Question about Electrolux EL6988A Bagged Canister Vacuum
How to fix the coupling on a electrolux oxygen EL6988
I'm looking for an electrolux oxygen repair manual
Electrolux EL7020A Oxygen 3 Ultra Canister Vacuum Cleaner
i have 2, 1powers up and all 3 lights flash change hoses from the good one that work fine and it still wont run and the three blue lights continue to flash and wont run
Aug 08, 2010 | Electrolux EL7020A Oxygen 3 Ultra Canister...
My electrolux oxygen won't turn on. Could it be the switch and can I fix it myself?
mcdevito75 here, The first thing is to make sure you are useing a live or good wall outlet. Then you can try the on / off switch a few times. If this doesn"t work it may be the switch itself. Look for an appliance repair center in your area.
Jul 23, 2010 | Electrolux EL7020A Oxygen 3 Ultra Canister...
I havea -1year old Oxygen Vacuum and the powerhead just quit.
the vacuum you have is made by eureka (cheap)
the original electrolux today is called aerus
Jun 26, 2009 | Electrolux EL7020A Oxygen 3 Ultra Canister...
9 month old electrolux oxygen vacuum just quit
my electrolux oxygen canister just quit- i think it's the sumo board and the whole fuse problem why does this keep happening over and over (my 4th time w/ this model) and where can I buy a replacement sumo board myself?
Jun 19, 2009 | Electrolux EL7020A Oxygen 3 Ultra Canister...
I have a Electrolux , EL6988 Canister Vacum, howeveer the brushes and motor will not run when turned on. I have take the plates and cleaned around the brushes, but it will not come one. The vacum comes on...
Turn the brush unit upside down, so you can see the brush roller. Then, with the brush roller positioned nearest to you, you will find the reset button close to the rear edge, near the wheel that's on the right hand side as you look at it.
Good luck! I hope this works for you. I value your feedback. Please remember to rate this response.
Feb 19, 2009 | Electrolux UltraLux 2000 Bagged Canister...
Electrolux Oxygen Ultra
The problem is that Electrolux sold a portion of the company to Eureeka, so the Electrolux you are familiar with is under the name Aerus-Electrolux. Aerus vacuums are still produced with the same high quality as always, and still are made in the USA!!!
Feb 10, 2008 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Electrolux Oxygen Canister Vac
Did you check the powerhead drive belt. Procedures for replacement are on the electrolux website and also in the owner's manual.
Nov 18, 2007 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Electrolux EL6988A Bagged Canister Vacuum Logo
224 people viewed this question
Top Electrolux Vacuums Experts
Mack Baxter
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
