Question about Canon Office Equipment & Supplies
When scanner is turned on the light starts to blink immediately and the notice that the scanner cover is open comes up. The scanner cover is not open and the light continues to blink even if the machine is turned off/on and the computer is restarted.
  • dianne2889 Sep 15, 2010
    I do not see the toggle switch you are referring to. This is the DR-2580C model. Can you tell me where the switch would be located?
  • dianne2889 Sep 16, 2010
    Was able to get scanner light to stop blinking by using a paper clip as you suggested! Now the rollers aren't working. Any idea why they would not be grabbing the paper and unable to read that there is paper to be pulled in?
  • 600 Answers
Please check the cover switch, you can find that by looking/running around the scanners edges, it would be a toggle like switch, that is actuated or press by a notch by the scanner cover itself.
The notch or the switch trigger should reach in the hole where the switch is located, if it doesnt, the error would be like this, it will say the cover is open yet you have closed it.
If you have located the switch hole, try operating the scanner with you pressing the switch, with the use of a hairpin or paper clip, just dont press on it too hard, very light press would suffice. if it operates with that procedure, and clears the blinking, the notch or actuator on the cover may not have been reaching the switch.
you can do the trick by gluing a piece of pin or clip just long enough to reach the switch on the hole.
If you are techy enough, you can try to copy the shape of the notch and try attaching it.
If you want to, you can also open up the scanner, and try replacing the switch with a taller button.
hope that clears your problem.
Posted on Sep 15, 2010
  • 6 more comments
  • manuel oliva
    manuel oliva Sep 15, 2010
    If you are using that model, it is situated right at corners on the insides of the scanner, to where the lid flaps or cover meets,
    try these steps,
    open the upper lid:: do that by pressing the "OPEN" tab on the unit.
    pull up the upper part slighlty, then close it again, pressing down with slight force until it clicks to place.
    if you are using the flatbed addin, refer to its user manual
  • manuel oliva
    please download this
    http://www.uploadmb.com/dw.php?id=128456...
    and go straight to page 24, you need adobe reader software to open this file.
    you can download adobe software here
    http://get.adobe.com/reader/
    page 24 is about the straight path vs coming out the top - why that page?
    I used the open lever and see the small gray notch buttons on the sides. pressing on the top/sides to make a better connection doesn't stop the blinking. it is definitely clicking into place - but still blinks.
  • manuel oliva
    If thats the case your scanner need servicing, the sensors and actuator switches may require replacement or repair. the situation simply tells that the scanner mechanism may have damages in the sensors, and no user can service that,because of the sensitivity of components inside.
    Can you tell me where I would be able to get service for the scanner?
  • manuel oliva
    The best place for it be repaired, would be on the first on the list, is where from where have you bought the scanner from, they would be happy to help you out.
    Next place is a store or a shop which is accredited or certified by your scanner manufacturer, which in your case is canon, just look for a shop bearing the canon logo accreditation.
    Last place would be the canon global support which is here.
    for global
    http://www.canon.com/
    for USA
    http://www.usa.canon.com/cusa/home
    http://www.usa.canon.com/cusa/about_cano...
    depending on your location, you would find the nearest canon site to where you can bring or phone in your scanner for repairs.
  • manuel oliva
    Or you can call
    1-800-OKCANON
  • manuel oliva
    manuel oliva Sep 16, 2010
    As you have done, the lights went off, and stop blinking with the step I told you, simply means the sensors are jammed or non operational, try leaving something that presses that switch(without falling off) and perform scanning in the normal way.
I have a 2003 Chevy trailblazer I have a couple problems. First the car sometimes does not start. I can start it a few times a day and go places and then later on it will not start. All lights on dash will...
Best thing go to www.reliable-store.com they have got books on every vehicle and also how to service/repair it,
service/repair/owner's/maintenance manual with
parts info, fuse box, gear box, PCV, torque specs,coiling, wiring diagrams, electrical diagrams, fuse diagrams, error codes, etc everything
Worth it
Mar 15, 2018 | Cars & Trucks
Entrance light on Lift Master garage door opener won't stay on when door is opened ?
Light Feature
Activate the Light Feature
  1. Close the garage door.
  2. Start with the garage door opener lights "ON".
  3. Press and hold the light button for 10 seconds. (Upon pressing the light button, the lights will immediately turn off and come on 10 seconds later.)
Deactivate the Light Feature
  2. Start with the garage door opener lights "OFF".
  3. Press and hold the light button for 10 seconds. (Upon pressing the light button, the lights will immediately turn on and go off 10 seconds later.)
