Question about Whirlpool Refrigerators
Water dispenser does not work properly the water drips out and the ice maker is not working right. please help
  • 145 Answers
Check the water supply from your plumbing first. When they both stop working properly it is ususlly slow water pressure coming to the unit.
Posted on May 16, 2008
Ge profile refrigerator leaking water from bottom when pressing dispencer
The water dispenser tube is getting leaked form in between or its got loose from its actual line.Inspect water dispenser tube from water valve to the end of where the water is getting dispensed.
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 26, 2012 | GE (PSS26MSRSS) Side by Side Refrigerator
Water dispenser not working on Daewoo DRS31PSM fridge freezer
Get the water valve checked.
May be its not letting the water to pass through the line.or its blocked auger.
Replacement parts can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
partsselect.com
These will help.
Thanks,.
Dec 23, 2012 | Refrigerators
Ice maker kitchenaid super ba is not working . Chilled water dispenses but no water seems to enter ice maker.
These will help.
Thanks,.
Dec 22, 2012 | KitchenAid Superba KSRG25FK Side by Side...
Ice maker will not work. Water is coming into the back of the refrigerator and water dispenses out of water dispenser. But no water will go to the ice maker.
Try swapping the wires on the dual water inlet valve. It’s on the back where the water supply comes in. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze blocking the fill tube.. You can take the water line off the valve and watch to see if it drips.
Aug 23, 2010 | Maytag MSD2651 HE Side by Side...
Ice maker does not make ice anymore. appears the tray is not filling with water. door water dispenser is still working
Apr 24, 2010 | LG LRFD25850 French Door Refrigerator
The water dispenser in my refrigerator ice maker is leaking
if you have recently changed your filter, had the water turned off, or disconnected from the ref this is a common problem. you have air in your water line. fill 5-6 large cups of water or until it stops spurting and your drip should go away
Apr 23, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
No ice being made. water supply for drinking is OK. Model is about 3 years old. question: why no ice. does the automatic shut off arm control the water flow?
Well first of all you can check to see whether the ice maker has been turned off, Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat. Please reply if you need more help or information.......
Good Luck!!
Thanks
Dec 29, 2009 | LG LFX25960ST Stainless Steel French Door...
Water leak from ice dispenser line
hi..
Your water inlet valve on the back where the water supply comes in is probably leaking. disconnect the water line coming out of it and see if you have a slow drip. Try the dispenser to see if it's just drips after use.
For the ice maker problem, Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.If it does, the problem is the ice maker and not the valve and line...
thank u
rate me!!
Jul 26, 2009 | GE Refrigerators
My maytag ice maker is not working, but the water dispenser is working at a good pressure.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze and block the tube. You can take the water line off the valve and watch to see if it drips.
A strainer before the inlet valve can also get stopped up restricting flow.
Jul 12, 2009 | Refrigerators
Water dispenser leaks, ice maker won't make ice. Hve disconnected line at bottom front, and tried blowing out the lines, no help. Model EDQ22DQFNX00
Jul 02, 2009 | Whirlpool ED2FHEXN Side by Side...
Refrigerators Logo
53 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
