After replacing circuit board in Mr Slim model MSH17TN, unit won't respond to remote (it displays as if communicating but no beep. Unit works using Emerg op switch. What's wrong?
  • 1 more comment
  • rivahvw Sep 16, 2010
    yes, exactly same circuit board.
    Batteries already replaced & display is responding (on, off, mode, etc) but does not beep which is the norm when changing the mode or temp. There are no lights on the remote.
    How do I find out if new circuit board has new remote code programmed in it?
    Please advise more possible solutions.
  • rivahvw Sep 22, 2010
    Circuit board was purchased from authorized reseller, Gemaire Distributors, Richmond, Va.
  • rivahvw Dec 07, 2010
    in case you experts would like to know what fixed the problem... per the invoice
    President:
  • 2,777 Answers
It is possible that the new circuit board has a different remote code programmed into it. The other more obvious answer could be that the remote's batteries have failed? Or did you say it is receiving the remote's output but just not adjusting correctly? Does the remote have lights on it that indicate it is "broadcasting" the signal? It was definitely the exact same circuit board as the one you replaced?
Thanks
Tim
Posted on Sep 15, 2010
  • Tim Grayson
    Tim Grayson Sep 16, 2010
    Where did you obtain the replacement board from? They would definitely have the information on whether the old remote would be compatible with this board. Hopefully it was an authorized reseller, or they may have no idea.
    I am researching further to see if there is any way you can tell, but to my knowledge only the manufacturer knows based on the boards serial number, what the remote code is for that unit...
    Let me know! I will continue to check here on my end to see what you can try, but I believe you may need manufacturer assistance / authorized reseller assistance.
    Thanks
    Tim
  • Tim Grayson
    Tim Grayson Sep 22, 2010
    Hmm, from what I have found you will need to check with Gemaire Distributors to see if they can advise to the remote codes, or if you need to reprogram or for some reason replace that remote. It should be working otherwise, it must have a different remote setup programmed into it.
    Tim
How do I get MR Slim out of standby mode
if unit is hard wired try turning circuit breaker off and then back on
Feb 14, 2015 | Mitsubishi Electric Mr Slim E12C26426...
How do i Turn off the beeping sound from mr slim ac unit? I've read all the manuals and searched the Mitsubishi site and the net extensively. Each time the unit is turned off or on, it emits a loud...
It requires surgery to remove the beeper :) seriously, find a local nerd to go in, not hard to do, and yank out the little piezo buzzer. I've had customer that wanted the same, factory said sorry no dice.
Sep 24, 2013 | Mitsubishi Mr. Slim MXZ30TN Air...
I have a problem code...its says check EO
Signal transmitting/receiving
error
(Indoor controller does not
respond to remote controller
signal.)
During individual unit control
1) Bad contact of transmission
wire
2) Signal transmitting/receiving circuit
is abnormal.
1) Check the transmission wire.
2) Check with another remote controller. If "EO" is
still indicated, replace the indoor controller
board.
If other check code appears. replace the original
remote controller.
P3 Signal transmission error
(Remote controller does not
respond to indoor controller
signal.)
wire
is abnormal.
3) Wrong operation due to noise
wave emitted
Nov 10, 2010 | Mitsubishi Mr. Slim MXZ30TN Air...
We have a Mitsubishi Mr Slim air conditioning unit, i've checked the circuit breaker, the remote works but the unit will not engage.
DOES IT DO ANYTHING I THINK ON THE RIGHT SIDE IF YOU HAVE YOU BOOK IT FLASHES ERROR CODES IF YOU HAVE THE COVER OFF
Sep 18, 2010 | Mitsubishi Mr. Slim MXZ30TN Air...
The unit does not respond to the remote, it seems that there is no power going to the unit. Have checked the service panel, replaced the bateries in the remote and I have tried the emergency start in the...
Check fuse in the AC machine panel. If power is available and still it does not respond, may the micro controller or infra-red receiver problem.
Take assitance from the service provider
May 27, 2010 | Mitsubishi Mr. Slim MXZ30TN Air...
Mr Slim split system with no display on remote control or unit display.
Mitsubishi Mr slim comes with no diplay on the indoor unit but there is small display on th eremote unit.for further help kindly send your air conditones complete model
Jul 09, 2009 | Heating & Cooling
Controller not working
The units were set up as master/slave by removing a jumper on the indoor board of the 0V unit. The CENTRALISED CONTROLLER display was removed by changing one of the indoor boards dipswitch settings.
Jun 10, 2009 | Mitsubishi Mr. Slim MXZ30TN Air...
What is the code p3 at Mr Slim thermostat
Signal transmission error (Remote control does not respond to indoor unit)
Causes:
Bad contact of transmission wire
Signal transmitting/receiving circuit is abnormal
Wrong operation due to noise interference by another appliance
Mitsubishi recommend replacing the transmission cables, the controller or the indoor board. Had the same problem myself one, I ran new temporary transmission cables. The unit ran no bother. Swapped the transmission cables for the original and the fault disappeared.
Jun 10, 2009 | Dometic Rooftop RV Air Conditioner
Mr.slim thermostat flashin and display p3
Causes:
Jun 10, 2009 | Heating & Cooling
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
