Printer iP1200, iP1600, iP2200
2. Unzip downloaded file by WinZip, 7Zip, Izarc, etc
3. Run GeneralTool.exe
4. Select the connected USB port number from USB PORT
5. Click LOCK RELEASE, and select the applicable model name in SET DESTINATION
6. In CLEAR WASTE INK COUNTER, select MAIN or PLATEN. The selected waste ink counter will be reset. MAIN resets the main waste ink counter, PLATEN resets the platen waste ink counter.
If both the main and platen waste ink absorbers are replaced, reset both the main and platen waste ink counters
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Mar 15, 2010 | Canon PIXMA iP1700 InkJet Photo Printer
INSTALLATION OF CANON IP1700 PRINTER
If you do not have the disk you download software from Internet, follow instructions below,
Click here:Pixma ip1700 Canon Drivers and Software
A web page will open, follow instructions, select operative system etc., and click on download .
Chose to download the file in my documents when asked.
Afterdownloading,findthefile,doubleclick on the file, if you get introubles ,thenfollowinstructionsbelowto reset and reinstall:
  • Unplug printer USB.
  • Go to control panel >> installed printers in Windows and remove (delete ) any installed printer from printer list.
  • Download driver from website and run the file.
  • Follow driver installation wizard.
  • Plug back printer when prompted from installation wizard.
Note some printer does not work on Vista.
Sep 23, 2008 | Office Equipment & Supplies
I dont have a cd to install my Canon pixma iP1700 printer. Can u please help me. Thanks
iP1700
Aug 10, 2008 | Canon PIXMA iP1700 InkJet Photo Printer
Free canon ip1700 software
hi sir i need free canon ip1700 software to install my pc plz help me
Feb 16, 2008 | Canon PIXMA iP1600 Printer
37 people viewed this question
jasbo
jasbo
