Question about HP LaserJet 4L Printer
A paper has wrapped around the roller. I can't get at easily. If I open it how can I reassemble?
    Problem Solver:
  • 16 Answers
I recommend you to check this:
http://h20000.www2.hp.com/bizsupport/TechSupport/DocumentIndex.jsp?contentType=SupportManual&lang=en&cc=us&docIndexId=64179&taskId=101&prodTypeId=18972&prodSeriesId=25486
Posted on Sep 15, 2010
There is a paper jam in my hp laserjet 3055 printer and I don't know where is the door of this printer to remove the anybody please help me out.
Remove the cartridge from the printer and look for the obstructing paper especially in the arms of the paper detector switches (2 nos. in the path). If you cant see any, the paper has most likely wrapped around the pressure roller / tafflon sleeve in the fuser. Carefully remove the plate just above the cartridge labelled "Caution Hot - Avoid Contact" (after the printer has been in power OFF mode and has cooled down) by removing the two screws on either side. See if the paper has wrapped around the rollers - remove and fit back the plate. In case of repeating problem look for damages to pressure roller and the tefflon sleeve. Have the fuser serviced in that case.
May 28, 2015 | HP LaserJet 3055 All-In-One Printer
Paper has jammed around something at the back. I can see it but cannot work out how to get proper access to it. I might be able to poke it out but I do not want to risk causing a greater problem. Can you...
it sounds like you have paper wrapped around your fuser. poking will cause greater problems as you will easily damage the rollers. if the paper is not easily accessed I would suggest contacting an authorised repair centre for a quote for the repair.
Jun 27, 2011 | Samsung SCX 4200 All-In-One Laser Printer
I have a Samsung SCX-4600, great machine but I've got a paper jam and I can't get at it - the troubleshooting guide is very helpful for jams everywhere except in this location - the paper has wrapped...
it sounds like it is wrapped around the fuser roller. is the roller around an inch or 2 around? if so it is the fuser roller and be carefull to no scratch this roller or you will get all jams. the fuser can be taken out with care to look at all the plugs and screws.
Jun 20, 2017 | Samsung SCX 4600 multifunction Laser...
Paper jammed message won't go away
Presumably this error follows an actual paper jam (whether the culprit has admitted it or not). The following is general advice that applies to paper jams in most printers, copiers, etc.
In my experience at least 98% of paper jam errors are because a piece of paper is still caught inside the printer. The remainder are generally due to a damaged paper jam detector (usually a small plastic arm which actuates a switch inside the printer) or less commonly a failure on the PC board which senses paper jams.
Please return to point 1 and look (again) for a piece of paper jammed in the printer. If the jammed paper was torn from the printer, only a small remnant has to remain inside the printer to generate an unclearable paper jam error.
Switch off the printer at the wall and unplug it. Remove the paper tray from the printer. Check to see if the printer has an access door in the rear to allow you to see inside (open it). Open any other external flaps (eg. manual paper feed tray) that will allow you to see inside. Open any internal flaps or levers designed for user operation and usually indicated with a green or orange coloured tab. Occasionally a page can wrap completely around a roller and be very hard to see. Be very suspicious of any 'white' roller' - check at the ends to note if the roller is actually a different colour with a complete page wrapped around it (generally then only removable by tearing other than complete disassembly by a professional). If paper was torn you may need a pair of tweezers and some determination to remove any small paper pieces wedged inside the printer. Ensure the printer is unplugged from the wall and avoid damaging any rollers or other parts inside the printer. Always remove jammed paper by pulling it in the direction of normal travel only. On rare occasions very serious paper jams may need expert service to dismantle and reassemble the printer.
After finding and removing all paper pieces, return all levers, flaps, doors, paper trays etc to original positions, reconnect power to the printer and test.
Mar 05, 2010 | Canon PIXMA MP170 All-In-One InkJet...
HP C4280 won't grab paper,tries then says out of paper
You need to clean the feed rollers. Open your HP Notification tray and check up some options. It's really intuitive so if you fiddle around a bit, you'll probably find an option to clean the feed rollers.
If not, dampen a cotton cloth and wrap it on a ruler and scrub the feed rollers yourself. Just look into the tray where you put papers and on the back you can find normally one feed roller on the right side. It's not that difficult.
Good luck.,
Feb 19, 2010 | HP Photosmart C4280 All-in-One InkJet...
Paper is jaming put in new toner just three days ago. the paper feeds part away and then wraps around the roller. We have doubled checked our loading of the new toner cartridge.
Hello sir; Is the paper wrap around heat roller ? if yes, then check the roller has 4 to 6 paper separation fingers does it function good, if not, please tell us which roller is?
Jul 30, 2009 | Samsung 4725FN Black and White Copier
Paper Jam that pulls paper to the right and crooked then get error message no paper
Hello
You have either a rubber roller that has gone completely bad or more likely there is something still stuck in the printer - probably a piece of paper wrapped around part of the feed roller. Open it up and examine carefully with a flashlight. If you can't find any foreign objects then wipe down all the rubber rollers with denatured alcohol.
Jul 28, 2009 | HP Photosmart C5180 All-In-One InkJet...
Clear paper jam in top feeder of HP 3055
IT HAPPENED TO ME, I HAD TO TAKE HP ONLINE HELP, BUT ACTUALLY U WILL HAVE TO OPEN THE WHOLE AFD LIKE LITERALLY UNSCREW IT OPEN CAREFULLY AND THE ROLLERS AND THEN U MIGHT MANAGE TO TAKE OUT THE JAMMED PAPER
Apr 02, 2009 | HP LaserJet 3055 All-In-One Printer
HP Photosmart 475 printer
The rollers should be in front of the printer. I have never opened one of these before but have worked on a Kodak. Try using a flat screwdriver with a cloth wrapped around it to clean the rollers. Just be careful not to damage the rollers with the sharp end of the screwdriver.
Jul 18, 2008 | Office Equipment & Supplies
Panasonic printer dp4520 error code j40
This indicates there is a paper in the fuser area(very Hot section be cautious).1. open the front door.2, open the left side door. look inside for a green plastic handle & lift up he metal guide plate sometimes the paper gets wrapped around the upper heat roller or curled up and around the separator claws. if so be very careful not to scratch the rollers or break the sep claws. there is a green handle/knob located in the machine that can be turned, this turns the fuser rollers and makes it a little easier to remove a fuser paper jam. After you remove the paper jam close all the doors/panels you first opened. the copier should reset itself. I have seen the pj errors change to a new one indicating another pj still exists. if so look again and remove as indicate by the Lcd screen. Please leave positive feedback if this helps
Jun 07, 2008 | Office Equipment & Supplies
HP LaserJet 4L Printer Logo
mukhtar21 shaikh
mukhtar21 shaikh
