The Sage Line 50 Account Version 11 is saying "not enough memory to continue" when we try to access the Sales Order Processing on either the server or client machine.
Paeroa
  • 457 Answers
SOURCE: Restoring Sage back up file
All the back files that was created is on that other machine even while you may think its on that disk in theory YES but physically NO. Thats why you got this: Error message keeps coming up which is: programfiles\sage\accounts\company.001attachments\nominal\1200\statements\288.pdf Just one more try the disk you used look on it if it has the 288.pdf file you may be able to read it from the PDF software and then recreate it in the sage financial creater?
Posted on Sep 18, 2007
  • 36 Answers
SOURCE: dhcp in server 2003 in domain not working
Windows 2003 server supports DHCP. If you don't see in Administrative tool DHCP maybe the DHCP role is not enabled. You can add this role in "Manage your server". You don't need to reinstall win 2003 server.
Another way to access DHCP management tool is: in command prompt type mmc and then File> "Add remove snap-in" then "Add" and select DHCP.
Posted on Jan 08, 2009
  • 28 Answers
SOURCE: Sage Line 50 cant get customers off hold
If you go to Setting/ Company preferences then click on parameters tab if you untick display account status you will switch off all warnings
Posted on Mar 24, 2009
vickygomar
  • 460 Answers
SOURCE: Premium users are not allowed to access this server. Error???
Lets try to update your yahoo by doing so many problems will be solve, it will take few min depending in your conection.
Your rating is very important to me...
Was this helpful?
Posted on May 27, 2009
SOURCE: VPN Using XP Servers and D-Link WBR-2310
I had exactly the same problem. The solution is to set up pptp as a virtual server pointing to the lan ip of the server. Port forwarding only forwards the port but not the GRE protocol (pptp passthrough)
Posted on Sep 09, 2009
I can not install sage line 50 11 verson. please help me
Hi charuka, try going into control panel and delete all things sage then restart, reinstall, restart = play. Best of luck, Greg.
Dec 20, 2014 | Microsoft Windows 7 Ultimate for PC
Sage line 50 v12 activation key and serial
hi
activation key for version 11 is ZIXBLXAI and serial no; NZ13217
May 03, 2012 | Sage Computers & Internet
I have set up a euro currency bank account in sage line 50 v10. However, the account has now reverted to a sterling currency one and I am unable to change it back. Any solutions?
There is no way of changing the currency on a bank account once any transactions have been posted. This may mean you have a corruption in your data and it may have to be sent to Sage for fixing. Sorry I Can't be more helpful
Jan 22, 2011 | Sage Instant Accounts 8.0 (013604ug)
I have just upgraded to sage line 50 accounts professional, yet when i try to run it it tells me the data file could not be found.my data is held on another networked computer and i can see that the path...
Hi allweatherra
Sage 50 has a file called company. that holds the path to the sage Data. From version 2007 onwards this is held in c:\documents and settings\all users\application data\sage\accounts\2010(or whatever version you have)
Hope this helps
Feb 10, 2010 | Sage Instant Accounts 8.0 (013604ug)
C:\program\SAGE\ACCOUNTS\REPORTS\\*TB.SRT contains an invalid pat
This message usually comes when the target location is not there or is renamed OR the address is wrong. Open My Computer, and go to the address you gave. Look if there is the file named *TB.SRT.
And by the way... the address you gave was "
C:\PROGRAM\\SAGE\ACCOUNTS\REPORTS\\*TB.SRT" BUT I believe that the address should be "C:\PROGRAM\SAGE\ACCOUNTS\REPORTS\*TB.SRT".
It is not possible that the address contains 2 slash (\\) repeatedly. Open the file by going to the My Computer OR by opening the software and by locating the file manually from there.
live chat assistance costs $19.99. And $12.99 for one time e-mail premium support.
If you have a registered product then I would suggest you to visit:
http://support.sage.co.uk/default.aspx?page=1
There you might find a solution at no cost.
Please inform if your problem is solved or not. And please rate if you found the above info useful.
Aug 28, 2009 | Sage Instant Accounts 8.0 (013604ug)
Email Remittances - Report Designer Problem
Sage Line 50 Addpurch Utility
In Sage Line 50 V5, you could only produce remittances for the
supplier accounts you had set up in your Sage Line 50 program.
The information that appeared on your remittances was taken
from the supplier ledger.
In newer versions of Sage Line 50 you can produce remittances for suppliers
who do not have a corresponding supplier record. This allows
you to produce free-format cheques for one-off payments. To
enable you to produce free-format cheques, Sage Line 50 no
longer takes the information for remittances from the supplier
ledger. This means that you can produce remittances whether
there is a corresponding supplier record or not.
If you want to include additional information from your
supplier records on your remittances, for example bank sort
codes and account numbers, you should convert the layouts
you require using this utility.
Note: This utility is installed automatically into your
Sage Line 50 program directory when you install Sage
Line 50.
>> To use the Addpurch utility
1. Open a Command Prompt by clicking on to your Windows Start Button
selecting Run, then type the word COMMAND and click on to OK.
From the command prompt (for example, c:\windows\desktop>) type cd\ and
then press ENTER.
2. At the c:\> prompt type cd "Program Files\Sage Accounts\layouts"
and then press ENTER.
The prompt should now read c:\Program Files\Sage\Accounts\layouts
Note: If your Sage Line 50 program is installed in a different
directory replace the above instruction with your own directory
name. The directory path can be found within your program by
clicking on to Help and then About and choosing the System
Information Tab. Your layouts will be held on the same path
as your data directory.
3. Before you can convert your remittance layout you will
need to save this with a new filename. (maximum of 8 characters).
For example, to rename one of your existing layouts from
the c:\Program Files\Sage\Accounts\layouts prompt type:
copy remita4.sly newrema4.sly
Jul 07, 2009 | Sage Computers & Internet
Invalid Path error
I get this error when trying to run Financial reports in Sage line 50 financial controller verson 10: C:\PROGRAM FILES\SAGE\ACCOUNTS\REPORTS\\*TB.SRT contains an invalid path No matter what financial report I try to access I get the same error including audit trail. My computer is window Vista. Please help me and also let me know how much is it cost for on line chat?
Thank you
from selvi
Apr 14, 2009 | Sage Instant Accounts 8.0 (013604ug)
Sage Line 50
You would need to be on version 9 or higher and have finanacial controller (now called Accounts professional) Run the foreign currency setup wizard then you would be able to setup and operate an account in US Dollars
Jul 03, 2008 | Computers & Internet
Sage 50 Accounts 2008
I think I got the solution for you ...
User Name is Already in Use / Cannot Access YYY because XXX is logged in
Typically, when you get this message you will be asked if you want to remove the user from the request list. If you are asked this question, simply answer Yes and you'll be able to continue.
An alternative solution is to go in the data folder for your sage data (the default folder for versions prior to 14 is c:\program files\sage\accounts\accdata for v14, the folder is c:\documents and settings\all users\application data\sage\accounts\2008\company.000\accdata on XP and c:\programdata\sage\accounts\2008\company.000\accdata. In the data folder, you will find a file called QUEUE.DTA - delete the file and you should be able to get back into Line 50. If you have a multi user version of Line 50, you should only delete this file if you are sure that no-one else is using Line 50.
Mar 20, 2008 | Sage Instant Accounts 8.0 (013604ug)
Computers & Internet Logo
323 people viewed this question
David Payne
David Payne
