Question about Sony Video Cameras
When I turn on my sony dcr-trv120 the time code on the display just blinks and will not read the time code from the tape. It will not play back recorded tapes either. I have two of these camcorders and both of them do the same thing.
  • 3,083 Answers
I couldn't find any reports of this happening on the net, but I did run across a free manual for you. Since both camcorders are doing this, I think it's a software setting issue, and the manual might help you set it up.
Here's the manual:
http://www.retrevo.com/support/Sony-DCR-TRV120-Camcorders-manual/id/201ag125/t/2/
Good luck, and hope this helps.
Posted on Sep 15, 2010
Whenever I insert a new video tape on my Sony Handyman DCR-TRV120, it says "C:31:23" and it tells me to eject the tape. Once I take out the video tape, it rather has the film outside of the tape,...
You have a transport problem with the tape feed. If you are up to working in small spaces without damaging adjacent parts, you can try and clean the pinch roller and capstan drive system with alcohol on a Q-tip. Sometimes, there are special cleaning tapes your can purchase that will do the same thing. Assuming that the transport is dirty, you may have a shot at it. If it's excessive wear instead, it's shop time. One more thing. DO NOT USE A CRINKLED TAPE IN YOUR CAMERA. IT WILL TEAR UP THE VERY DELICATE TAPE HEADS PERMANENTLY.
Feb 04, 2011 | Sony Handycam DCR-TRV19 Mini DV Digital...
What would cause a sony dcr trv120 zoom button not
There is control switch block that has zoom/wide switch along with play, rewind, forward, stop, pause buttons and this switch block flip up and down while ejecting/ load tape in camcorder, this will be replaced as zoom/wide switch got defective and sending continues command of zoom to system control chip.
Let me know if you need part number of switch block control for DCR-TRV120
Jul 27, 2010 | Sony Handycam DCR-TRV19 Mini DV Digital...
Cleaning dcr-trv120. Camera needs to be cleaned and I cannot find tape that works in order to clean it
Go here to find the details regarding cleaning of Camcorders.
http://www.kb.sony.com/selfservice/microsites/search.do?cmd=displayKC&docType=kc&externalId=C254128
Aug 07, 2009 | Sony Video Cameras
Error message; has something to do with insertion of tape. Looks like triangle over straight line. beeps and blinks, will not play. Working when loaned to a "friend", returned in this condition...
Will it record on a new tape? Will it play a different tape? Have had a similar problem with a different camera. Think it had to do with the record mode / play back. A bit like standard play and long play - are there setting like that you could change?
Jun 26, 2009 | Sony Handycam DCR-TRV27 Mini DV Digital...
Choppy playback from my Sony Digital 8 DCR-TRV120
I think you are don with that camera , If you know of a friend or someone who has a similar try playing back your tapes if they do then just forget about your camera and simply replace it
Jan 26, 2009 | Sony Handycam DCR-TRV120BT Digital...
Sony TRV120 Won't load tape C21:00 code
From the user manual ...
Under self diagnosis display
C21:00
Moisture condensation has occurred.
Remove the cassette and leave your camcorder for at least 1 hour to acclimatize. (p117)
On p117
If your camcorder is brought directly from a cold to a warm place, moisture may condense inside your camcorder, on the surface of the tape, or on the lens. In this condition, the tape may stick to the head drum and be damaged or your camcorder may not operate correctly. If there is moisture inside your camcorder, the beep sounds and the [picture of water drip] indicator flashes. When the [end tape icon] indicator flashes at the same time, the cassette is inserted in your camcorder. If moisture condenses on the lens, the indicator will not appear.
If moisture condensation occurred
None of the functions except cassette ejection will work. Eject the cassette, turn off your camcorder, and leave it for about 1 hour with the cassette compartment open. Your camcorder can be used again if the [water drip] indicator does not appear when the power is turned on again.
Note on moisture condensation
Moisture may condense when you bring your camcorder from a cold place into a warm place (or vice-versa) or when you use your camcorder in a hot place as follows:
- You bring your camcorder from a ski slope into a place warmed up by a heating device.
- You bring your camcorder from an air-conditioned car or room into a hot place outside.
- You use your camcorder after a squall or a shower.
- You use your camcorder in a high temperature and humidity place.
How to prevent moisture condensation
when you bring your camcorder from a cold place into a warm place, put your camcorder in a plastic bag and tightly seal it. Remove the bag when the air temperature inside the plastic bag has reached the surrounding temperature (after about 1 hour).
Dec 06, 2008 | Sony Handycam DCR-TRV120BT Digital...
Sony dcr-trv120 playback
the problem is with the video head. either it's dirty or broken. if cleaning tape is not solving the problem then i fear you have to get the head changed. an expensive repair.
Jan 18, 2008 | Video Cameras
No playback on DCR-TRV103
In playback mode the lCD displays the battery time, hi8 symbol and the tape counter. all the functions work the tape will play, rewind, fast forward. The screen stays blank on playback and the tape counter stays at 0:00:00 eventhough I can see the tape turning. I also hooke the camera to my tv and I got no picture.
Dec 23, 2007 | Sony Handycam DCR-TRV103 Digital Camcorder
DCR TRV320
That is the "LOAD" error code.
However, to service the C:31 code, Sony recommends you do the following:
  1. Turn off the camcorder.
  2. Remove the battery or disconnect the AC power adapter for 60 seconds.
  3. Insert the battery or reconnect the AC adapter.
  4. Turn on the camcorder.
  5. If the error message appears, service may be required.
If your camcorder still shows the same error code, then you'll have to send in your camcorder for service.
Oct 25, 2007 | Sony Handycam DCR-TRV320 Digital Camcorder
I am having trouble playing a Hi-8 tape in my sony camcorder DCR-trv250
Looks like you have a blank area in the Tape. Try Fast forward and you will get again MM:SS:SS.
Mar 25, 2007 | Sony Handycam DCR-TRV250 Digital Camcorder
Video Cameras Logo
66 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
