Question about Scotsman Ice Machine, Cuber, 1825 lb. Unit, Head Only
The scotsmand machine make ice, but quantity of the ice seems limited. The machine was descaled a month ago, no signs it needs serviced again. Could the cube sensor be faulty?
  • 4 Answers
Scotsman unit is the CME1856 water cooled
Average batch weight= 20lbs
cycle time 15-17 min
Production 1825-1695/24hrs.
Need more informaton
sensors not the issue unless there on all the time or not blinking as ice passes the infra red signal.
Remember this was a very hot summer and ice demand was high is it possible you have experianced increase volume?
Check controller for error codes and call 1-800-533-6006
Posted on Nov 29, 2010
  • 1,420 Answers
Take a can of compressed air and blow out the dust in the coil. If the coil can't get rid of the heat, it reflects in the amount of ice it produces.
Posted on Oct 05, 2010
If descale not function, how can I do?
Try reading the user manual. You can find it at: http://www.cerinicoffee.com/saeco-user-manuals-28/ or there is a video on how to do it at: https://www.youtube.com/watch?v=k6iGAQ5C8hs
May 05, 2015 | Saeco Royal Digital Espresso & Coffee...
Have a scottsmanc1448 ice machine shows codes 1 an an 2 longharvest cleaned all water sensors descaled machine works threw all cycles water flows over both curtain coils ...
ok, what you have not told me was the temp of the ice plate. If you have an inferred thermometer now is a good time to use it. what is the Temp of the plates or ice collection try. Ice will never collect if it is not below zero C. 32F my guess is it must be below 28F. you need some kind to thermometer.
Dec 09, 2014 | Kitchen Appliances - Others
My Gaggia Titanium has an ventilate problem when it is stil cold. After starting up, autotest and running pump, it appears whit message ventilate. It takes a long time steaming or hot water after the
The ventilate sign appears as an error message to tell operator that the flow of water is reduced. I can tell that the machine has not been descaled or was descaled using unscrupulous products that are labeled as descaler but they are not.
Because the sign disappears at this time after flushing water through the steam pipe, the flow restores the sensing that water is flowing normal. This "apparent restoration" of water flow is without any back pressure. The espresso function is restored for limited use.
This error code if not corrected immediately, it will not disappear and not allow any function even after flushing water manually.
The flow meter registers the quantitative flow of water as programmed for espresso.
Please descale the machine as soon as possible. before the 'Ventilate' error message stops all functions.
This is a well designed machine. Needs more attention to maintenance.
You may use the link to order our Best descaler.
Services Unlimited Inc Parts Guru
Oct 19, 2014 | Gaggia Titanium Espresso Machine
How often should you clean the ice maker?
it depends on the quality of water in your water supply. If you get scale buildup easily, you need to descale and sanitize it as often as each month, if scale buildup is minimal, descale and sanitized every 6 monthes. I always nickel safe scale remover and calgon sanitizer. If in doubt, consult the manufactures recommendations.
May 25, 2013 | Scotsman Ice Maker 600LB CM3 30inW...
Won't heat up
nosolo, i descaled my machine with water and vinegar do you think i damaged my machine? I can't even get it to pump water, when i turn my machine on, it's silent, how do i descaled it again?
May 22, 2013 | DeLonghi EC702
I am looking for a manual to de-calc and clean in Saeco Vienna superautomatica sup 018
Descaling Saeco Automatic espresso machines SAECO VIENNA SUPERAUTOMATIC MACHINES:
SAECO VIENNA DIGITAL - MANUAL DESCALE PROGRAM
1. Fill the water tank with the Saeco descaling solution. (1 bottle of Saeco descaling solution to one full tank of water.)
2. Turn on the machine. Run approximately 1 cup through the steam wand by turning open the hot water steam valve). Turn machine off and let sit for 5 minutes.
4. Repeat this procedure until the water tank is empty. Then rinse water tank thoroughly and flush the machine by running two tanks of clear water through the steam wand.
5. To clear the "Decalcify" message on the Digital model, press the MENU/OK key to go into programming mode. Scroll up or down to select the "Signal.Descal" function. Press MENU/OK. Next, the messages " Quantity Water Not Reached" and "Left Quantity" will flash. Press MENU/OK again - the message "Reset Descaling Program - Yes" will appear. Press MENU/OK again. The Descale meter is now cleared.
