Question about Maytag Refrigerators
Maytag refrigerater Hi i have this mayteag refrigerater that seems to run a very long time. It seems to keep the temperature at the proper temps but i do not think it shuts off at the right time.Let say that it atarts cooling when the refrgerater temp reaches 38 and runs for abaut 45 minutes to sometimes 2 hour or more and then shuts off for about a half hour. Then it repeats the cycle all over again but this time it runs for about 45 minutes and then shuts off. What is the proper running time of a refrigerater. Sometimes it runs longer than 2 hours and i will turn the thermoustat until iy shuts off and then turn it up immidiately to the same number it was on and it will stay off for about 45 min to a hour my email is pjm47@comcast.net
  • 828 Answers
If you have an ice maker in the freezer compartment try raising the bail arm and shutting it off. It is possible that an ice maker will increase your run time.
Posted on May 16, 2008
Clean light keeps blinking and I cannot get dishwasher to start cleaning dishes. It seems to be hung up.
If it blinks 7 times, then pauses, then 7 times....over & over, then the computer control has failed to see an increase in water temperature during the last cycle. That means the heater could be out, the temperature sensor is out, the heater drive circuit is bad, there is not enough water or the water is not circulating properly. The newer models have different blink sequences that mean other things. On most models you can press hi temp wash>heated dry>hi temp wash>heated dry in quick succession to enter a service mode. All the lights will come on, then after the control clicks a few times, just press cancel & the control will be reset & you can run another cycle. If it does the same thing again at the end of the next cycle, it will need repairs.
Feb 16, 2016 | KitchenAid Dishwashers
My Fridgidaire upright Gallery freezer is freezing my food but the appliance seems to be constantly running and the temperature control on the outside is reading 29 Celsius when it obviously isn't
Hi Susan Abboud - Modern freezers have increased storage capacity and keep more even temperature that may require the compressors to run longer but use less energy. Was the unit disconnected previously for any reason? If so, freezer requires a minimum of 4 hours to cold down completely. Confirm that the temperature control is not set too cold and that the door is not being open frequently. A dirty, cracked, worn or poorly fitted door gasket can allow warm air to enter the unit causing it to have to run longer to remove the warm air. Leaks in the door seal will cause freezer to run longer in order to maintain desired temperature. Cleaned the gasket, if it is too damage then it will need to be replace. You can check and see if the door seal is bad by, placing a dollar between the gasket and cabinet. Check to see if the door is being blocked by anything stopping it from closing properly. If nothing is stopping the door then replace gasket. Keep in mind that there should also be at least 4-6 in of air space on all sides of the unit. If freezer is built in or has items stored on top that cover the unit, the can cause long run times, high temperature in the freezer and premature failure to the unit. Do not block the toe grille on the lower front of the unit. Sufficient air circulation is essential for the properly operation of your freezer, about 3 inches around the unit.
Nov 22, 2012 | Frigidaire 20.6 cu. ft. / 583 liter...
We have a 4 year old maytag a/c - M1200 16 seer unit. The compressor has stopped running several times durring the hottest time of day - the air handler keeps on running - which brings in warm humid...
It may be overheating, but chances are it has a high limit control switch which may be bad or it is overcharged with freon, in any case the limit and/or the freon charge needs to be verified by a qualified person who know the proper method's for charging and verify charge.
The hotter outside temps cause the high side pressure to rise, with a properly charged system it should operate properly even at 120 degree temps.
Aug 23, 2011 | Maytag Heating & Cooling
Bottom freezer not keeping ice cream frozen
Check out freezer temp - should be around zero degrees. Fact that ice maker is still working would indicate that the temps are at least about 10 degrees. If the door seals are tight and the self defrosting mechanism is working properly, the unit may be low on refrigerant. I had similar situation where stuff was frozen but my ice cream was mushy even though unit was running 24 hours a day.
Apr 18, 2017 | Amana BX21V
MY Maytag Wide by Side freezes in the produce drawers.
When a unit freezes in the lower drawers this is usually due to a thermistor which is not functioning properly. If you can provide your model number I can try to locate your schematic to your unit showing the thermistor that you would replace to alleviate this issue. I will await your reply as to the complete model number of your unit.
p.s if you had ice up the top of the unit as well then you would look at the damper door otherwise known as the diffuser door in some units or the control for the door as the problem area in your unit.
Thank you,
Rick
Jan 21, 2009 | Maytag 26 cu. ft. Wide-By-Side...
Maytag gas oven cycles every 20 seconds
yes it is normal . but i know your not the first to think its not , todays ovens are so tight , it only takes 10 seconds of heat to keep them at proper temp . it used to be that ovens where kept at a 3 degree sweep that is set at 350 turn on and up to 353 then off ,cool down to 350 and back on . this was a longer time off and a longer time on topday we keep to 1 degree ! 350 on to 351 off to 350 on and so on ....... so short berst of heat make for a more even oven ........ but i know i hate it too ! good luck
Jan 18, 2009 | Maytag CWG3100A Gas Single Oven
Inside Dsiplay Not Always on
Hi -
I haven't solved my problem, yet, but i have determined that it's beyond my scope and will require a pro's visit to my house.
thanks for the line.
b
Aug 17, 2008 | GE Profile PFS22 33" Artica French Door...
Maytag gas kitchen range/oven model# MGR575 ADW during preheat cycle in oven seems to keep trying to start left bank of burners over and over again. Gas can be heard flowing an ignition occurs and then...
that actually sounds to be pretty normal operating procedure unless im not understanding correctly, the unit will shout off, and cycle back on to maintain proper temp as cooks, the" top lef bank of burners" they show signs of clicking??? but not actually igniting correct??? and do they ever start to click when unit is completly off???
Apr 07, 2008 | Kitchen Ranges
Refrigerators Logo
117 people viewed this question
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
