Question about Canon imageRUNNER 5000 Copier
I have a Cannon IR5000 and need to remove the hard drive before it gets junked. How can I do this myself?
    Guru:
  • Canon Master
  • 452 Answers
Hi, look at this picture you find what you need:
Posted on Oct 29, 2010
00602-003 error
Your hard disk needs to be replaced!! E602-003 is a bad sector read on the hdd, if you restart the machine it may work for a while but it WILL come back.
You need canon part number WM2-5230-000 (not sure how you would get it) it needs to be installed in the back of the machine at the top of the main body after the back cover has been removed.. Once this is done you dilemma begins, Canon uses a program called "service support tool (SST)" which is only a canon issued program, this program is the tool used to update all the software and firmware in iR devices. This can only be connected to a 2200 machine via usb to centronics cable with a "nethawk driver" driving the cable. Then SST need to have the firmware for the 2200 series registered (it does not come together) within SST, then connect cable and turn the machine on at the switch on the right hand side WHILE holding keys 2 & 8 together, this will give you a black screen which only shows "DOWNLOAD MODE" in the lower part of the screen. Then the machine is ready to accept the data. SST is extremely touchy, so if anything is not right you will get a lovely pink screen in SST saying an error code. To correctly set up the hard drive you must first format the HDD from within SST, then install the BOOT and SYSTEM versions (boot must be "N" at the end of it's version eg. 37.44N to be a printer or a stand alone copier will have a "C" at the end. You must pick the right one or you will not be able to print (if it has a PCL kit installed in the machine).
After all Boot, system, language, fax versions are installed restart the machine, wait for a couple of minutes intil all that data is written to the HDD and it will pup up ready to go.
Apr 22, 2014 | Canon iR5000-6000-L1 PS Ver 1.0
Tip
How to Speed up a Slow Mac
Apple Mac computers can also become slow and sluggish with time and use. So here I will show you four methods to speed up your old-slow-mac.
Method 1: Free up hard drive space
You might have stored many huge video files, thousands of photos and music tracks on our Mac computer. The popularity of using solid-state drives (SSDs) of Mac computers means considerably less capacity than traditional hard drives.
1. Find the large media files on your Mac, delete the unused videos, apps, photos, etc. Or you can move all of them to an external hard drive, and remove them from your Mac.
2. Empty your trash cans, say the user account's main trash can and the iPhoto/iMovie/Mail trash can.
3. Remove junk files from your old Mac, MacClean is the way to go. It helps removing Internet junk, user junk, system junk and application junk on your hard drive.http://www.imobie.com/macclean/
Method 2. Free up more RAM
Most Macs ship with between 4GB and 16GB of RAM. If your Mac has only 4GB or 8GB RAM, the system might be running low when launching programs or loading document.
Step 1. Open up Terminal: ~/Applications/Utilities.
Step 2. Enter the command: Purge, and tap the enter tab.
Step 3. Give your Mac a minute or two to complete the process.
Open up Activity Monitor to see the before and after results, you'll find the Free size increases in System Memory.
Method 3. Kill Unwanted login items
Step 1. Open up System Preferences, and click the Users & Groups.
Step 2. Click the Login Items tab, and you'll see a list of apps that open every time you turn on Mac.
Step 3. Select the login items you want to kill, and click the "-" button to remove them.
Method 4. Clean up your desktop
1. Delete the files you don't need any more, and empty the Trash.
2. Classified the files on your mac, and move them to some folders.
3.Name the folder so that you can easily find the one you need. Why Is My Mac So Slow and How to Fix It
on Mar 19, 2015 | Computers & Internet
Whether Canon IR5000 printer can be a tool, through the com settings (data). how do I to connect the cable to the machine copies com IR5000.butuh lan similar devices or other connector?
If I understand what you are ask???? You need to know where the ethernet cable goes in to the copier?? The conector is above the main power switch on the right side of the copier.... The print funcation is a option with a IR-5000...... Do you have a ether net PCB installed???? If you do not, you need to get a new boot rom & more ram & the ether port and lastly, you need to have your hard drive flashed to print...... Good Luck
May 18, 2011 | Canon imageRUNNER 5000 Copier
How do I get the second hard drive out of a dell precision 670
Hello there. before going into the Case make sure to touch the metal
Power down the PC and remove all cables
Open the side of the Case find the hard drive you want to remove unplug the two cables connecting to the hard drive and slowly remove the hard drive from the bay you may need to UN-screw the hard drive.
put in the new drive into its bay connect both cables put the case back together connect all the cables back to the PC boot the System up and reformat the new drive .
If you need anymore help with this problem let me know, i have done it many times myself thank you and don't forget to Rate
Jan 26, 2011 | Dell Precision Workstation 670 PC Desktop
Error code E000020-0000 in cannon ir5000/6000
Main cause: The machine is not receiving toner properly because 1)The hopper connector is left disconnected. 2) The hopper motor (M9/M10) is faulty.3) The toner sensor (TS1/TS2) is faulty. 4) The DC controller PCB is faulty.
If you recently added toner, recheck that area.
Basically the copier is trying to add toner and is not getting it.
Oct 25, 2009 | Canon imageRUNNER 7200 Copier
Hardisk ir5000/ir5000i
You need to have the hard drive "Flashed" with the correct software. They come from Canon blank, you need to find a tech to flash the HD for you. If your question is if one would work in the other copier, the aswer is yes, but you need to have the printting software on that HD if you want it to print.... Good Luck.... Just for your info. you may want to ask your question in English if you want a respones from one of the techs.
Dec 30, 2008 | Canon imageRUNNER 5000 Copier
How to replace HDD IR5000??
how to clear hard disk IR 5000 and where i can find hard disk software
Dec 20, 2008 | Canon imageRUNNER 8500 Copier
Broke
turn it off, hold down the 1 & 9 keys and turn it back on. The screen will cone up blank exept for a flashing block in the top left corner. Wait, for a long long time, 20-40 min or more, do not interupt it. The block will drop followed by another one, tetris style. When it is done it will say "download mode" . When it is done turn it off and back on. If this doesnt work (and there is a good chance it wont) then you need a new hard drive, which is not a job for an end user.
May 09, 2008 | Canon imageRUNNER C3220 Color Copier
IR5000 Service Mode
Call usa cannon and ask for the help desk...they will walk you thru this
Apr 03, 2008 | Canon imageRUNNER 5000 Copier
Copier Harddrive
Remove the rear cover. The hard drive is at the top, near centre. Disconnect the connector and remove the four screws. The hard drive can then be removed from the mounting plate. New system software needs to be installed if a new hard drive is fitted to the machine in order for it to operate. It will not function without a hard drive or the system software.
Nov 16, 2007 | Canon imageRUNNER 400S Copier
Canon imageRUNNER 5000 Copier Logo
477 people viewed this question
old marine
old marine
