Question about Whirlpool Dryers
Dryer #3397286 dryer will not spin but still makes humming noise..Before it stopped spinning was making a grinding noise while it spinned..
natengel
  • 19 Answers
SOURCE: washing machine will not spin makes loud humming noise
motor coupling needs to be replaced
Posted on Nov 05, 2007
  • 10 Answers
SOURCE: washer make a grinding noise in the spin cycle; barrel does not spin in spin cycle
check the transmission out or it can be a clutch problem
Posted on Dec 14, 2007
  • 3 Answers
SOURCE: dryer won't spin
step 1- remove the face of the dryer, then remove the cover for the fan, check to see if object is blocking the fan, if object is there , remove object, if not go to step 2
step 2- check to see if the belt is broken, if the belt is broken replace the belt.
step 3 - remove the belt from the motor and turn the dryer on, if the motor doesn’t turn then you need to replace the motor.
Posted on Jan 01, 2008
  • 1314 Answers
SOURCE: loud cliunking noise in beginning of spin then won't spin
get a flashlight and see if a foreign object has fallen down through one of the tub holes and is jamming the tub you have to look real close
Posted on Jan 11, 2008
gittos73
  • 244 Answers
SOURCE: hotpoint aquarius vtd00 dryer starts ok then slows down and stops
sounds like your bearings have gone at the back off your drum behind the small middle panel try turning it by hand if it starts scrapping straight away then u need to replace the bearings m8
Posted on Feb 08, 2008
Duet dryer is making a humming noise when cycle starts a d during
whenever i hear a humming sound in a dryer it's usually the motor or something caught in the blower wheel stopping the motor from spinning.open the door and see if you can spin the drum.if it spins by hand try this,open the door,push in the door switch with one hand,have someone push the start button while you hold in the door switch and spin the drum by hand helping it move,if it runs you have a bad motor,if it doesn't remove the bottom panel and see if the belt is broke and stuck in the motor but like i say usually it has something to do with the motor not spinning.hope this helps
Oct 21, 2013 | Whirlpool Duet Sport 6.7 Cu. Ft. Gas Dryer
Electrolux front load dryer does not start
if it makes a humming noise for a short peiod then stops and after a while it does it again the drum maybe stuck and making the motror go off on overload try turning the drum by hand and see how it spins
Jan 08, 2013 | Dryers
My Frigidaire Gallery front loading dryer seems to be out of balance. It has become louder and makes a rhythmic grinding noise as it spins. Sometimes it starts with grinding noise that stops after a...
YOUR DRYER DEFINITELY HAS A BEARING RUNOUT PROBLEM (THATS THE GRINDING NOISE YOU HEAR - THE DRUM RUNNING ON THE SIDE OF THE CABINET ) . IT WOULD ALSO GRAB CLOTHES AS YOU SUGGEST . COST TOO MUCH TO FIX = GO AND SHOUT YOURSELF A NEW ONE IF U CAN .
Jul 26, 2011 | Dryers
My kenmore dryer makes a humming noise when u turn it on n the drum will not spin
If you are hearing a humming noise and no spinning . You have a burnt motor..Do not attempt to switch it on till you fix it to prevent further damage
Mar 07, 2011 | Dryers
Leaking from bottom on spin. also makes rattling
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer2_bing.gif Repair Squeaks, Grinding, Clicking and Knocking Noise
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Jul 10, 2010 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
Dryer won't spin, but heats up - belt is okay
the motor may have seized up, or the drum bearings are shot.
Jun 19, 2009 | GE DBL333EA Electric Dryer
Dryer not spinning
it makes a humming noise..defective motor,,also you need to replace door switch...onthejob
Jan 10, 2009 | Kenmore 72802 Gas Dryer
Dryers Logo
108 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
