Question about HP Compaq Evo n610c Notebook
Always have to change date on boot up - HP Compaq Evo n610c Notebook
  • 70 Answers
Most probably the CMOS battery is already damaged. it is the same battery like the watches is using. It's much better to bring your laptop to the nearest local computer technician, they need to unscrew your laptop to replace the battery.
hope that helps.. thanks..
Posted on Sep 15, 2010
I have a Probook 4520s checksum error on cold boot. Time and date is reset to 1979 but everything works fine after adjusting both date and time. I changed the CMOS battery and flashed the BIOS. Same...
You need to replace the small bios battery or CMOS battery if you changed it and it didn't work the battery was probably dead. Pull and test the battery. If the battery tests good yep you may have a board motherboard problem. Check the new battery first test any new battery it could be dead on the shelf always good to find out.
Oct 21, 2013 | HEWLETT-PACKARD Computers & Internet
My date is not getting set in bios
Change the CMOS battery.
If you had taken the time to post the computer manufacturer name, and model number; I would know what motherboard we're dealing with, and what type of CMOS battery it uses.
Generally the battery is a CR2032.
A type of watch battery.
Positive ( + ) side ALWAYS goes UP
Post back in a Comment.
Regards,
joecoolvette
Apr 03, 2013 | Computers & Internet
The date changes by itself no matter how many times I change it even in the bios ... sometimes it jumps ahead other times it goes back to November 2009. Happens almost every day
If the date was always changing to the same date in the past it would be a cmos battery but since you said it has also moved forward then most likely its a virus issue. Update your antivirus and run a scan sometimes this will fix the issue but often times once you are infected an antivirus scan will not fix the issue. Unless you have a way to boot into a live cd and run a scan I would take it to a local repair shop for a diagnostic.
May 07, 2011 | ASUS U50F Notebook
I have ASUS P5VD2-VM SE - Motherboard when i turn off power supply and start my pc again, it display a messege always "Cmos Checksam bad date and time not set" I replaced old cmos battery with...
Oh, you need to go into your BIOS, for that Motherboard, you should press alt+f2 while it boots up and that should load you into BIOS (or it might be called Setup). Once you're in there you need to change your Date and Time to the current date and time. Hope that helps!
Dec 14, 2010 | ASUS P5VD2-VM SE - Motherboard - micro ATX...
My PC does not boot when I press the power button on. The power comes alright but it will not boot and load files unless I leave it on for a long time and later reboot it again. This has been the problem...
You need to clear cmos usually on board is a little coloured jumper,but also first disconnect power plugs from board which come from the big psu,normally have a little clip you have to squeeze,find cmos normally 3 pins with a littl jumper move it from one set of pins to next set of 2 pins,you normally have i pin exposed,so move left or right and hold for 10 seconds make sur e you put back as it was,reconnect psu plugs ,reboot enter the bios normally Delete button or what it says on your screen normally setup button ,reset your time and date and make sure you save your settings before you leave bios page
Jan 14, 2009 | Computers & Internet
My Computer Does Not Boot
If your system is still not holding the date and time after changing out the CMOS battery, then ther is what is called a "cold" solder joint on the motherboard thjat might work, as you mentioned, after the system is warm.
However, sicne the system does boot up and operate later, it is more likely that the power supply has the issue and is not delivering power properly until it stabalizes.
Get a replacement PS, just make sure that it has at least the same wattage as the original one. You don't even have to physically install it at first, just swtich all the connections from the old one to the new one and see if the system comes up right away. It is does, then do the swap. If not, you can return it and replace the motherboard.
Jan 10, 2009 | Computers & Internet
Date and Time
the main board of the cameras as a small battery on her, and if that battery, is damaged that will hapen (losing date and time)
Jan 18, 2007 | BenQ DC2300 Digital Camera
HP Compaq Evo n610c Notebook Logo
314 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
