Question about Whirlpool Washing Machines
The control lock is on. How do I get it off. I have model #GHW9150PW1
    President:
  • 1,554 Answers
The control can be unlocked by pressing and holding the End of Cycle button for 3 seconds or until the Control Locked indicator turns off. Unplug the machine for at least 30 minutes to forcibly reset the control and make sure and eliminate the possibility of an electronic glitch if the End of Cycle button does not unlock it. Replace the control if unplugging and the End of Cycle button fails to unlock it.
Posted on Sep 15, 2010
3 Suggested Answers
jsrock516
  • 5911 Answers
SOURCE: My control panel is locked on my Duet Wirlpool
This may or may not be an indication of a serious problem. In the majority of the cases, this is a simple operator error. Nearly all these model appliances have some sort of Control Lock feature on the front panel now. This is a designed safety feature that is used to prevent small children from manipulating the controls. The controls can be easily locked or unlocked by pressing and holding the following button on the front panel:
Whirlpool Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 3 seconds.
Kenmore Elite Dryer - Press and hold the AUTO DRY LEVEL button for 3 seconds.
These instructions may not be all inclusive for all Kenmore and Whirlpool models, but they are the most common. Chances are, if you have a Control Lock feature, the instructions will be printed on the front panel adjacent to the button that is required to lock or unlock the controls.
NOTE: These instructions may also work for newer model Maytag, Hotpoint, Admiral and Fridgidaire model front loaders as well. Refer to your owner's manual or front panel for instructions pertaining to your sepcific model.
If the Control Lock feature will not lock or unlock the appliance, unplugging the unit for AT LEAST 30 minutes is recommended in order to reset the main control board. In many cases this is all that is required to correct momentary glitches.
If this does not solve your problem, or if you have additional questions, please let me know.
Posted on Jul 09, 2009
  • 6 Answers
SOURCE: Whirpool Duet Washer Model GHW9150PW1 Control Locked
I had the same exact problem, the answer is in the User's Manual for this model Dryer, also here: The Users Manual reads: "TO UNLOCK": Press and hold the END OF CYCLE button for 3 seconds to turn this feature off. I did this and it worked perfectly the first time! My first load is drying now after months of being without the dryer (too busy to investigate!). Good luck.
Posted on Jan 04, 2011
Manual for Whirlpool front load washer #GHW9150PW1
Many Whirlpool appliance manuals are available here: http://www.whirlpool.com/manuals/ . Use the search function to find your model. The direct link to the manual for the GHW9150PW1 is currently http://www.whirlpool.com/digitalassets/MLPDF/Use%20and%20Care%20Guide%20-%208182674.pdf . Sears Parts Direct also has the manual; the direct link is http://c.searspartsdirect.com/mmh/pd_download/lis_pdf/OWNM/L0606369.pdf .
I hope this helps.
Oct 17, 2016 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool front-loading automatic washer problem
yea replace the ccu and the mcu more than likeley the mcu will do it tho
Jul 28, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Oct 26, 2009 | Whirlpool Washing Machines
My control panel is locked on my Duet Wirlpool washer model # GHW9150PW1 how do I unlock it?
Jul 09, 2009 | Whirlpool Duet GHW9150P Front Load Washer
WHIRLPOOL DUET MODEL GHW9150PW1 doesnt complete wash cycles
FO2 is the code for long drain. The filter on your pump is probably clogged with lint and stuff. You have to remove the bottom front panel, 3 torx screws underneath. The panel will drop and come off. Drain off the excess water from the drain pipe you see. The white filter cover is right in front. Get yourself a good plastic bag to collect water. Unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in carefully.
Apr 04, 2009 | Whirlpool Washing Machines
Whirlpool Duet Washer GHW9150PW1
Swich off the machine, try some WD40 on the door mechanism (on machine lock, not on the door) and open & shut for a minute or two. Then try the machine, spin only just to try.
Rate pl, if solved, or dont!
Mar 04, 2009 | Whirlpool GHW9150 Front Load Washer
The "control locked" light on my ge whirlpool stays lit and
its in small print under one of the buttons. I can't remeber which one it is either. usually you will see a pad lock symbol press andhold tha key down for 3 seconds
Jan 04, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Ghw9150pw1 would not start
This advise is for Kenmore Elite and Whirlpool Duet front loader washers and dryers with a Control Lock problem.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Aug 21, 2008 | Whirlpool GHW9150 Front Load Washer
Washing Machines Logo
96 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
