Question about Toshiba Satellite U205-S5034 Notebook
How to replace the built in wireless - Toshiba Satellite U205-S5034 Notebook
  • 734 Answers
This step by step disassembly guide with photos will help you perform your replacement.
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-U205-U200/disassemble-laptop-1.htm
Best Regards,
Marcus
Posted on Sep 15, 2010
Wireless antenna or wireless router
Did your ISP Boingo supply you with a DSL or cable modem with a built-in wireless router? If only a DSL or cable modem is supplied and you wish to connect to the Internet by wireless then you need to connect a wireless router to this DSL or cable modem.
You can connect to the Internet using a LAN cable from your laptop to the DSL or cable modem.
If your laptop as a built-in wireless card you can to the Internet via the wireless router.
If you laptop does not have a built-in wireless card then you can install a PCMCIA wireless card into the card slot of your laptop to the Internet via a wireless connection.
Nov 01, 2012 | Toshiba Computers & Internet
Tip
PS3 models, and what they can do
The 20 Gig
Pros
Full PS2 Compatibility
HDMI Port
Pretty good Cooling System
4 USB Ports
£220
Cons
Super Small HDD
No Wireless Card
Discontinued (They don't make them any more)
The 40 Gig
Pros
£250
HDMI Port
Built in Wireless
Medium HDD
Amazing, New Cooling System
Cons
2 USB Ports
Cannot play PS2 Games
The 60 Gig
Pros
SD Card Slots
4 USB Ports
Built In Wireless
Big HDD
HDMI Port
£280
Cons
The *OLD* 80 Gig
Pros
Massive HDD
4 USB Ports
Limited PS2 Compatibility
SD Card Slots
HDMI Port
£280
Cons
The *NEW* 80 Gig
Pros
Massive HDD
£250
HDMI Port
Built in Wireless
Cons
NO PS2 Compatibility
The 160 Gig
Pros
Mammoth HDD
HDMI Port
Built in Wireless
Cons
£350
on Jan 18, 2010 | Video Game Consoles & Games
My Dell E1505 won't allow me to go wireless. My
Ideally, see if we can isolate the issue.
Disable the built-in antenna.
Try connecting to the wireless via a USB wireless antenna. (hopefully you can borrow one).
If you can connect, then I would say you need to replace the built-in antenna. Or you could keep using the USB antenna.
Good luck
-Carlos:
Jan 25, 2010 | Dell Inspiron E1505 Notebook
Wireless connection wont work
To check if the wireless card is bad or OK.
Go to Control Panel - Network Connections - Is the wireless network connection listed and if so is there a red X on this connection?
If so, right click on the wireless and click Repair - this may fix your problem, it forces the wireless router to issue the wireless card with a new IP address.
If it doesn't fix the problem then go to Control Panel - System - Hardware tab - Device Manager - scroll down to Network Adapters and expand and check your wireless card, is it Working and Enabled?
If has a yellow ? against it or not working then reinstall the wireless card driver.
If the wireless card is built-in check the BIOS to see if the wireless card is enabled, if not enable the wireless card and repeat the above steps.
If this doesn't fix your problem then the wireless card is faulty and you need a new wireless card. You can get a PCMCIA wireless card to replace the faulty wireless card. If the wireless card is built-in then disable the faulty wireless card in the BIOS before you install the new wireless card.
Oct 11, 2009 | HP Compaq Presario 2200 Notebook
Laptop states wireless adapter not installed and configured? worked before.
Oct 11, 2009 | Gateway (802.11usb) Wireless Adapter
Is a toshiba sat 4100xcdt wireless compatable
hello,
yes it is Wireless Compatible" ie external wireless car" it doesnt have an internal wireless card
Sep 26, 2009 | Computers & Internet
Wireless network adpater problem
This model normally came with wireless standard. If not, then you can add any PCMCIA wireless card from Wal-Mart, etc.
If you need a replacement for the built in one, try HP parts at partsurfer.hp.com
May 18, 2009 | HP Compaq Presario V2555US Notebook
Linksys wireless notebook adapter 2.4 GHz??
Since your Toshiba has a wireless card built in, you wont derive much benefit from using it.
It is basically there for people who don't have built in wireless cards.
Jan 19, 2009 | Linksys WPC54G Wireless-G Notebook Adapter...
Wifi issue
Hi!
Check with your laptop's manual or specification sheet if it came with a built in wireless adapter. If it does, then you do not need to use a wireless adapter. All you have to do is to configure the wireless utility of your laptop to connect to your preferred wireless network.
You can also check Device Manager to check if there is a built in wireless adapter. Assuming you are using Windows XP - Go to Control Panel > System > Hardware > Device Manager. Look for Network Adapters. Check if there is anything under Network Adapters that says "wireless" or 802.11A/B or G. If there is, then again you do not need to install a wireless adapter.
Once you verified that there is a built in wireless adapter, just configure the wireless adapter utility to connect wirelessly to you preferred network.
Good luck and have a nice day!
Sep 30, 2008 | Compaq Presario 700 470024-192 Notebook
Laptop
As long as your wireless equipment broadcast its info automatically, any laptop that has built in wireless b/g should be fine.
Just make sure that you check the specifications on the laptop that you choose to buy and make sure that it has the built in wireless.
Thanks
Jul 24, 2008 | Computers & Internet
Toshiba Satellite U205-S5034 Notebook Logo
150 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
