Question about IBM Computers & Internet
I have a 2887 MQ5 thinkpad IBM Laptop, One of my key on the board was broken so I attached an external keyboard with the help of usb port. Now the broken key is repaired and when I started using the inbuilt keyboard some of the keys when pressed gives a different input than those imprinted on the keys.What should I do?
  • 72 Answers
Replace the strip of the keypad of ur laptop
Posted on Sep 15, 2010
My laptop omlet to conect a phone charger dosent work enymore
Good Day!
maybe you just accidentally disable the usb port, so that you cant able to char your phone.
Mar 04, 2013 | IBM ThinkPad T40 2373 Notebook
How do i switch to external monitor
Virtually all IBM and Lenovo ThinkPad and ThinkCenter laptops allow you to hook up an additional monitor or projector to the computer. When you add an external monitor or projector to your notebook, you can choose to view the display on the computer, on the external device, or on both the laptop and the external monitor or projector at the same time. Toggling between viewing devices is as simple as pressing a couple of keys on the keyboard.
Shut down the laptop. Plug the VGA monitor cable from the external monitor or projector into the blue VGA port on the back of the computer. Turn on the external monitor or projector first, and then the Lenovo laptop. Allow the notebook to boot into Windows normally. Press the "Fn" and "F7" keys at the same time to switch the display from the laptop to the external monitor or projector. Press the "Fn" and "F7" keys again to enable the display on both the laptop and the external display device. Press the "Fn" and "F7" keys again to display screen contents only on the laptop LCD. choose support you need http://www-307.ibm.com/pc/support/site.wss/MIGR-54305.html http://www-307.ibm.com/pc/support/site.wss/MIGR-4YQHUC.html enable tv out on thinkpad http://www-307.ibm.com/pc/support/site.wss/document.do?lndocid=MIGR-58625
Feb 13, 2013 | IBM Lenovo 3000 N200 PC Desktop
I just bought an ASUS notebook but the USB cannot read any device what do i do?
Hi,Some USB devices are not APM/ACPI friendly and may not operate properly after resuming from Standby or Hibernation. Some of these steps may not apply to your computer. Test the attached USB device after performing each step.
1. Verify that a USB port and an operating system with USB support are being used to attach a USB interface external device to a ThinkPad system.
Note: The following is an example image of a ThinkPad system USB port
USB port
2. Verify that the latest BIOS and embedded controller for the ThinkPad system has been installed.
View the latest BIOS files for all ThinkPad systems(-307.ibm.com/pc/support/site.wss/BMOE-3VAM8Y.html)
3. Verify that USB is enabled in BIOS.
* For ThinkPad A, G, R, T, X and Z series systems
1. Turn on the computer.
2. While the "Press F1 for BIOS Setup Utility" or "To interrupt normal startup, press the blue Access IBM button" message is displayed at the lower left area of the screen, press the F1 key, blue Access IBM, or ThinkVantage button.
3. Select Config and then click USB. The window should list USB BIOS support as [Enabled].
For ThinkPad 600, 600E, 770, 770E/ED, 770X, and 770Z systems
1. Press and hold the F1 key and then turn on the computer. Hold the F1 key until the Easy-Setup menu appears. If a password prompt appears, type the correct password.
2. Select Config.
3. Select Initialize and then click OK.
4. Click Exit, click Restart, and then click OK to restart the system
4. Verify that the USB device and any required drivers were installed in accordance with the manufacturer's instructions.
This may require removing the USB device and the drivers, and then reinstalling the USB device and the latest drivers.
5. Verify the USB device works on another machine, if available.
6. Verify another USB device, if available, works on this machine.
7. Verify that the USB device is USB 1.1 or 2.0 compliant.
Plugging specific USB 1.1 compliant devices into a USB 2.0 compliant port will cause an error message dialog box to appear. That dialog box details that a non-high speed device has been attached to a high speed port. The device should function normally, but at a slower speed than if a 2.0 device is attached to 2.0 port. Most USB 1.1 devices will function normally in USB 2.0 ports.
8. Verify that external power is attached if required.
Some USB 2.0 devices will require additional power from external sources or an additional USB port to function correctly in USB 1.1 compliant computers.
9. Verify that the latest Microsoft Windows Service Pack has been installed for the operating system installed on the computer.
There are updates and fixes to USB 1.1 and USB 2.0 available in Service Packs.
10. If an operating system was installed from a retail CD, then refer to installing USB 2.0 support on ThinkPad systems.
11. Test the USB port for errors.
Run the PC Doctor diagnostics for all current ThinkPad systems. PC Doctor for DOS is available by pressing the F11 key or the blue Access button during startup to access the predesktop menu area. If these methods are not available for your system, then PC Doctor for DOS may be downloaded. This DOS version requires two or more floppy diskettes depending on the ThinkPad system.
12. If these steps have not solved your problem:
Refer to "Need more help?"
You could also try downloading an updated/fresh copy of the drivers for my specific model notebook from Asus's web site and just reinstall over the old ones.
And if you don't understand much about it, i would advice you take it back from where you bought it from and get a replacement if it's on guarantee...
Thanks for using fixya....
Nov 01, 2010 | Computers & Internet
Does ThinkPad R51 2887-MQ5 support wi fi? how to enable wi fi?
YES ThinkPad R51 2887-MQ5 supports wi fi .
For that make sure wireless network adapter driver installed in laptop.
For that right click on my computer icon thne click on proeprty then hardware ->device manager.
It shows all driver in list.
Make sure wireless driver is there and Enable to.
Make sure WI-FI switch is turned on in laptop.
Then right click on my network places and then click on proeprty you can see your wireless network adapter there then right click on it then click on "view available networks".Then connecrt.
If you need driver for your laptop you can download from below link.
click here
Let me know if you need more assistance.Thanks.
Nov 08, 2009 | IBM ThinkPad R51 Notebook
Work with an external numeric keyboard
I'm afraid that is not possible. The only way to overcome this is to get a full size USB keyboard and plug it into the laptop's USB port and type using the full size keyboard.
Sep 01, 2009 | IBM ThinkPad R52 Notebook
I want remove & fix the new key board 4 my IBM T43 lap top , Kindly send me any demo how to remove & fix the key board
Hi there here is the instructions for replacing the keyboard of your laptop.Please note: dont forget to take the saftey precautions before opening your laptop.Like disconnect the powercord then remove the battery.
http://www.ehow.com/how_2093745_replace-ibm-thinkpad-keyboard.html
May 12, 2009 | IBM ThinkPad T20 2647 Notebook
I Require an Audio Driver for Intel Motherboard, Model No. 82845GL/GV, I CAN'T FIND IT ON THE INTERNET. PLEASE PROVIDE ME THE LINK to DOWNLOAD.
can you solve my problem my problem is that i have one ibm laptop computer type 2887-MQ5 S/N L3 -AKHHZ 05/12 I HAVE NO ANY DRIVER HOW CAN I GET MOTHERBOARD DRIVER CD
Mar 16, 2009 | EliteGroup P4M800PRO-M478 Motherboard
Can i connect a presario v3500 laptop to an external momitor. @I think the display inverter is gone and i need to get some files off the lap top for work.
Yes, connect the external monitor to the port it corresponds on the laptop, usually the blue port. When you boot the computer hit the FN key located on the bottom right hand side of your keyboard and the LCD/CRT key i believe this will be the F4 key located on the top part of your keyboard this should activate the external monitor.
Tang
Feb 23, 2009 | IBM ThinkPad T23 2647 Notebook
Computers & Internet Logo
74 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
