Question about SmartDisk Crossfire Desktop (xf160f) 160 GB Hard Drive
Drive F: No more, HELP!!!
My Crossfire was recognized for the past week as Drive F. and when I turned on the computer, it was gone. It's plugged into my USB port, ans when I cheked the status, it gave me a "Code 10". I cannot find any program to fix it. I have home movies, music, and important files on it. Is there a chance that everything was erased?
    Genius:
  • 1,224 Answers
Try changing your usb port the info on drive should still be there also if this didnt help try reinstalling driver software sometimes corrupt files happen for drivers
Posted on May 16, 2008
My crossfire hard drive is clicking and is not recognized by my computer as an external drive.
It's died, if its under warrently get it looked at quickly before the warrenty runs out.
Otherwise you need to use a data recovery company, if you need I can advise on some good ones that we (MCSLondon.co.uk) use
Oct 29, 2010 | SmartDisk Crossfire Desktop (xf250f) 250...
Computer is not recognizing my external hard drive
If the light won't blink, there could be problem with the power source. Do scanning hardisk for errors manually ( take off the hardisk from the case, assemble it on other PC Desktop)
May 06, 2010 | IO Magic Corporation GigaBank (I250HD35)...
I have a smartdisk Fire Lite external harddrive - When I plug it into the usb hub the computer does not acknowledge it
Hello
If you power up the drive and you can feel that the drive is actually spinning, a periodic clicking noise is bad news.
Does the computer make a sound when you plug it in, or does it make a sound.
If the computer recognize when you plug it in, but it just not show in my computer, here is how you fix the problem. Go to:
control panel
Administrative tools
Computer management
Storage
Disc management
Now you should see your drive in the schematic below. Right click on it and choose the option to change drive letter or paths. Now just assign a new drive letter to the drive, restart your computer and it should work fine.
Best regards
Andrea
Nov 05, 2009 | Smartdisk - Peripherals - HARD DRIVE,...
Periodically the crossfire won't start.
This sounds like one of those interesting problems. What you are going to have to do is find a light bulb type of electrical tester, and a schematic for the wiring on the car (or get a mechanic to do it). When the problem comes up again, you have to find where the power to the module is not coming through a weak connection. It is something that warms up and then breaks connection.
The first thing to do is change the fuses for the engine controls. Fuses are cheap and sometimes they develop a crack that opens when they see a rise in temperature from a heavy electrical load or warm or cold weather changes. Other things that cause problems are the wires that connect to the battery, and splices in those wires which are usually hidden inside a bundle of wires. Also inspect the connectors that hook up to the engine module and make sure the pins are not pulling out from tension in the wires and other defects.
You said it doesn't turn over, so also check the connections at the starter. Sometimes main power is routed through there.
May 29, 2009 | 2005 Chrysler Crossfire
Computer suddenly not recognizing relatively new WD MyBook 640GB
Just a shot in the dark, but ..., shut down your computer and unplug the drive. Turn the hard drive off, then back on. Plug it back into the computer and restart. If it doesn't pop up, restart your computer this time with it plugged in.
Is there any noise coming from the drive? Is the green light on the front?
The same thing happened to me and the same drive, but 500gb. I did the above and it fired right back up again. You may have to delete the trial version from the drive if it on there, or from your computer if you had originally installed it.
Jan 07, 2009 | Western Digital 320GB MyBook External USB...
My 160GB Crossfire is not recognised when connected to any of the USB ports. It used to be, but then I've had some other PC issues recently that meant a forced closure of the PC and I'm concerned that...
When starting the external drive there is not much more than just plugging it in to a USB port and turning it on. The computer should recognize it ( showing something like the window shown here http://attachments.techguy.org/attachments/66120d1129787805/new-device-found2.jpg ) and it will show up in the My Computer area and a green arrow looking icon ( http://home.krb.nsw.edu.au/start/images/USB2.jpg ) When disconnecting an external drive the correct procedure is to left click the arrow in the system tray and select Safely Remove Mass Storage Device (X:) (whatever letter you device shows here)
You may want to test if another computer recognizes the device being plugged in to see if it is still functioning. You may want to also try plugging the device into a different USB port on your computer.
Dec 09, 2008 | Computers & Internet
WHERE TO BUY REPLACEMENT POWER CORD
I just today ordered a new power supply adapter for my Smartdisk Crossfire 250 gb hard drive (I had a broken pin on my original one). Paid $29 plus shipping. We'll see if it arrives this coming week. If you still need one, here's a link to it:
http://lcdpayless.com/productpage.php?productId=4043
Bob
Nov 18, 2008 | SmartDisk 250GB SMARTDISK CROSSFIRE EXT...
SmartDisk Crossfire Desktop Drive
Usually this is a problem with the usb port not being able to supply enough power to the drive. Often, units like this will come with two usb plugs on one cable to increase the current supplied to the drive. If the drive has an input for external power (some do, some don't), then using external power would help.
Apr 23, 2008 | SmartDisk Crossfire Desktop (xf160f) 160...
Crossfire 160gb external hard drive.
If the drive was formatted in a newer windows OS and it is the NTFS file system, the Mac OS will only have read access. You can check this by plugging it in and checking the properties. To solve this you can copy your stuff off and reformat in the FAT32 format, you will only lose the security features that NTFS offers.
Jan 29, 2008 | Smartdisk - Peripherals - HARD DRIVE,...
Crossfire 160 GB external hard drive
Dear Crewchief Try deep freezing your drive, really, I mean freezing it for more than an hour, take it out and attach as a primary or secondary slave and see if it cycles up. Sure hope this helps.
Jan 16, 2007 | Smartdisk - Peripherals - HARD DRIVE,...
SmartDisk Crossfire Desktop (xf160f) 160 GB Hard Drive Logo
Top SmartDisk Computers & Internet Experts
Sunday Ojelabi
Sunday Ojelabi
 Ian Kayhan
Ian Kayhan
Are you a SmartDisk Computer and Internet Expert? Answer questions, earn points and help others
