When I press Num Lock the light goes on but I cannot type numbers from the num lock keyboard. I have checked the Registry & HKey_Current User ...keyboardindicators is set correctly to 2. I am running XP Pro SP3.
  • 734 Answers
HI there,
It definitely sounds like a hardware problem as you've checked the exact settings for software issues. I'd just replace the keyboard. Go to eBay and enter your laptop's model followed by "keyboard" in the search window. You should a zillion of them for sale and I've rarely seen a laptop keyboard replacement part there over $20.
Best Regards,
Marcus
Posted on Sep 15, 2010
  • 72 Answers
There is no problem in system but the problem is in hardware please connect another keyboard and tyr if the other keyboard works then the problem is in keyboard or else the problem is in keyboard connecter pins
Disable num lock
Deskop or Laptop seems to be a contradiction >????
The num lock (number or numeric lock) can become annoying if you tend to accidentally hit the num lock key on your laptop and turn it on or off.
Disabling the num lock completely involves editing the system registry.
Before performing such edits, always save and back up your computer information in case you make a mistake, as the system registry controls many aspects of your computer's operation.
Once you have disabled the num lock on your laptop, you must edit the system registry again to re-enable that function.
Close all windows and programs that are running on your computer.
Press the "Windows" key and the "R" key simultaneously to open the "Run" dialog box.
Type "regedit" without the quotation marks, then press "Enter."
Click the "+" symbol next to HKEY_CURRENT_USER, then select the "+" symbol next to "Control Panel."
Click on "Keyboard."
Double-click "IntitialKeyboardIndicators."
Enter "0" (the number zero) in the "Value Data" field to disable the num lock after logon, or enter "1" (the number one) to disable the num lock entirely.
Click "OK," then close the registry by clicking the "X" in the upper right corner of the registry window.
Restart your computer.
To re-enable num lock, follow the same process, but change the "Value Data" to "2."
http://www.softwarehowtos.com/article-how-to-disable-or-enable-the-num-lock-key-at-startup-1244448193.html
Oct 09, 2013 | Dell Vostro 1510 Laptop Computer PC...
Tip
How to enable the NUM LOCK key for the logon screen
The status of the NUM LOCK key is specific for each user, and it is disabled by default. If you want the NUM LOCK key enabled for use before a user presses CTRL+ALT+DEL to log on (the logon desktop), you need to edit the registry. To enable NUM LOCK for the Logon desktop (shown when no user is logged on), use the steps below:
  • Click Start, Run and type regedit.exe
  • Navigate to the following location:
HKEY_USERS\.Default\Control Panel\Keyboard
  • Double-click the value InitialKeyboardIndicators
  • Set the value-data from 0 to 2
  • Close Regedit
To undo the above, change the InitialKeyboardIndicators value back to 0
on Mar 24, 2008 | Microsoft Windows Vista Ultimate Edition
Unlock number lock
On a laptop, the "Num Lock" key has a function slightly different than the one it performs on full-d desktop keyboards. Activating "Num Lock" on a laptop usually transforms a set of central keys, including many letters, into number keys, allowing typists used to entering numbers on a keypad to type efficiently. While on desktop keyboards "Num Lock" usually has a dedicated key, on laptops it often shares a key with another function on MacBooks, for example, it shares the "F6" key and you must hold down the "Shift" or "Fn" key to activate it.
Look for the "Num Lock" key on your laptop's keyboard. This is usually near the top of the keyboard. If the key says nothing on it except "Num Lock" if that's the only function the key performs you can just press it to activate the lock; a light will probably go on somewhere to indicate that "Num Lock" is on. If the key has multiple functions, you'll have to hold down a different key while pressing it. Hold down "Shift" and press "Num Lock" if the writing saying "Num Lock" appears above some other writing on the key, the way various symbols appear above the numbers on the keyboard's number row. Hold down "Fn" and press "Num Lock" if the writing saying "Num Lock" appears in a different color often light blue that's shared by the "Fn" key.
