Owners manual for lg wm 1285 fhd washing machine
2 Suggested Answers
TheMobilian
  • 8220 Answers
SOURCE: my LG1285 FHD washing machine will not complete final spin
Are you using the correct amount of the correct soap?
These machines struggle with soap overdose.
My notes:
You MUST use "HE" (High Efficiency-Low Suds) type detergent--but to use the correct amount.
Nearly all brands of "HE" detergent have incorrect instructions.
The correct amount is as follows:
HE: (2) Tablespoons Per Washload
HE 2X (double concentrated) : (1) Tablespoon
HE 3X (triple concentrated): (1) Teaspoon
This reduces/prevents:
1) Musty Odor
2) "LE" Error/Interrupted Cycle
3) L-O-N-G Cycle Times (longer than time displayed)
4) Insufficient Cleaning Results
5) Small Water Leaks from the air vent behind the washer or at the
front door gasket
6) Damaged Hall Effect Sensor (on 2007 or older LG washers)
7) Reduced Spin Speeds (laundry not spin-dried effectively)
Most consumers were doing what is *normally* the right thing to do, which is to follow directions on the detergent label. In this rare case--those directions should be entirely disregarded.
Additionally--in many LG washers--the liquid dispenser cup (blue cup) has a "MAX" line on the white siphon cap.
This was a very big *faux pas* on LGs part--this "MAX" line has NOTHING to do with measuring detergent and should never be used as a guide for determining correct detergent amount.
The "MAX" line indicates how much liquid must be in the blue dispenser cup before it DISPENSES from the bottom of the cup.
This is a very,very frustrating mistake that gives owners much grief.
After three months of incorrect type of detergent or incorrect amount of the correct detergent used--musty odor begins to occur.
After more than two years--a significant amount of soap scum/curd has accumulated in the washer. Odor-causing bacteria flourishes on this build-up.
It is imperative to remove this slimy residue. Tide sells a product called "TIDE WASHING MACHINE CLEANER" which is very effective.
Once a tub has become heavily contaminated--normal methods of performing a TUB CLEAN cycle won't "cut it".
Add the entire packet of "TIDE WASHING MACHINE CLEANER" directly into the tub (no laundry) and close the door.
Press and hold: SPIN SPEED & SOIL LEVEL buttons--then press POWER button.
Wait for door to lock.
Press the START button (6) times--this will fill the tub with hot water to the maximum setting when it stops filling.
Press the START button two more times--this will enable the tub to tumble.
After 3 hours--turn "off" the washer.
Turn the washer back "on".
Select the shortest wash cycle (usually "quick wash") and press "START". This will rinse out the tub.
This method of "TUB CLEAN" is *not* from a service manual but has been the best method for cleaning out LG washers more than a year into incorrect detergent useage.
After this--use the correct amount of "HE" detergent & perform a "TUB CLEAN" cycle every (4) months using the *tub clean* option on the control panel.
Most digital-controlled front load washers have a software feature that consumers are unaware of.
If excess suds is detected by the MAIN BOARD (which monitors motor electrical load during rinse & final spin) the "suds kill mode" will be enabled.
This causes the washer DISPLAY CLOCK to stall.
The washer makes an attempt to reduce/remove suds--usually a futile attempt--and ends the cycle much longer than was originally shown on the DISPLAY.
Posted on Jun 30, 2010
I have a LG INTELLOWASH m/c WM 1080 FHD and when it is spinning, it continually grinds, it sounds like the bearings are going, is this the problem?
yes more than likely put ure fingers inside thumbs outside and squeeze in and out any movement bearings r gone
Feb 13, 2015 | LG Washing Machines
WM-1280 FHD Machine stopped when about to spin. There is still some water in the drum up to door level. It displays error code OE. What does it mean ?
It means "Outlet Error", your drain pump impeller may be clogged with a foreign object. Just open your easily accessible drain filter (indicated in your manual) and remove the object. If no object is found, it could mean that you'll have to replace the drain pump -> purchase one here: www.appliancespareswarehouse.co.uk/
Good Luck!
* If you found this solution helpful, please vote positively. A 4 four thumbs up will do nicely too :-)
Feb 23, 2011 | LG Washing Machines
Where can I get an owners manual for this washer?
Hi
You can download the manual for your washer from this link---
LG WM2277HW Washer's Manual
Please post back for any further assistance.
Daniel
Jul 30, 2010 | LG WM-2277HW Front Load Washer
Can't get beyond the filter to get objects out
You could fry blowing hard down the the outlet hose, this may dislodge it.
The only other way would be to remove the pump from the washer, and retrieve it that way.
Hope this helps.
Jan 22, 2010 | LG WM-1480FHD Front Load Washer
Need link for manual for LG washer WM 1812 CW
You could download the manual from ;-
http://safemanuals.com/user-guide-instructions-owner-manual/LG/WM1812CW-_E
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Oct 30, 2009 | LG WM-1832C Front Load Washer
No water going in , display says IE
Check the water inlet valve assembly. I will attach a photo for reference. First, remove the water suppy hoses and check the small screens inside the water inlet valve and make sure they are clean and clear. Then use a multimeter to test the solenoids for continuity. A lack of continuity indicates a faulty solenoid and the water inlet valve will have to be replaced. Sure hope this helped and best wishes.
Aug 06, 2009 | Washing Machines
I'm looking to find acopy of the owners manual
au.lge.com
Go to this site and download the pdf file for your
model
Jun 13, 2009 | LG WM-3677HW Front Load Washer / Dryer
Intellowasher WM-1460 FHD
Try cleaning out the drain filter and see it that fixes it.
Nov 17, 2007 | LG WM-1832C Front Load Washer
"CD" ERROR ON LG WM-3677HW Front Load All-in-One Washer / Dryer
CD means cool down, press the pause start button, the door lock will open. It is an anti crease cycle. It mentions it in the owners manual, but it is hidden deep in the drying section.
Sgt 48
Sep 01, 2007 | LG WM-3677HW Front Load Washer / Dryer
Washing Machines Logo
195 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
