Question about Whirlpool ED2FHEXN Side by Side Refrigerator
Whirlpool sideby side
Area between refrigerator and freezer ,Just the face where door seal hits gets very warm to touch. Ref. is about a year old and is the water and ice thru door model.
  • hillsgirl May 21, 2008
    I can't belive it....I just noticed this exact same problem with my Whirlpool Model ED5RHEXNL a few days ago. I'm worried that this could be a fire hazard of some sort. But you seem to suggest this is just normal, I just can't figure out why I hadn't noticed it before now as the fridge is about 2 1/2 yrs. old.
    Genius:
  • 1,073 Answers
This is normal this is the mulliion heater , it is a loop of tubing from the high side of the condenser it is used to keep moisture from forming between the doors of the ref, cool it will not be
but is cool how the manufacture thought about doing this
Posted on May 17, 2008
Old whirlpool freezer door left slightly ajar.light on inside.door won't seal. Rubber on door warm.what can I do?
if you replace the door seal and it still doesn't work then that is a dilemma you have to face. If you get a technician out to check it out and all you need is a door seal--same problem
Is the compressor motor still running then there is a good chance that a door seal will fix it
flip the coin and make a dicision
May 03, 2015 | Whirlpool Refrigerators
Freezer too warm, and i feel heat on the door seals
The door seals warm is from the mullion heater that minimizes moisture from forming in that area, under working conditions. You need to provide more information.... What did you see that made you defrost it 3 weeks ago..
Nov 27, 2013 | Kenmore 53542 / 53544 Side by Side...
Water dispence slow
do you know if it is a whirlpool made model, 27ft french door, ice maker in ceiling, they had issues with a seal between ice compartment and ref side- leaks freezing air to water tank area, freezing tank. other wise if its not the filter -then water flow to unit. ck where it connects to ref, if good( should have steady stream with press. replace ref valve if bad look at your valve in wall or at sink.
Sep 14, 2012 | Kenmore Refrigerators
I have a Whirlpool GX5FHDXVY, only 3 months old, the freezer drawer does not seem to be sealing, it will be several days before I can get a repairman out, is there some easy way to fix this? I don't see...
May sure the drawer is installed correctly. Then with a hair dryer gentle heat the seal and adjust it to touch the cabinet. use a pen or pencil to gentle adjust it to touch the cabinet. One it is touching and will stay allow the door to stay in that position until the heated area of the gasket is cooled and can retain its shape.
Dec 31, 2017 | Whirlpool GX5FHDXVY Stainless Steel (248...
Whirlpool sideby side ref. ED5FHGXKQ02 condensation on walls of freezer causes accumulation of water on freezer floor
Most times that is a defrost drain blockage behind the rear wall of your freezer back panel. Sometimes the door seals allow some moisture to accumulate if air is drawn in through the seals leaking or the door to the dispenser is stuck open. But when you say it has accumulated in a pool of ice on the bottom of the freezer then the drain is blocked. I'm going to send you to some links and I want you to read through most of what is said and just use the parts the refer to your refrigerators problem, Sea Breeze
Sep 07, 2009 | Whirlpool ED5FHEXMQ Side by Side...
Sideby side whirlpool- 3 years old- ice maker stopped working 3 weeks ago. today everything in freezer is melting
Verify condenser fan is running. Check evaporator coils for frost. IM will quit if freezer does not go below 5 degrees. The cooling was slowly dieing and finally warmed enough to defrost the food.
Eric
Jul 16, 2009 | Refrigerators
Freezer quit freezing
HI,
you can try this suggestion first.
if the compressor is running your ref. should be getting cold. Their is a defrost timer but when it is in defrost the compressor shuts off. I think you do have a leak.
any further question let me know.
thanks,
Mar 22, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Front metal piece that the seal goes against - between freezer and fridge
ED5VHGXMQ10 Whirlpool Fridge
I have the same problem. Too hot to touch between the freezer and refrigerator door. Is
this normal?
Jul 07, 2008 | Whirlpool GS6NBEXR Side by Side...
Warm to Hot molding that seals the doors
The heat in door frame is normal but undetectable when ref at normal temp. Definitely cooling problem. Google ref not cold enough to get help to solve problem. Never use any oil for it will not help also health problem if not approved to be used around food. Fan motor must be replaced for it will just keep stopping.
Mar 31, 2017 | Kenmore 52642 / 52644 / 52649 Side by Side...
Whirlpool ED2FHEXN Side by Side Refrigerator Logo
79 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
