Question about Pentair 150k Minimax Ch Ng Mv Heater
My pentair minimax 150 has a pilot light but will not ignite. I have checked the thermostats and have jumpered the sensors. I have good water flow. I am thinking it is the gas valve or thermocouple. I am getting millivolts out of the thermocouple, though. Can you assist?
    Top Expert:
  • Pentair Master
  • 8,514 Answers
Check for loose wires
Posted on Oct 07, 2017
  • 128 Answers
SOURCE: Pentair minimax nt just replaced ingnitor module
This means the air switch is bad.
Posted on Aug 23, 2009
  • 246 Answers
SOURCE: Pentair Minimax 250M
how many times it blink will tell you what is wrong check at the codes. unplug thermostat check fo homs 10 k around is fine at 80 degrees pressure switch require a by pass but DO NOT RUN THE HEATER WITH A BY PASS ANY CONTROL!!!!
Posted on Sep 19, 2009
SOURCE: Pentair minimax pool heater (1 year old)
Board problem? Did you fix the problem?
Posted on Oct 19, 2009
  • 990 Answers
SOURCE: the pilot light on my pentair minimax ch 250m will
More than likley this is a bad thermocouple and will need a new pilot assembly. But it can also be a short in the safty circut, rat chewed wires or a bad gas valve. It may be best to get a repairman involved. Or you can just drop each switch out of line and jump past them to check. But part changeing can get pricy. Good luck.
Posted on Jun 27, 2010
UglyPoolGuy
  • 46 Answers
SOURCE: Pentair Minimax CH Propane Millivolt Ignition
If you are firing, and then going off and getting an E05, your igniter is to blame. It may be glowing but it's getting weak. The diagnostic goes further but that is usually the fix.. With inactivity, the igniter is always to blame. You really need to fire it off weekly to make it reliable and make sure that your heater is serviced at least one time a year to keep all the internal components operating as designed.
  • PILOT ASSY LP MV CH150 IID
  • Manufacturer: PENTAIR WATER POOL AND SPA INC
  • Manufacturer Part #: 471291
  • Description: Propane pilot assembly for heaters with millivolt ignition.
  • Retail Cost: Approximately $65.00
Posted on Dec 08, 2010
I have a 8 year old pentair minimax 200ch that does not start but pilot liights up
all these heaters have safety features that must test 'ok' before they will light. the first place to start is the pressure switch. if it doesnt sense water flow, you will not have heat
Jun 28, 2014 | Pentair Minimax NT Heater
My Pentair Minimax NT heater constantly displays "HI" on the LED readout, and never turns on to heat. As I understand the HI readout, it is an overtemp protection. I looked at the product manual and...
This could be high limits but more than likely this is a water flow problem. Check to be sure your by-pass is closed or nearly closed. If this is good then you need to remove the water manifold from the side of the heater. Inside you will find another by-pass assembly and you will need to replace this.
Before doing this you can take the wires from the limit switches one at a time and use a jumper wire to by-pass them. This won't tell you if they are bad though just if they are kicking off. If the water in the heater is that hot they are just doing their job.
Sort of a catch 22 but the best I can do from here. Hope this helps, good luck.
Oct 10, 2010 | Pentair Minimax NT Heater
I have a PacFab MiniMax 100 pool heater. The pilot remains on... but the burner will not ignite unless I hit/jar the heater. Any suggestions on what may need replacement or repair?
First thing to check is the flow switch. You can bypass it temporarily, and see if it lights. DO NOT OPERATE IT WITHOUTH FLOW SWITCH. If it isn't the flow switch, then it could be the thermostat or a bad connection on this low voltage millivolt circuit.
Jul 04, 2010 | Pentair Minimax 100 Pool Heater
Triton minimax 400 pool heater won't ignite
Make sure the gas valve is set to on and thermostats are set properly. Check the pressure switch and high limits for continuity.Check wires for signs of damage, etc..
Jun 27, 2009 | Pentair PUREX MINIMAX HEATER; THERMOSTAT,...
Jun 17, 2009 | Pentair 250k Minimax Ch Ng Mv Heater
Purex Triton Minimax 400 pool/spa heater not igniting
This sounds like you have a problem with your pilot. You can check this with a small mirror to see if their is a spark when you turn it on. If you have any soot build up on the pilot that will stop the spark and keep it from lighting also. If you have a short on your pilot wire this could be the problem also. I hope this helps, good luck.
Jun 05, 2009 | Pentair PUREX MINIMAX HEATER; THERMOSTAT,...
Pentair 250 CH LP will not ignite. Pilot works
to test the presure sensor jump the wires that plug in to the sensor if it turns on the presure sensor is bad and the the thermostat do you mean thermo sensor the one that checks the water tep follow the wires to were they plug in turn power off get your finger wet and put it were it plugs in on the 2 prong and turn it on the heater will light up if the sensor is bad
May 11, 2009 | Pentair 250k Minimax Ch Lp Mv Heater
Pentair 150k Minimax Ch Ng Mv Heater Logo
320 people viewed this question
Top Pentair Pool & Spa Experts
Jay Finke
Jay Finke
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