Light Timer
Press the Light button to turn the opener light on or off. It will not control the opener lights when the door is in motion. If you turn it on and then activate the opener, the light will remain on for 4-1/2 minutes. Press again to turn it off sooner. The 4-1/2 minute interval can be changed to 1-1/2, 2-1/2, or 3-1/2 minutes as follows:
  1. Press and hold the Lock button until the light blinks (about 10 seconds).
  2. A single blink indicates that the timer is reset to 1-1/2 minutes.
  3. Repeat the procedure and the light will blink twice, resetting the timer to 2-1/2 minutes.
  4. Repeat again for a 3-1/2 minute interval, etc., up to a maximum of four blinks and 4-1/2 minutes.
Oct 20, 2017 | Building Materials
My light doesnt come on when i break the sensor....and my learn light blinks none stop
Random blinking of the learn light is normal.
To have your lights come on automatically when you walk into an open garage, you must START with the lights ON. If you don't want that feature and you want to turn it off, you must START with the lights OFF.
To turn the feature on, turn the lights on manually with the wall switch, then press and hold the LIGHT button for about 10 seconds until the motor unit light bulbs flash. Now, if the light bulbs are on, manually turn them out and then walk out through the open door. The light bulbs should come on.
To disable this feature, start with the light bulbs OFF and everything else is the same.
Feb 17, 2012 | Sears Craftsman LiftMaster Chamberlain...
Scanner error power on power off message come
the scanner under the glass has a problem. turn the machine on with the top cover open and see if you notice the scanner moving either to the left or right.
Mar 05, 2011 | HP LaserJet 3030 All-In-One Printer
Samsung HLN507W turns on for about one minute then shuts off, three blinking lights stay on in front. It is not the lamp, nor the blue lamp cover switch for sure. I unplug it and immediately turn it on. ...
Samsung HLN507W turns on for about one minute then shuts off, three blinking lights stay on in front. It is not the lamp, nor the blue lamp cover switch for sure. I unplug it and immediately turn it on. It always does the same thing: comes on for 1 minute, then powers down - there is no wait time in between unplugging and powering on. All fans seem to work and I cleaned the dust out of it. Help.
Nov 04, 2010 | Samsung HLN507 50" Rear Projection...
I have properly connected my HP Scanjet 2400 scanner with my system and the appropriate software was successfully installed, the light is blinking and when we try to scan, it tries to start, but it...
sometimes the power management causes the scanner to act up or fail altogether.
Try: Solution: Disable power management on the USB hubBy default, Window XP tries to disable USB port when the HP Scanjet scanner is not in use to save power. The scanner fails to wake up when called. To fix this problem use the steps below:
  1. Click Start , right-click My Computer , then click Properties . The System Properties window will open.
  2. Click the Hardware tab, then Device Manager . The Device Managerwindow will open.
  3. Double-click the Universal Serial Bus controller branch to expand it.
  4. Right-click USB Root Hub , then click Properties . The USB Root Hub Properties window will open.
  5. Click the Power Management tab.
  6. Remove the check from the Allow the computer to turn off this device to save powercheck box.
  7. Click OK , and close USB Root Hub Properties window.
  8. Close any other open windows.
Aug 28, 2010 | HP ScanJet 2400 Flatbed Scanner
Kodak i40 error e7
E6 means the scanner cover is open .
Please check for any open covers or any movable parts which is not closed.
Feb 26, 2010 | Kodak i40 Path-Through Scanner
My girlfriend has a 1/2 hp Craftsman garage door opener (model 139.5398511) which operates fine when cool but after several uses or later in the day the opener only partly opens the door (the height varies...
hi,
there is little chance for the board to be affected by the melting of plastic covers of light. if the circuitry is damaged by the heat, you'd notice the problems immediately, if it is working fine now, then there is no chance for this incident to affect the working in future.
cheers
Jul 22, 2009 | Sears Craftsman LiftMaster Chamberlain...
Lexmark x2500
There 3 light on the printer that able to indicate to user when problem occur. Find your printer error accordingly as below and may solve your printer problem.
1st button light blink rapidly = the printer may be out of paper, so load more paper and press the 1st button itself to continue. Or may be paper jam is occur, so clear the paper jam and press the 1st button light itself to continue.
If 1st button light blink slowly = mean the cartridge carriers are stuck, so raise the scanner unit and remove any object blocking the path of the cartridge carrier, make sure the cartridge are closed and installed properly, then lift the scanner unit, gently push the scanner support towards the cartridge carriers, and carefully lower the scanner unit until it is completely closed. After that press the 1st button itself to continue.
If 2nd LED light blinking = the color cartridge need to be replaced soon.
If 2nd LED light is ON = the color cartridge need to be replaced immediately.
If 3rd LED light blinking = the black cartridge need to be replaced soon.
If 3rd LED light is ON = the black cartridge need to be replaced immediately.
Hope this help.
YBC (/\)
Feb 05, 2009 | Lexmark X2500 All-In-One Printer
Powers on immediately powers off
ok well there is somwhere to start i would see if you can get it to take a charge ok and if it does than try to start it without the ac power on and see what it does if it wont take a charge your battery may be bad or your charging circuit may not be connected correctly ok lrt me know best regards mike
Aug 27, 2008 | Dell Inspiron 5160 Notebook
47 people viewed this question
old marine
old marine