Feb 28, 2013 | Acer Aspire Computers & Internet
Numerical keypad offset numlock on keyboard
Examine your keyboard to ensure your "Number Lock" key is not activated.
This activation is indicated by the key being lit up.
If the key is activated, press it to deactivate the lock.
The number lock key will deactivate an entire segment of your keyboard
Start, click Run, and type regedit to open the Windows registry editor.
In the registry, open the below folders.
HKEY_CURRENT_USER\
Control Panel\
Keyboard\
Within the keyboard folder, you should have a string value named "InitialKeyboardIndicators" with a value of 0, 1, or 2. Below is the explanation of each of these values.
0 = Num Lock is turned OFF after the logon.
1 = Disable Num Lock.
2 = Numlock is turned ON after the logon.
hope this helps
Nov 18, 2012 | Genius KB9229047 Keyboard
When I type on my keyboard on my computer numbers are popping up instead of letters
Press the Start key + R.
type osk in that box and hit enter
On this keyboard, try toggling numlock scrolllock and capslock a few times.
Also, try this too: Fn+Numlk or depending of the model, press the button or Fn + Shift +Numlk
hope this helps
Try this. Press the Start key + R. type osk in that box and hit enter On this keyboard, try toggling numlock scrolllock and capslock a few times
or
HKEY_CURRENT_USER\
Control Panel\
Keyboard\
hope this helps
Nov 08, 2012 | Computers & Internet
My keyboard is locked and 3 lights above the number pad are lit
HKEY_CURRENT_USER\
Control Panel\
Keyboard\
hope this helps
Oct 03, 2012 | eMachines Computers & Internet
Toshiba satellite c655d-5332 keys problem
HKEY_CURRENT_USER\
Control Panel\
Keyboard\
hope this helps
Sep 23, 2012 | Toshiba NB205-N210 Netbook
Keyboard keys that have purple numbers are locked. Can't type.
Your "Num Lock" is on.
Look for the num lock key (it's similar to the "caps lock" key in function)
If the "num lock" is blue, you may have to hold a blue "fn" key when you press num lock
There's is probably a light at the top of the keyboard that'll tell you when num lock is on.
Sep 20, 2009 | Compaq Keyboard
Dell Keyboar Problem -
This likely is one of two issues. A BIOS setting, and can be changed in the BIOS setup utility accessible at startup.
Or ...
If you are sure you have no computer virus or a hardware conflict than you can modify this setting by editing the registry on the computer. Normally, the computer applies the user settings when the user logs on, but it uses the default user profile when it is first turned on, before the user has logged on. To turn this functionality off, the default user settings must be modified. The Keyboard entry contains user preferences as defined by choosing the Keyboard icon in Control Panel. Entries are found under this registry path:
HKEY_USERS\.DEFAULT\Control Panel\Keyboard
InitialKeyboardIndicators REG_SZ Number set it default to 0.
If not:
* Run the Registry Editor (REGEDIT.EXE).
* Open HKEY_CURRENT_USER\Control Panel\Keyboard (If the Keyboard key isn't there, add it.)
* Double-click the InitialKeyboardIndicators value on the right. (If it's not there, select New from the Edit menu, then String Value, and type InitialKeyboardIndicators for the name of the new value.)
* Change the value to any of the following:
0 - all indicators off
1 - Caps Lock on
2 - Num Lock on
4 - Scroll Lock on
Or, combine them by adding the corresponding values:
3 - Caps Lock and Num Lock on
5 - Caps Lock and Scroll Lock on
6 - Num Lock and Scroll Lock on
7 - Caps Lock, Num Lock, and Scroll Lock on
* Close the Registry Editor when you're done.
All the change should take effect when next time you start Windows.
Aug 28, 2009 | Dell 0Y3740 Keyboard
The scroll number lock goes on by itself
you can just press function+num lock and then it'll turn off and on when you want it to
Mar 30, 2009 | HP Pavilion ze2000 Notebook
Computers & Internet Logo
61 people viewed this question
David Payne
David Payne
