Question about Kitchen Ranges
I need a wiring diagram for a Kenmore oven model 790-96429407
  • donmarber Sep 15, 2010
    Thank you....where did you find this???? You are awesome
    President:
  • 1,554 Answers
Here's your wiring schematic and wiring diagram. Click on the links and you will be redirected to the wiring schematic and the wiring diagram then click on the image to enlarge the view.
Posted on Sep 15, 2010
I need a parts diagram to replace the right front surface heating element of a Kenmore range, Model 629-45775
Does the element have continuity? if so, it will be the element switch that needs replacement... Generally, the radiant element will be held on by two screws and a steel plate, note the wiring before removing the old part. Definitely remove power to the machine before doing anything inside of it... Kenmore Range Stove Oven Surface Element Switch WP7403P239 60
Kenmore Range Stove Oven Radiant Surface Element 12002141
May 25, 2016 | Kenmore Kitchen Ranges
Kenmore refrigerator model 25378832790
WIRING SCHEMATIC Diagram and Parts List for KENMORE ...
www.searspartsdirect.com/model-part/25360132993/0582/.../00005.html
WIRING SCHEMATIC diagram for model # 25360132993 Kenmore-Parts Refrigerator-Parts (11). Full Size ... Refrigerator ice door insulation Part #: 5303917276.
WIRING SCHEMATIC Diagram & Parts List for Model ...
www.searspartsdirect.com/model-part/25331614100/0582/.../00005.html
WIRING SCHEMATIC diagram for model # 25331614100 Kenmore-Parts Refrigerator-Parts (8) ... Refrigerator freezer door hot tube repair kit Part #: 5303918222.
WIRING DIAGRAM Diagram & Parts List for Model ...
www.searspartsdirect.com/model-part/2536580250a/0582/.../00006.html
WIRING DIAGRAM diagram for model # 2536580250A Kenmore-Parts ... Refrigeratordoor hole plug Part #: 240479601 Substitution: 240494001 Learn why ...
Kenmore refrigerator model 25378832790 - Fixya
www.fixya.com/support/t26040123-could_get_schematic_above
41 mins ago - Kenmore refrigerator model 25378832790 Where can I get a ... awiring schematics for a GE Refrigerator model TCC18JAAC type LB18,. Jul 29 ...
Jan 05, 2016 | Refrigerators
I have a kenmore model 790.46893900 glass cooktop 0ven and i need to no where each of the 6 wires hook up exactly? they are the wires in clock and control digital display.
There is an old saying amongst Technicians. If you don't have a wiring diagram, mark every wire where it goes before you unplug them. The oven should have a wiring diagram somewhere behind one of the covers. If it doesn't, you may need to contact Kenmore or one of their Agents to see if they have a service manual detailing the wiring connections. Sorry , but I don't have any info on Kenmores. I don't think they are sold in Australia.
Sep 15, 2015 | Kenmore Kitchen Ranges
What does the F93 code mean and how do we fixt it
i know that it can be very difficult to have issues with your oven. the f93 on this model of kenmore range indicates that you have a problem with the oven door lock assembly (see image below). this can be caused by a failed oven door lock assembly, a wiring failure or a bad electronic oven control board.
i recommend that you unplug the range and check the wiring between the components first. you can remove the upper back panel of the range to access the electronic oven control board in the console. you may need to remove the lower panel to access the door lock assembly on the back of the range. the image below shows the wiring diagram and other information that should help you check the wiring connections. check for a mechanical binding of the door lock assembly as well. if the wiring connections are okay, you will likely need to replace the oven door lock assembly. if you need further assistance, please reply to this thread. thank you for using manage my life.
May 23, 2015 | Kenmore Elite 30" Slide-In Gas Range White
I need a wiring schematic for a Kenmore model 79040522400 wall oven . Control panel the five wire that hookup on side for broil, bake, etc
diagrams are inside the control panel, usually in an envelope to the left or right side of center. If not there, look on the top or rear panels as they may be adhered to either of those. Worst case is someone took them from the unit during service in the past and never replaced them. Last option is to look online at sears parts direct. They show the diagram, but it is not clear.
Jan 26, 2015 | Kenmore Ovens
91136669891 HAS ERROR CODE F2 F3
Are you sure about this error? The 91136669891 was made by Whirlpool for the Kenmore line. The 4 character codes for these ranges are F# E# (not two Fs).
Depending on which error you are actually have see below.
If the code includes F3 then you have a problem with the oven temperature sensor (F3 E2 would be temperature too high). You need to replace the sensor. Sears Parts Direct has the sensor for $74.12: http://www.searspartsdirect.com/partsdirect/part-number/Kenmore-Parts/Range-Parts/WB21X5301/0022/364/Model-91136669891/0582/0124250?keySuffixId=NA&pathTaken=partSearch&pathRender=modelComponent&documentCompId=P9040087&diagramPageId=00005&productTypeId=x&searchModelNumber=91136669891&subCompDesc=Body&brandDesc=KENMORE&modelDesc=30 . The complete diagram of the oven parts is available here: http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Range-Parts/Model-91136669891/0582/0124250/P9040087/00005?blt=06&prst=&shdMod= . The sensor is part 253.
If the code includes F2, then double check the second code. Whirlpool has no F2 E3 error that I know of. However, F2 errors tend to be a problem with the keypad. Check the wiring connection between the keypad and the control. This should be firm. Then press Cancel. If the error persists, you need to replace the keypad. See http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Range-Parts/Model-91136669891/0582/0124250/P9040087/00001?blt=06&prst=&shdMod= for the parts diagram and prices.
I hope this helps.
Nov 23, 2011 | Kenmore Kitchen Ranges
Steel stick inside Kenmore electric oven
you can go to www.searspartsdirect.com . and input your model numver to view the exploded parts diagram.it is sometimes diffcult to give great advise with out visually looking at the machine
Apr 01, 2010 | Kenmore 30169 Electric Single Oven
Electric Diagram for Kenmore Model 790
Has the oven run out of control or gotten too hot? The 790 series is made by Frigidaire and those fault codes are F0 to F8. F2 indicates the temperature sensor is reading too hot. Now with the double oven models, some manufactures add an extra digit to the fault codes to indicate which oven created the fault.
Your most likely fix is to replace the temperature sensor. The most probable locations for the wiring diagram is taped inside the bottom drawer, on the back or under side of the oven, or behind one of the panels on the back of the oven. This might tell you the room temperature resistance for the temperature sensor so you can test it with an ohmmeter and be sure that it is faulty. Try Appliance Parts Pros for replacement sensors.
Jan 09, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Thermostat for kenmore oven wiring
Here's a link for you: http://www.partselect.com. You can put in your make and model and get diagrams of your appliance and see how things connect. Good luck!
Jul 14, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Kitchen Ranges Logo
658 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
