Question about Britax Evolva 123 - Prague
I have lost my instructions. How do I adjust the seat from stage 1 to stage 2?
  • 419 Answers
If you email userguides.uk@britax.com you can request the manual to be emailed to you.
Hope this helps!
Posted on Sep 15, 2010
TORQUE SETTINGS FOR 1.4 16V 04 VAG ENGINE THEY USED IN SEAT LEON 04 16V 1.4.
Cylinder head instructions
Tightening sequence
Cylinder head torque setting for 2004 VW 1.4L 16V fitted in Seat Leon
Renew bolts
Stage 1 = 30 Nm
Stage 2 = 90 degrees
Stage 3 = 90 degrees
May 17, 2011 | 2000 Volkswagen Golf
Hi,just got a dynojet stage 1/3 kit for my 1980 honda cb650, it's on standard air box, but 4 into 1 exhaust, I take it I should use the stage one kit. Also I have no instructions can you help...
Intended for motorcycles with a stock engine using the stock airbox, air filter and stock pipe. Stage 1 kits are fully adjustable to allow the use of a well designed aftermarket pipes and stock replacement air filters like K&N. Stage 1 kits are designed to improve throttle response and driveability and in most cases power increases of approximately 5% throughout the entire power range can be achieved.
STAGE ONE INSTRUCTIONS
1. Remove the vacuum slide from the carbs. Remove the stock needles & spacers, noting the order of
assembly. Locate the slide lift holes (Fig. A), with the slide drill DD# 14 supplied, enlarge your slide lift
holes. The picture may not show your slide exactly, enlarge your slide lift hole or holes depending on your
model. Do not drill any new lift holes. Do not drill the needle hole.
2. Install Dynojet needles on groove #4, using all stock spacers. Install the Dynojet washers (2 per
needle) above the E-clip.
3. Remove the stock main jets and replace with the Dynojet main jets provided. If you are running with
stock exhaust, use the DJ110 main jets. With an aftermarket header or slip-on with high flowing baffles,
use the DJ116 main jets. Be sure that the jets you are changing are the main jets.
4. Locate the fuel mixture plug (Fig. B), if you see a screw head, proceed to adjusting procedure. With the
DD #5/32 drill bit provided, carefully drill thru the plugs. Note: the mixture screw is directly underneath this
plug, be ready to pull back on the drill the instant you break thru. Use screw provided to secure and
remove the plug. Carefully turn mixture screws clockwise until they seat, turn out 3 turns.
For further info on this, visit: http://www.dynojet.com/jetkits/motorcycle/honda.aspx
You can find the manual for the model you are searching for. Follow the 1st column "CC" to find 650cc models and you can find your specific model after that.
Thanks for asking.
Regards,
Arvind S Iyer
Oct 15, 2010 | Dynojet Cycling
My 1986 gsxr 1100 has a stage 3 jet kit with k&n filter on each carb it keeps messing up the #1 spark plug after i stop riding it for the day. have to replace eveytime i ride.
if its fouling out then you need to move the needle down or use a smaller jet. Stage 3 are a full rich adjustment. Maybe fo to stage 2,
I lost 40 miles to the tank when I put a stage 2 in my 1100 sabre. Regained half that when I adjusted the needle and came down one number on the jets.
May 09, 2010 | Suzuki GSX 1100 GP Motorcycles
3 in 1 Exersaucer Pond Stage 3
Go to www.evenflo.com. Click on your product at the top and then on the right side there is a "related link" for product instructions. You will need your Model # and Manufacture date (which is on the seat of the Exersaucer). Then it will list all the parts available for that product. Almost all the way down is a pdf version of the instructions that you can download for free. I used it and was able to assemble my Exersaucer to the 3rd stage. Good Luck!
Dec 22, 2008 | Evenflo ExerSaucer SmartSteps ABC Stroller
Lost instructions
please call a ParentLink Representative at 1-800-233-5921, Monday - Friday from 8 am to 5 pm.
https://plweb.evenflo.com/replacement_parts.aspx
This is the link to the evenflo toy site, it gives the instructions to call and talk to an agent. Hope this solves your issue. I don't have the toy.
Nov 11, 2008 | Evenflo Generations
Nania 3 in 1 carseat
i have lost instructions for nania 3in1 ihave got all the straps but cant put i t together can i download instructions please help
Aug 10, 2008 | Nania Nuevo 3-in1
Car seat manual
You have to go here: http://eddiebauer.djgusa.com/instructions/
May 25, 2008 | Eddie Bauer 3-In-1 with Latch
Evenflo 3 in 1 Exersaucer Triple Fun
https://plweb.evenflo.com/product_search.aspx?txSearchModelNo=6231711&txSearchDOM=1/1/2008
Look here it has the instructions.
May 23, 2008 | Evenflo Generations
Jane Matrix Cup car seat
The best instructions I have found (as I have the same car seat!) were on YouTube. These instructions are really clear as they are in video format and they show you how to fit the seat in both the lie fat and rear facing mode.
In terms of the harness, you may or may not be aware that there a number of adjustments that can be made. The first is that you are able to adjust the positioning of the straps within the seat so that the child is not overhanging the seat. In addition the straps themselves lengthen by adjustment with the buckles on the straps.
I think all of these adjustments are in the instruction manual, which is available on line from the manufacturer if you have lost it.
Hope this helps!
Feb 08, 2008 | Baby Gear
Infant Rear facing car seat
ON THE BACK OF THE CAR SEAT ARE TWO LATCHES SIMPLY REMOVE ONE BY PUTING THE STRAP THROUGH THE LATCH AND ADJUSTING IT TO YOUR CHILD FIT DO THE SAME TO THE OTHER. LET ME KNOW IF I WAS ANY HELP...
Jun 01, 2007 | Evenflo Embrace
Britax Evolva 123 - Prague Logo
187 people viewed this question
Top Britax Baby Gear Experts
thegtw
CheckitRight
CheckitRight
Jennifer Rock
Jennifer Rock
Are you a Britax Baby Gear Expert? Answer questions, earn points and help others
