Which of the following is a primary memory? hard disk ram rom cd floppy
  • 70 Answers
Ram rom
Posted on Sep 15, 2010
I have k8-upgrade-NF3. I tried to connect two SATA CD-ROM to SATA1 and SATA2 ports but the computer restart constantly. The domada is: i can connect cd-rom and cd-burner on SATA1 and SATA2 matherboard?...
you need to change the BIOS setup. Go to the booting menu change the arrangement of your hardware.
1.Primary Disk (Hard disk) 2.CD/DVD ROM 3. Floppy 4.others
then save and exit. Your PC will reboot and MUST detect first your hard drive to proceed to your desktop..
I hope it will help you..
May 21, 2011 | Asrock K8UPGRADE-NF3 Socket754/nForce3...
Tip
How to do Fast and unattended setup of OS
Here I have an Idea for primary setup of a large lab quickly. Suppose you have to setup a lab where have more than twenty or thirty system but must setup it quickly. At that time if you don't have enough CD Rom drive or not enough OS installer CD then the task will take a long time. To save time at the same moment I like to prepare an unattendent operating system installation. Before this task I must check for presence of some requirement. Verify for unattended Installation: To perform an unattended installation from a CD-ROM, the following conditions must be met:The computer must support booting from a CD Rom The unattended answer file must be renamed to Winnt.sif and copied to a floppy disk so Setup can access it. So must need a floppy disk drive.The answer file must contain a valid [Data] section. This is explained later in this article. Before installation it has some conditions:
1> the installation is limited to a single partition.
2> you cannot specify third-party drivers during Setup Prepare For an Unattended Installation:
To prepare your computer for an unattended installation from a CD-ROM, I've followed these stepsFirst I've created a Folder in local drive & shared it. Then I create setup manager.I install Setup Manager by following these steps:I Open My Computer, and then open the SupportTools folder on the Windows XP CD-ROM.Double-click the DEPLOY.CAB file to open it On the Edit menu, click Select All.On the Edit menu, click Copy to Folder.Click Make New Folder. Type the name that you want for the Setup Manager folder, and then press ENTER. For example, type setup manager, and then press ENTER.Click Copy. Open the new folder that you created, and then double-click the setupmgr.exe file. The Windows
Setup Manager Wizard starts: alokerdas_2.jpg
Then I Use Setup Manager to Create an Answer File.
I open the setup manager & go to create a new answer file.
Then I go to the unattended installation & windows version option.
I have selected the fully automated option & create an answer file.
If you want Windows Setup to delete all partitions on the hard disk and to create a new partition, you must include the Repartition command in the Winnt.sif file. Under [Unattended], insert a new line, and then type "Repartition=Yes"
If you omit this line, you are prompted for the installation partition.
Add a [Data] section with the following entries to the unattended answer file:
Unattended Install=Yes - Value must be set to "yes"
MSDos Initiated=No - Value must be set to "no" or Setup stops during the graphical portion of Setup
Auto Partition=1 - If the value is set to 1, the installation partition is automatically selected. If the value is set to 0 (zero) you are prompted for the installation partition during the text portion of Setup.
Save the unattended answer file as Winnt.sif on a floppy disk.
Insert the Windows CD-ROM into the CD-ROM drive, and then insert the floppy disk into the floppy disk drive.
Change the boot order in the CMOS so that the CD-ROM is first in the list.
Restart your computer. When Setup is started from the CD-ROM, the Winnt.sif file located on the floppy disk will be used to complete the unattended installation.
<SPAN style="FONT-FAMILY: 'Courier New
on Feb 15, 2011 | Computers & Internet
I can not boot my hp pavilion a1720n. I get the error message below. I have opened up the case and moved the jumper and replased the battery. Award Bootblock Bios V 1.0 2000, Award Software Inc Bios Rom...
First of all your problem is caused by the hard disk - it has died and must be replaced. Second you are booting from the wrong disk Hiren's disk is a very specialized system analysis and recovery disk, it's not a Windows reinstall one. You should use the disks that came with your pc for that, after you replace the hard disk. Finally you should check the memory sticks, the low memory warning appears only when it way low, less than 256MB. If this is really how it is then you should buy more.
Aug 08, 2010 | Computers & Internet
Computer wont boot properly
A POST diags card can help you resolve your problem/s, if not then.
1. remove all devices and insert the floppy drive, one RAM module and video card.
2. Go into the BIOS configuration and set it to the default configuration, check the installed RAM is it correct? .
3. Insert the remainder RAM module/s and check the POST info and BIOS again, has it detected all the RAM?
4. Does the computer Boot up using a floppy boot disk
5. Insert the CD and hard disk and check the POST info and BIOS configuration, does it detect the new drives?
6. Does the computer Boot up using a floppy boot disk, run FDISK, can you see the hard drive, if so delete all partitions (if any) and create a new primary DOS partition and then format the hard drive.
7. Boot up with the Windows CD (may have to change the boot order to the CD as the first boot device).
8. Delete the DOS partition, create a primary NTFS partition and the do a full NTFS format (not a quick format) and continue to install Windows Xp or Vista.
9. Install the other device eg modem, Lan etc. and the drivers.
If you have trouble with the first 5 steps, then you most likely have a faulty motherboard and/or a faulty hard disk.
