Question about Syntax Olevia 327V 27 in. LCD Television
Hi, I have a olevia 37 in model 337-B11 and all of a sudden the tv urned off like i hit the remote...i turned it back on it turned back off in like 3 mins.. no damage and pic and sound are fine
  • 45 Answers
SOURCE: Purchased TV without stand
You could try calling this number 866-965-3842 its a 3rd party repair center that services Olevia televisions.. but they might be able to sell you a stand..
Posted on Jul 31, 2009
tvtek
  • 1284 Answers
SOURCE: The HDMI port on my Olevia Model 337-B11 LCD tv
Without replacing the main board, probably not. Did you try another HDMI source to verify the TV is at fault? If it is the cheapest fix is to use component only.
Posted on Sep 10, 2009
Testimonial: "Thanx for the quick response! Plan A is to use component/S-Video inputs but plan B is replace the board, if I can find one. Thanks Again!"
SOURCE: Cannot pmy "Direct TV Satellite Remote, so I can control TV Sound
10178 or 11331 or 11610, depending on the model of your remote.
Posted on Sep 24, 2009
dave1645
  • 834 Answers
SOURCE: I have a olevia 337-B11 HD-ready TV, which kind of
you need a quam tunner your best bet would be to get the box from your cable company set toop boxes are not cheap for hd
Posted on Nov 28, 2009
Testimonial: "thanks for the info."
SOURCE: Olevia Hi Def tv 242TFHD, won't turn on. Power
yes the capacitors your looking for are a 1000uf , 1500 uf , and on the other side of the heatsink a 680 uf. the tops will be slightly bowled. replace those with same type !not brand!, and youll be happy.(same thing happened to me, less than 2 years old also).
Posted on Dec 04, 2009
Olevia model #337-b11
replace power supply! board
Jan 21, 2013 | Televison & Video
Olevia 542-b11 LCD HDTV won't turn on. Blue light blinks twice
My Olevia 42" television is several years old. In March of 2012, the infamous "TV will not power on" problem started.
The blue LED light on the front of the TV would go off for a split second, then light up again. The television would not start.
If you are handy with small tools and a soldering iron, you can change the capacitors on the power supply. My Olevia is a model 542-B11.
I bought the repair kit off eBay from seller: sghill99
As of this writing, the seller has sold 37 of these kits. The title of the auction is: Repair Kit, Olevia 542-B11, LCD TV, Capacitors
And if the url is still active, it is: http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=230554940338&ssPageName=ADME:L:OC:US:3160
I made the repairs in March 2012 and it is now August 2012 and the television is still working great. It is turned on and off several times every day.
Oct 25, 2011 | Olevia LT42HVi 42 in. LCD Television
My Olevia 37" LCD HDTV suddenly will not turn on.
power supply board is damaged,only working with standby power
Aug 15, 2011 | Olevia LT37HVS 37 in. LCD HDTV
My 37 inch Olevia that is 3 or 4 years old is stuck on a very loud, so loud I have to turn it off, but I can't access the volume on the remote or on the TV, it is so weird! The remote does work to turn...
When you have strange problem like this, power supply module will be the first thing to check for steady DC. Since this company is no longer around and parts are getting hard to come by, the repair shop will not even try to do component level repair on it due to time consuming process and no schmatic available.
There may be not much you can do.
Parts: http://www.shopjimmy.com/catalogsearch/result/?q=Olevia+LT37HV+
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Jun 14, 2010 | Olevia LT37HV 37 in. HD-Ready LCD...
I tryed to connect coby speaker (model number - csp42) up to my olevia 337-b11 tv and i can only hear sound through the bulit in speakers in the front of the tv and not out of the coby speaker! the coby...
Does your TV have an Audio out? This is the only way that you can get signal to feed to your coby speakers and make sure that your coby speakers has an amplifier.
Apr 03, 2010 | Olevia LT37HVS 37 in. LCD HDTV
Hi I am in Toronto Canada and have a model 337-b11
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hi
Most likely a power supply component has aged and thus changed value and/or failed. Take it to a reputable repair person
Mar 13, 2010 | Olevia LT37HVS 37 in. LCD HDTV
The HDMI port on my Olevia Model 337-B11 LCD tv quit working. Is there an easy fix?
Sep 10, 2009 | Olevia Televison & Video
Olevia 237V Backlight problems
Voltages do not dance around and should be constant and within stated parameters.. The board producing those crazy readings is the issue.
Mar 12, 2017 | Olevia LT37HVS 37 in. LCD HDTV
Olevia 337-B11 how to connect to a TV
Unfortunately, This hdtv can only use with receiver. There is no cable connection back of it. You may connect it using with HDMI cable.
Nov 30, 2008 | Olevia LT37HVS 37 in. LCD HDTV
Olevia 337 B11 Power Problem
Olevia sugested repl. the Main board
Mar 05, 2008 | Olevia LT37HVS 37 in. LCD HDTV
Syntax Olevia 327V 27 in. LCD Television Logo
125 people viewed this question
Top Syntax Televison & Video Experts
Computer Repairing
Computer Repairing
Kolbrun...
Are you a Syntax Televison and Video Expert? Answer questions, earn points and help others
