Question about Whirlpool LEQ9858P Electric Dryer
In the last few weeks on 3 occassions when the cycle is complete I open the dryer and there is moisture on the inside of the door and on the drum? Why is this happening
    Master:
    Sergeant:
  • 449 Answers
Check for a blockage in your exhuast vent
Posted on Sep 15, 2010
Dryer works OK on timed dry but doesn't dry the clothes in Auto dry.
In some dryer's the control panel relies on a thermistor rather than a CYCLING thermostat to regulate the drum's air temperature by monitoring the component's resistance changes; resistance goes down as temperature increases and up when temperature decreases. Once the drum's air temperature reaches a certain level required to dry clothes, the control panel shuts off the heater. The panel will turn the heater on again and begin another heating cycle when the thermistor indicates that more heat is needed to keep the air temperature constant inside the drum 9 this is why in some cases the dryer will operate at lower cycles like gentle or low heat but not at higher settings?)
Lastly check your moister sensor. ( located inside the dryer door usually) Especially if machine seems to shut down early and clothes are still wet.
Test with a meter at room temperature and it should show continuity.
A failed moisture sensor will affect the dryer run time in the automatic moisture sensing cycle but it will not affect the heating of the dryer or the timed cycle. Which are reflected by the thermostats.
Read more :
http://www.ehow.com/info_12203962_check-dryer-thermistor.
GOD IS So GOOD !!!! AND THAT'S WHY MY ADVICE IS FREE
How to Check Dryer Thermistor eHow
Jan 07, 2016 | Dryers
Auto cycle does not work timed cycle works fine
Read more :http://www.ehow.com/info_12203962_check-dryer-thermistor.html
Apr 15, 2015 | Kenmore Dryers
Dryer works fine on timed cycle does not work on auto
Why does my whirlpool senseon dryer start when i disconnect the thermistor wire but then shuts off after a minute?
Apr 08, 2015 | Whirlpool Dryers
Dryer shuts off after 5 seconds then beeps 3 times
Check the thermal cut off, the cycling and the hi limit thermostats.
For continuity or OHMS. If no ohms or resistance they need replacement.
Apr 03, 2015 | Frigidaire FARE1011MW Affinity High...
Gas dryer does not dry in "timed Dry" setting
Mar 06, 2015 | Whirlpool LGB6300 Gas Dryer
GE dryer runs but only heats on timed cycle not the other 2 cycles.
Feb 17, 2015 | GE Dryers
My dryer heats but doesnt stop wben timer is set
Read more :http://www.ehow.com/info_12203962_check-dryer-thermistor.htmlGOD IS So GOOD !!!! AND THAT'S WHY MY ADVICE IS FREE
Sep 11, 2014 | Dryers
Will broken moisture sensor cause dryer not to heat
Aug 18, 2014 | Maytag Dryers
The drum light is out in a GLER104FSS
first, unplug machine. open the dryer door, Remove light protector cap. (pry with flat screwdriver), unscrew bulb and replace a new one
tadamm!! :-)
Mar 30, 2014 | Frigidaire GLER104FSS Gallery Series 27...
Whirlpool LEQ9858P Electric Dryer Logo
102 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
