Question about Lexmark X5470 All-In-One InkJet Printer
Power will not come on. OUtlet is good. - Lexmark X5470 All-In-One InkJet Printer
  • Official Brand Answer
  • 3,344 Answers
Unplug then replug power adapter from the printer. The power adapter is the black rectangular box behind the printer where the power cord is attached. Make sure the power cord is properly secured in the power adapter. Press power button if it doesn't power on automatically. Plug printer straight to power outlet in the wall. Bypass surge devices or power strips as they tend to draw away power from the printer. If no go, try to plug it to another known working power outlet. If problem continues, contact Lexmark technical support for further assistance.
Posted on Sep 15, 2010
No power give me a soluition
check to see if your fuse is good usually on the back panelwhatever it takes you have to find out if there fuses good or not
Oct 06, 2014 | Mackie SWA1501 Subwoofer
LG LDS5811BB power cord is good, however the dishwasher is not getting any power. No lights no nothing.
There is a fuse on power unit, that should be tested first, check also a different outlet.
Aug 09, 2008 | LG Dishwashers
Gateway zx4970 all in one will not power on
Sounds like your power supply might be shot. New egg is a good site to get a new one.
May 05, 2014 | Gateway Computers & Internet
No power won't turn on
Make sure the unit is plugged into a good outlet or power source and that the cord is OK. If so, perform surgery to find cause of power loss. If not, plug into good outlet or replace power cord.
Mar 16, 2014 | Samsung Heating & Cooling
The power plug inside the center console has no power at the plug. The fuse is good. Why is there no power to that plug?
Sometimes the wire on the bottom side of the outlet comes loose. Remove the out let and check the wires. If the wiring is good, check with a test light or meter and see if you have power at the outlet. If there is power there, replace the outlet, If not, check the wiring back to the fuse box
Apr 04, 2013 | Cars & Trucks
Auxiliary power outlet won't work. Fuse is good.
If all wires, harnessesand ground connectiosn are good, defective outlet.
Mar 04, 2012 | 2006 Pontiac Grand Am
I have a light switch in my apartment that controls both the light in the kitchen and power to both sockets of a dual outlet. How do I adjust the wiring so that the outlet is always powered? The wiring...
This is not good wiring option. It is not good to have light and outlet on the same switch without different fuse. I suggest to insert another little switch on light connection. Than you can have control of both. Or you must find main phase (hot wire) inside switch box. This will be always on for tester when you try different switch position. When you find this main (hot) wire, you disconnect one of another two wire (after you disconnect power), than give power on and test light and socket (one of them will not work). If this is outlet, you must connect this wire to main (hot) one. Don't work when power on. Just test it with tester, and than disconnect when you change position of wire.
Good luck and be careful!
Aug 26, 2011 | Electrical Supplies
2006 Dodge Dakota - power outlet doesn't work. The #28 fuse checks fine.
Take a 12v test light and wrap the probe with electrical tape, leave about
1/4" exposed. With the key on, ground the test light wire and insert the
probe into the outlet and touch it to the center power contact. If the light
stays out and you have a good ground, you don't have +power at the
outlet. If the fuse is good, you may have a bad wire or socket. But if it
lights up, we go to the next step. Touch the probe to a known +power
source and ground the wire to the metal side in the outlet. If you don't
get light, check the ground for the outlet socket. Repair as needed.
If it lights up, then you know you have power and ground. Check the
plug on the device you're trying to use. I hope I was of some help.
Good luck.
todytwo
Feb 04, 2010 | Dodge Dakota Cars & Trucks
Fuses seem to be in tact but power outlet doesn't work. What next?
if the fuse is good, then remove the outlet and check for power and ground at the outlet. If they are both there, then you need to replace the outlet. Also sometimes the outlet won't get grounded off of the casing so it won't work, which you also need to replace the outlet. nine out of ten times you replace the outlet.
Oct 08, 2009 | 2008 Lexus Rx 330
The power outlet under the cup holders
check these fuses:
under the hood fuse panel:
#23 - auxiliary power
#25 - ac/dc inverter
instrument panel fuse panel:
#29 - retained accessory power
if these fuses are good and they have power at the fuse panel, the outlet itself may be bad. if your inclined and you have a test light you can check to see if the outlet has power going to it by probing the wires on the back of the outlet if you can get to them. test the red and white wire for 12v positive and test the black wire for a good ground. if those wires test ok then it its the outlet itself that is bad. if the wires do not test ok then there is a break in a wire somewhere which will have to be traced and repaired
Oct 29, 2008 | 2007 Chevrolet Uplander LS Minivan
Lexmark X5470 All-In-One InkJet Printer Logo
139 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
