Had a Sharp (LC-26SB24U) TV with a no video, white screen but good audio. The Budm fix was to replace Q413. Bingo! That was my problem...a multimeter confirmed C was shorted to B so I replaced the transistor with NTE153 (as suggested) and that fixed it...video was great! All worked fine... However, after just 1 week, the TV video went out again, just like before...the White ScreenOf Death! So I removed Q413 again but it tests ok. I resoldered it back in and the TV still has a white screen with no video as before. Any suggestions? Thanks!
  • 22 Answers
Fuse F404
Posted on Feb 10, 2011
White screen with Sharp LC-26SB24U
Check and replace the T'Con board.
Mar 01, 2013 | Sony BRAVIA Televison & Video
Sharp Lc-26sb24u white screen with sound
You will get a white screen when you unplug the t-con from the main board. Doing so removes power to the LCD panel. Verify that all of your voltages from the power supply are correct. If they are, I'd look at the t-con board. It sounds like there is a problem with the t-con that is pulling down the main board.
May 11, 2012 | Sharp LC Televison & Video
My sharp LC-26DV24U is displaying a white screen only.
I have the same model Sharp TV with the same symptoms. The TV would sometimes work perfectly, then go to white screen (audio OK) and sometimes back to working perfectly again.
I saw Posts saying to check F404 and Q413 - My fuse F404 was not blown, and replacing the Q413 transistor did not fix it.
On Q413 I had about 12.4 VDC on the Emitter, 12.3 VDC on the Base and about 1.5 VDC on the Collector. My service manual called for 11.6 VDC on the Base lead. As a Test, I used a 150 Ohm resistor from Q413 Base to metal chassis ground, and that made the TV work OK.
I replaced the Q419 NPN silicon driver transistor, and now the TV has been restored to 100% proper operation.
I hope that helps someone else down the line.
Mar 27, 2012 | Sharp LC-26DV24U 26 in. LCD HDTV/DVD Combo
White screen when I turn it on and only had it for 2 years. It's a Sharp lcd tv model# LC-26SB24U. Please tell me that its a defective part, like the tv tuner signal board.
The problem is that the t-con board is not receiving signal to the logic board or there is no supply coming to the t-con board. T-CON board gets the signal to logic board to produce image in to the screen if T-CON board fails white screen is produce. Try to check if there is a bulge up in the top of the capacitor. Note before opening the back cover of your tv be sure to unplug the unit feel free to send feed back good day and best regards.
Aug 14, 2011 | Sharp LC26SB24U 26 in. LCD TV/DVD Combo
My tv screen keeps going white. It's only about three years old.
It may have failing switched 5vdc transistor that feeds the 5v to the LCD T-CON board.
Here is the service manual: http://elektrotanya.com/?q=showresult&megnev=sharp&megnev2=LC-26DV24U&kategoria=&kat2=all
It has similar to this one as shown here: http://s807.photobucket.com/albums/yy352/budm/Sharp/Sharp%20LC-26SB24U/
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Jun 21, 2011 | Sharp LC-26DV24U 26 in. LCD HDTV/DVD Combo
LC-26DV24U white screen only
The grey screen is caused by failed transistor for the switched 12vdc for the T-CON board, same as my pictures here (my does not have the DVD), but it can also be the main 12vdc itself that is bad, you will have to do some probing. Since the screen is grey, you will not be able to tell if the set really function or not. http://s807.photobucket.com/albums/yy352/budm/Sharp%20LC-26SB24U/
Here is the free service manual that you will need: http://elektrotanya.com/?q=showresult&megnev=SHARP&megnev2=LC-26DV24U%20&kategoria=&kat2=all
Please see my basic troubleshooting guide here:
http://s807.photobucket.com/home/budm/allalbums
Please let me know what you find.
Jul 15, 2010 | Sharp LC-26DV24U 26 in. LCD HDTV/DVD Combo
I've only had my LCD TV for 16 months and of course now that the 1 year warranty isn't in effect the darn TV decides to break down. The TV screen is bright white with sound. What is wrong with it? :(
This problems i fix it before,it the Tuner board the main board that take the coalax signal in to get the broscast programs it dead.Tries websites like Shojimmy.com,Ebay.com to buy a refurbish Tuner board for the replacement.Will solved this problems,i experience before.
Jul 14, 2010 | Sharp LC26SB24U 26 in. LCD TV/DVD Combo
I have a white screen I do have sound and can
YOU MAY USE RADIO SHACK TIP31 TRANISTOR PART # 276-2017 IN PLACE OF KTA1281 COST $1.79 WORKS FINE
Jun 21, 2010 | Sharp LC-26DV24U 26 in. LCD HDTV/DVD Combo
Televison & Video Logo
1,190 people viewed this question
Top Televison & Video Experts
Electro Med Services...