Sep 11, 2009 | Computers & Internet
''BOOTMGR is missing'' I can't boot from Windows XP CD
Open cpu cabinet and Refix RAM some times bootable files not load on ram properly so this error comes.
So refix RAM memory clean dust from circuit and RAM .
Also pull cmos cell from motherbord for 5 minutes so all settings are defaults then check.
Aug 01, 2009 | Computers & Internet
How set the hard drive and dvd-rom
first idea is to set the Hard drives on the primary controller on the same cable, having your hard drive with windows as the master and the other as slave ( do this with the jumpers).
Next put your cd\dvd drive on the other cable on the secondary ide (the name is usually IDE2).
turn on your PC and pres delete to go to the bios settings,
once there go to the basic cmos settings page, and make sure you see the settings there as you wanted,
Primary master first hard drive
Primary Slave second hard drive
Secondary Master your cd\dvd drive
helpful ? if not give me a reply for more help
Mar 23, 2009 | Computers & Internet
Bad bios checksum
You need to go to the website of whoever made the motherboard and get the BIOS flash utility and the BIOS binary file to update your BIOS. Make sure you get the right one, as using the wrong one can render your motherboard worthless. The BIOS file has to be the exact match. There is no such thing as close in this situation.
If you are not sure of the exact make and model, get te free Belarc Advisor from http://www.belarc.com
The BIOS chip holds information about your motherboard hardware. It is reprogrammable. It uses what is known electrically erasable read only memory. This is also called Flash memory. Reprogramming is called flashing. When you flash the BIOS, all data is erased, then the new data is written. The flash utility will most likely allow you to save the old contents, but you might have an extremely tough time recovering from an improper flash. You'll also probably need a couple of floppy disks, one of which may have to be bootable. If you need a bootable floppy disk, you can get an image file from http://www.bootdisk.com.
Jan 23, 2009 | Intel Motherboard
INF file textsetup.sif is missing
his behavior may occur if any one of the following conditions is true:
  • Your Windows XP CD-ROM is scratched, smudged, or dirty. Clean the Windows XP CD-ROM with a soft cloth, insert it in the CD-ROM drive, and then click OK.
  • Your CD-ROM drive is not working correctly or the CD-ROM might be vibrating too much for the laser to accurately read the data. For more information about this problem, see your hardware documentation or contact the CD-ROM manufacturer.
  • If you are using multiple CD-ROM drives, your computer may be trying to locate files on the wrong drive. If your hardware has a feature to disable CD-ROM drives that are not being used, disable the CD-ROM drives that you are not using.
  • Your computer is over-clocked. Because over-clocking is very memory-intensive, decoding errors may occur when you extract files from your Windows XP CD-ROM.
  • Try to use the default clock timings for your motherboard and processor. For more information about how to do this, see your hardware documentation or contact the motherboard manufacturer.
  • Your computer has damaged or mismatched random access memory (RAM) or cache memory. For example, you might be using a combination of extended data out (EDO) and non-EDO RAM, or different RAM speeds.
    Decoding errors may occur even if Windows appears to be running correctly. These errors occur because of the additional stress that is put on your computer when Windows tries to extract files and to access the hard disk.
    To determine how to make your computer cache memory unavailable while you are running the Setup program, see your hardware documentation or contact your hardware manufacturer.
  • Ultra direct memory access (DMA) is turned on in your computer's CMOS settings, and the data is moving too quickly.
  • Change from DMA mode to Processor Input/Output (PIO) mode to lower your data transfer rate. If this does not resolve the problem, lower your PIO mode settings. The higher your PIO mode settings are, the faster your data transfer is.
  • You are using a third-party memory manager.
  • There is a virus on your computer.
If you continue to receive this error message, copy the i386 folder from the CD-ROM drive to your local hard disk, and then try to run the Setup program from your hard disk.
Dec 15, 2008 | Microsoft Computers & Internet
Os instalation will not load
Hi Dobssand, the most common reason for a CD-ROM (With a Windows CD in it) does not start to load is the motherboard's bios is not set correctly. While in the bios go to the title Boot & enter boot order. This is a common boot order for a PC.
1st boot device = [Floppy disk drive]
2nd boot device = [CD-ROM drive] (Model number of the CD-ROM drive).
3rd boot device = [Primary Hard Disk Drive] (Model number of drive).
Second most common reason is the data cable to the CD-ROM drive is loose or not fully connected either at the CD-ROM or at the motherboard. (Check it).
If you choose not to enter your bios, you can still get the CD-ROM drive to boot the Win CD in this fashion. Load the Win CD into the CD-ROM drive. Power off the system. Than power on the system & start to press the F8 key once every two seconds. Windows "Please select boot device:" window will open. Using your keyboards up & down arrow keys high-light the CD-ROM drive that has the win CD in it & press the enter key. Windows should start to load. If you receive an error message stating windows can not find your hard disk drive. Than you must enter your bios & go to the title Boot. Your hard disk drive is not listed in the boot order section. Worst case! Your hard disk drive may be faulty. Find the manufactures name printed on a large white sticker on once side of the HDD. Go to the manufactures web site & download their drive setup software so you can create a bootable floppy disk. This will allow you to check/test the HDD & format it for a windows installation.
Or is this not the issue you are having?
Mike
Sep 26, 2008 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