SAECO VIENNA DIGITAL - AUTOMATIC DESCALE PROGRAM
1. Press the MENU/OK key to go into programming mode. Scroll up or down to select the "Descaling" function . Press MENU/OK key. Place a large container under the hot water/steam nozzle. Fill the water tank with Saeco descaling solution. (1 bottle of Saeco descaling solution to one full tank of water. Refer to the instructions on the bottle).
2. Then completely open the hot water/steam rotary valve/knob. The pump starts and the descaling program begins. During this phase the pump runs at intervals and the message "Machine is Descaling" is displayed. The complete program takes about 40 minutes. Do not add any water to the tank during this phase. When the message "Descaling Finished" appears, close the hot water/steam valve. The message "Rinse Machine" will appear.
4. Remove and rinse water tank thoroughly, fill with fresh water and replace on machine. Empty the container under the hot water/steam nozzle and replace. Flush the machine by running the tank of clear water through the hot water/steam wand until the message "Rinsing Finished" appears. Exit the Programming mode by pressing "MENU/OK" Refill the water tank with fresh water.
Descaling Single Boiler Home espresso machines (HOME SINGLE BOILER ESPRESSO MACHINES)
Approximately every 3 months (depending on your use and the water hardness), clean the machine with natural citric acid based decalcifying agent.
1. Add a descaling solution into the water reservoir. Mix thoroughly to dissolve (use warm water for better results).
2. Remove the filter holder and place a cup under the group head and another cup, or other container, under the steam wand to catch cleaning solution.
3. Turn espresso machine on, turn coffee pump on and run approximately 8 oz. of solution through the brew head. Turn machine off and let the machine sit for 15 minutes.
4.Run approximately 8 oz. through the steam wand, and again, turn machine off and let sit for 15 minutes.
Repeat by allowing solution to run alternately through the steam wand and brew head. Turn espresso machine off after each cycle. Repeat process until solution has been run through.
5. Do not leave espresso machine on. Do not wait for the ready light to come on. Do not use the steam switch during this process. Do not allow reservoir to run empty!
6. Rinse reservoir thoroughly with fresh water. Refill reservoir with fresh water. Run half a tank of fresh water through group head, alternating between group head and steam wand.
Feb 28, 2011 | Saeco Vienna SuperAutomatica Coffee...
Keurig platinum only makes 1/2 cup
call customer service 1-866-901-BREW (2739)
Jun 17, 2010 | Keurig Platinum B70 Coffee Maker
The steam unit is taking FOREVER to steam a cup of milk. I have cleaned out the nozzle but it doesn't seem to help. Also, the ventilate message pops up now and again. I just had the machine serviced less...
Hi The first thing you need to do is go to your menu. Scroll down to water hardness and push the enter button. Use your up arrow and move the number to 4 if it is not already there. Push the enter button once it on 4 and then scroll up to descale machine and push enter. Have your solution (NOT VINEGAR) Citric Acid desolved in solution and put into water tank. Now open the knob for steam and let the machine do its thing. When it is all done it will say Finished descaling. Rinse out the water tank and put in fresh water. Close the knob and then reopen it again. When it finished rinsing scroll down to "Reset Descale" Push enter and chose "Yes" with the arrow and push enter. This will bring up a message when it needs to be descaled. You can also see hoew many coffee's you have made. Its just above the Descale Machine in your menu. Descale more often than Not Enough while keep your machine working well into the future.
Jun 08, 2009 | Saeco Magic Comfort Plus Espresso Machine
What Descale sign means
Start the descaling and follow the instruction the machine give you.
Best regards
/Mirran
Sep 06, 2008 | Saeco Talea Ring Plus Espresso Maker with...
Scotsman Ice Machine, Cuber, 1825 lb. Unit, Head Only Logo
159 people viewed this question
Top Scotsman Refrigerators Experts
t-stat
Level 1 Expert
john h
John Tripp
John Tripp
Are you a Scotsman Refrigerator Expert? Answer questions, earn points and help others
