Question about Dymo LetraTag QX50 Thermal Label Printer
My printer will not print. I have cleaned it, and you can just barely see what I have printed. Does it need a ink roller?
  • 863 Answers
This thing doesn't use ink. It uses thermal transfer onto the paper. Meaning it burns the letters onto the paper. You probably got bad paper cartridge or wrong brand. Try inserting a new cartridge.
Posted on Oct 11, 2010
When the paper prints, the color is missing in areas. It looks like a streak mark down the page. The black ink is full color, they yellow and cyan have a white, non-printed streak down the center, and...
Inspect the rollers for dirty or damaged surfaces. Clean up any loose toner or other debris in the machine. Note: avoid touching any roller with bare skin; especially in the fuser section or the photosensitive drum in the toner section. Skin oil can cause poor print quality or premature degradation of the roller surface.
Jul 06, 2017 | OKI C3200n Led Printer
Black ink leaked on inside of printer.
try to replace the defective cartridge by a new one and see printing test result
Nov 18, 2011 | Canon PIXMA iP6700D InkJet Photo Printer
Black ink won't print and I just changed the ink
Try using the photo paper option instead of the plain paper option.
I was using plain paper but, selecting the plain paper option...I could barely read the print. The photo paper option worked great!
Hope it helps!
Nov 14, 2011 | Brother MFC 6490CW InkJet Printer
Poor print quality, but only on certain lines
Pull out the cartridges. Wet a q-tip with alcohol and clean the foil contacts that are in the spaces that the cartridges just occupied. Use a flashlight to better see what you are doing. See if that helps.
And what kind of lines are you getting on the printout? Vertical?Horizontal? Those could be ink that is on the feed rollers.
Jul 17, 2010 | HP Officejet 6310 All-In-One InkJet...
When printing, a black stripe is printed on the back side of the printed pages (about 1/4'' wide, running from top to bottom). The ink strip bleeds through to obscure printed side. Any suggestions?
You need to have the exit rollers cleaned at a shop, and a mylar strip added to keep that from happening again. It's the ink from the cleaning station backing up thru the exit rollers.
Dec 03, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Ink marks on paper
seems that the Print roller needs a cleaning. get it cleaned as there might be some extra ink on the roller.
Hope this Help.
Cheers!!!
Jul 16, 2009 | Lexmark E330 Laser Printer
Hp officejet, pro k5400 printer,when printing i get lines top to bottom on print,about 1 inch apart,tryed print head cleaning,changed the cartridges .need help ,top to bottom,only on...
That is ink or dirt on the rollers, you need to clean them by lifting the lid, as if you were putting new ink in, and wipeing the rollers that the paper runs through.
Jun 09, 2009 | Canon PIXMA iP5000 InkJet Photo Printer
Ink blots deposit onto feed rollers which in turn transfers to all new prints
Most likely you have a leaking print cartridge (toner cartridge). Does it have the same problem if you use the Manual Bypass tray?
It could also be a worn fuser sleeve that is causing the print defect...the fuser would need replaced in that case.
Sep 30, 2008 | HP LaserJet P2015n Printer
Print quality is poor
if you replace the black ink cart with an original one then it's the print head
Solution: Cleaning the Print Head - C555 / C560 / C635 / C530 / C545
Untitled Document Follow this procedure to clean the BJ cartridge print head:
1. Press c755funckey.gif 2. Press c755cleankey.gif 3. Use c755down.gif or c755up.gif to select the [HEAD CLEANING]..
4. Press c755set.gif.
The MultiPASS cleans the print head.
Feb 12, 2008 | Cannon MULTIPASS C530 Printer
Dymo LetraTag QX50 Thermal Label Printer Logo
119 people viewed this question
Top Dymo Office Equipment & Supplies Experts
Jax Planet
Jax Planet
jdthefixer
Are you a Dymo Office Equipment and Supply Expert? Answer questions, earn points and help others
