Do not use,there was a recall instituted in 2009:
https://www.cpsc.gov/Recalls/2009/wal-mart-announces-recall-expansion-of-durabrand-dvd-players-due-to-fire-hazard
check your hoses and make sure its not getting low because when it gets low the hoses can get hot enough to expand and spit out antifreeze without overheating
You may have a bad thermostat or a weak water pump or a clogged radiator. Smell does not indicate if its hot. The gauge or coolant light might suggest its getting hot. You may have a fuel control issue that is overheating the catalytic converter which would smell or an oil leak that is dripping onto a hot surface causing a smell. You may have a real small coolant leak that you cant see that could cause this also.
Sounds as if the door switch/latch had stuck.the smell was probably a small short. try unplugging unit. But I would imagine you need door latch/switch replaced
You may have a low charge of freon, most likely about 10 ounces, as far as the musty smell that is mold from the inside of the AC air box, they make various chemical tratments to cure this issue, but once the smell is there it can be diofficult to kill the mold that causes it.
