Question about Bosch 24 in. SHX46A02 / SHX46A06 Built-in Dishwasher
SHX46A02UC dishwasher will not complete cycle. Just installed new circuit board. Will also run with door open. Seems to be stuck in drain mode.
  • Bosch Master
  • 19,396 Answers
Test the door switch and its wiring. The dishwasher is supposed to stop when door is open.
About drain pump, check the pressure switch and eventually replace it(pressure is water level, this is not the float, that is usually overfill-if there is no pressure switch, check float). That is the device that detects if drain is over, stopping the drain pump.
Posted on Sep 15, 2010
Dishwasher starts on its own (no house is not haunted). Start resume button flashes
have a service technician in as it appears to be a problem in the program board
could be moisture across the circuit board
Feb 06, 2016 | Maytag MDB7749AWQ Builtin Dishwasher
Why is my countertop dishwasher stuck in drain mode(s), and won't initiate or complete any wash cycle?
normally if a dishwasher fills then pauses it is trying to read the water level if it fills again it is trying get a reading from the pressure switch when it cant determine the water level it will drain to prevent it leaking, however you should get a error code for this kind of fault which makes me think it is the control board which is at fault by not being able to read the sensor rather than the sensor itself not working
Oct 08, 2014 | Dishwashers
Bosch dishwasher shx46a06uc-30
the unit will try to complete the last command it was engage in before it went in the overfill safety mode. you must perform a cancel drain cycle to reset unit to default setting. Remember the drain cycle is 2 min and must be completed to reset main control. however if it went into a overfill status you have a leak and it generally comes from the pressure chamber on the lefthand side of unit where the water enters tub
Apr 17, 2012 | Bosch 24 in. SHX46A05UC Built-In...
Whirlpool gu1200xtls2 wont drain just stopped
Hello
your Whirlpool dishwasher stopped draining mid-cycle, check your circuit breaker or fuses. The cycle won't complete if the power is interrupted. Reset the circuit breaker if tripped, or change out any blown fuses. Fully close the dishwasher door, and restart the cycle if you opened up the door. If you have not used the dishwasher in a while, the motor may be stuck. Open up the main housing, and rotate the motor until it turns freely. You must replace the motor if it's corroded or won't move since it's unlikely that you can fix it.
Pump
The pump is located underneath the lower rack and spray arm. This component is responsible for pumping water out of the dishwasher once the cycle is complete. If the pump isn't working, verify that it is not clogged with debris. Use a toothpick or plastic utensil to remove food particles from it. Check the pump impeller. If a section of it is broken, get a new pump since the impeller is difficult to fix.
Clogs
Clogs in the air gap or drainage hose prevent water from leaving the tub. Clean these components and the water inlet filters, if dirty. Examine the drainage hose, and straighten it if it's kinked. If the hose is badly crushed, you must replace it. Unscrew the drainage hose from the dishwasher to clean it, but reattach it before you restart the cycle. Run the food waste disposer if it's connected to your Whirlpool dishwasher. Remove the knockout plug from the disposer if you have just installed the disposer or dishwasher.
Drain Valve/High Drain Loop
Whirlpool dishwashers have drain valves with an internal solenoid. This valve opens and closes to drain water out of the tub. If the drain valve is stuck, lubricate the lever, and remove any debris clogging the valve. Remove any objects that are preventing the drain valve from freely opening and closing. If the valve is not working properly, you must replace it. Always install a high drain loop to prevent water from the sink entering your dishwasher. Create a loop of the drainage hose that is at least 18 inches high. Attach this hose beneath a section of cabinetry.
Sep 28, 2011 | Whirlpool Dishwashers
Dishwasher not draining water. Not 100% sure on exact model, can't find any number or ID marks. Definitely Frigidaire though.
the model number is or should be located on the right side of the.cabinet where the door opens.any how the problem could be a clog in the drain hose. you can remove the hose from the side of the garbage disposal.use a shop vac and try and drain the water that way if it does not drain then you could have a grease clog if there is grease clogging it use a blow dryer to heat the hose up and this should remove
the clog.if the water does come aut the you may have a bad drain pump and or a control board.
Jan 24, 2010 | Frigidaire 24 in. FDB635RF Built-in...
Bosch dishwasher continues to run (Model SHX46A02UC)
This is too common a problem with these units. I have written a guide to help folks out with it. Find it here.
Jul 11, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch SHX46A02Uc/21
it is likely a control module issue. I will take mine apart this weekend to verify what others have said: solder joint on circuitboard burns out from possible overheating, and DW doesnt go into rinse cycle. Try rinse and hold cycle to see if it stops on its own. mine does, but the other cycles which require the rinse to go to 156 degrees do not; the continue to run until I cancel and drain.
Feb 01, 2009 | Dishwashers
Bosch SHX46A02UC-21
float switch is in the flood position and the drain pump is running.. there is water under the dishwasher or that switch is stuck up..
Aug 19, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch built in dishwasher model # SHX46A02UC
sounds as tho you have a foreign object stuck in the drain pump. only solution is to remove drain pump and check
Jun 24, 2008 | Bosch Dishwashers
Bosch 24 in. SHX46A02 / SHX46A06 Built-in Dishwasher Logo
181 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
