Question about Dell 2135cn All-In-One Laser Printer
093-970 insert print cartridge error - Dell 2135cn All-In-One Laser Printer
Lexmark 6500 series has cartridge error
User genuine cartridges to avoid this type of error.
>> Remove the print cartridge
>> Clean the print heads of the cartridge.
>> Re-insert it and check the status.
>> If the cartridge is already used (I mean 70% of ink) please replace with new cartridge.
Nov 18, 2013 | Computers & Internet
Hp4355 print catridge error
Each cartridge having printing life, as long as cartridge health condition is good it won't gives any trouble. Subjected series printer having mono & colour cartridges,1. Remove both cartridge from the printer 2. Switch on & wait till message appears for insert the cartridges..3. Insert mono(Black) cartridge, close the door & wait till message appears on screen. If message appears same as cartridge error mean that mono cartridge is faulty replace it, if message appears like insert another cartridge, it's confirmed that colour cartridge faulty.. Replace it..
Apr 28, 2012 | HP Officejet 4355 All-In-One InkJet...
Just put in a new black cartridge and it wont print anything. Keeps saying alignment problem and prints a bunch of tourquoise designs in stripes. got the alignment note to go away but still nothing on...
It could be that one of your cartridges are not seated well in the carrier or one of your cartridges are faulty or just needs cleaning:
  1. Open the printer cover.
  2. Remove both cartridges from the printer.
  3. Close the printer cover.
  4. Unplug and re-plug the printer into the power source to reset it.
  5. When the printer turns on, re-insert one cartridge first. Close the cover.
  6. Check for any errors.
  7. If no error appears, re-insert the other cartridge.
  8. Replace whichever cartridge is causing the error to appear. Or you could also insert a different known working cartridge to determine if the other is faulty.
Jul 27, 2011 | Lexmark X5470 All-In-One InkJet Printer
Unable to print from lexmark x2690. printer is giving the error E C 1 on display.
EC1 error message indicates that your printer having trouble recognizing one of your cartridges. You could try to re-seat the cartridges in the printer. Remove and reinsert both cartridges. You may also wipe the cartridge nozzles with a damp paper towel to clean it from dirts and clogs. If error continues, check w/c cartridge is causing the error. Insert one cartridge first, then close the cover. If no error appears, then insert the other cartridge. Replace whichever cartridge is causing the error to appear.
Apr 15, 2011 | Lexmark X2690 All-In-One InkJet Printer
I installed a new print cartridge and now get an error message saying no print cartridge installed.
Try to reseat your new cartridge. You may wipe the nozzles with a damp paper towel to clean it from dirts and clogs. Make sure it's properly inserted. Unplug and replug your printer into the power source to reset itself. If error continues, try to insert a different known working cartridge to determine if your new cartridge is faulty. Thanks.
Feb 17, 2011 | Lexmark X2350 All-In-One InkJet Printer
10.1000 supply memory error
hi,
10.00X is the error code displayed when
  • Cartridge is not installed correctly
  • Use of refilled cartridges
in your case x is 0 which means that black color cartridge had a problem
problem may persist in slot holding black cartridge and /or in the cartridge
just do steps below
solution 1: check all cartridges are in right slot it is better to remove and fix it again
solution 2:
clean the surface of metal contacts with lint-free cloth
the image below will show metal contacts
solution 3: Insert the problem print cartridge into a different slot
Follow these steps to determine if the print cartridge or the slot it sits in is causing the error.
  1. Open the print cartridge door completely.
  2. Press the blue handle on the print cartridge drawer to release it, and then pull the drawer out completely.
  3. Remove one of the non problem print cartridges from its slot.
  4. Install the problem print cartridge into the empty slot.
  5. Install the other print cartridge into the slot of the problem print cartridge.
  6. Close the print cartridge drawer completely.
  7. Close the front access door completely.
  • If the error message persists , replace the problem cartridge with new one(problem is in cartridge)
  • If the error message is gone , contact HP to troubleshoot a faulty slot.
regards,
cseian
Dec 16, 2010 | HP Hewlett Packard LaserJet 3000dn Printer
Continually says align print cartridges
My guess is that the color cartridge is either defective or not inserted correctly. I have a 6110 and know that inserting a print cartridge is a little tricky. If it isn't completely inserted and the top latch fastened correctly, the cartridge either won't work or produce errors.
Try reseating the color cartridge so it's inserted in exactly the same way as the black cartridge and run a print job again.
Open the following web page and go to Step three to see the instructions for cleaning the electronic contacts on the cartridge and print carriage.
Ink Cartridge Alignment Fails
Those seem the most likely causes and solutions to me. Good luck.
Oct 29, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Hp psc2410xi
The following error message appears on the color graphics display after you insert a cartridge: Remove and Check Print Cartridges . The printer will not print. The message does not specify which cartridge has caused the error. Solution This error message indicates that the printer cannot determine which cartridge is causing the error. Follow the steps below to solve the problem.
  1. Remove the color cartridge from the left stall (which has a blue latch) and refasten the latch. Leave the other cartridge in place.
  2. Close the printer, wait 10 to 15 seconds, then look at the LCD display.
    • If the LCD display reads Insert Color Cartridge in Left Stall , the color cartridge may be causing the problem. Follow the steps below:
      1. Clean the color cartridge contacts.
      2. Reinsert the color cartridge into the carriage and close the blue latch.
      3. Close the printer and wait 10 to 15 seconds.
      4. If the LCD display reads Remove and Check Print Cartridges , replace the color cartridge.
    OR
    • If the LCD display reads Remove and Check Print Cartridges , follow the steps below:
      1. Reinsert the color cartridge.
      2. Remove the black or photo cartridge, depending on which one is installed in the right stall. The right stall has the gray latch. Be sure to refasten the latch on the empty stall.
      3. Clean the black or photo cartridge contacts.
      4. Reinsert the black or photo cartridge.
      5. Close the printer and wait 10 to 15 seconds.
      6. If the LCD display reads Remove and Check Print Cartridges , replace the black or photo cartridge.
  1. Remove and then reinsert the cartridge indicated in the error message.
  2. If the error is still displayed, clean the contacts.
    1. If the error message is Error. Remove and Check Black or Photo Cartridge , the following steps may help:
    1. Remove both cartridges, lower the latches, and close the printer access door.
    2. Turn off the unit by pressing the On button on the front panel. Wait for the printer to completely shut down.
    3. Turn the printer back on by pressing the On button.
    4. When the message display reads Insert Print Cartridges , open the access door and replace the cartridges.
    1. If neither of the steps above fixed the problem, either the cartridge or the printer is faulty
    Aug 12, 2008 | HP LaserJet 5L Printer
    Dell 2135cn All-In-One Laser Printer Logo
    546 people viewed this question
    Top Dell Office Equipment & Supplies Experts
    jasbo
    jasbo
    Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
