Question about ADVANTAGE Waterway SVL56 Pool Pump SVL56E115 Impeller 15 Hp 3103660
Im getting a loud buzzing noise when the pump is running
    Novelist:
  • 116 Answers
Could be an obstruction in the impeller, or the bearings going out. You can split the pump in two be removing the large clamp or 4-6 bolts holding the two halves together. (not the 4 bolts holding the motor to seal plate, but the the bolts holding the seal plate to the seal plate housing. once you remove the clamp or bolts, the motor with seal plate and impeller and diffuser can all be pulled back away from the pump. You need to remove the diffuser (plastic housing that goes around the impeller) usually by a series of 3 to 6 small screws. Now you can easily try and spin the impeller and check for obstructions that might have bound it. If you do not see anything stuck in the impeller, then the noise is likely coming from the motor (probably the bearings) you can replace the motor, or have it rebuilt. if your not gunna rebuild it you can deal with it as long as the noise doesn't bother you and the motor is not getting too hot
Posted on Sep 18, 2010
When microwave is started, why does it make a loud buzzing sound--like a Skil saw sounds?
Whirlpool Microwave Buzzing Loudly - ApplianceBlog
www.applianceblog.com/.../26531-Whirlpool-Microwave-Buzzing-Loud...
Aug 12, 2011 - 10 posts - ‎2 authors
My Whirlpool MT4155SPS-2 microwave oven has recently started to buzz loudlywhen operated. The sound is getting louder and more frequent ...
Whirlpool making intermittent loud buzzing noise Microwave ...
www.fixya.com > ... > Microwave Ovens
Whirlpool microwave ovens making intermittent loud buzzing noise related questions and answers. Ask your ... ...loud buzzing noise and it doesn't heat. i just tried it again and let it run for 1 minute. ... Question about Accuwave Microwave Oven.
Troubleshooting the Microwave: Potential Problems ...
www.appliancejournal.com/.../troubleshooting-the-microwave-potential-...
If your microwave buzzes loudly and produces no heat you probably have a defective power .... I have a whirlpool oven range and it's less than a year old. .... Humming sound stops when I open door to remove food, but when door is closed, ...
Whirlpool Microwave Ovens - Consumer Affairs
Feb 03, 2016 | Whirlpool Accuwave Microwave Oven
Dryer starts and runs fine but makes a loud buzzing noise from the motor that sounds a lot like the end of cycle signal
FIXED Dryer won't start. Makes electrical buzzing noise - model ...
www.applianceblog.com/.../7655-Dryer-won-t-start-Makes-electrical-buz...
Feb 12, 2007 - 10 posts - ‎1 author
It makes electrical buzzing noise when you press the start button. ... One would think that if it's the fuse that it wouldn't buzz at all but ... unplugged, re-assembled back, hooked back up to hose, turned on and running hot .... The belt was fine. ... Kenmore gas dryer 70 series is making very loud buzzing noise.
Troubleshooting Your Dryer Noises ' PartSelect.com ...
? 4:32
https://www.youtube.com/watch?v=Tk1YezyYMDY
Aug 26, 2011 - Uploaded by PartSelect
In this video you'll learn why your dryer may be making a variety of ... that is not only making a grinding noise but it also makes a loud banging noise. ... it's been drying about 15-20 min. it startsa loud humming sound. ... The dryer is working just fine, but I am concerned about the noise as it sounds electrical.
DRYER BUZZING NOISE - Dryer For Sale
Dec 18, 2015 | Amana DLE330RAW Electric Dryer
BUZZING NOISE FROM MY HEAT PUMP
Take a look at this YouTube page that explains with good videos what are some of the common problems with heat pump noise. The one that seems dominant is the defrost cycle a heat pump goes thru when it melts ice off the evaporative coils. In defrost cycle, The compressor runs but the cooling fan does not, so you will hear a loud buzzing sound and the unit sounds like it is stalled...because only the compressor is running to generate heat to melt coil ice.
https://www.youtube.com/results?search_query=American+Standard+5000+Heat+Pump+makes+a+buzzing+noise
Defrost cycle noise video:
https://www.youtube.com/watch?v=wudLk0WoIVo
Mar 06, 2015 | American Standard 5000 Heat Pump Unit
I'm doing the first step, sending a half liter through the machine before making coffee for the first time. The machine makes a very loud buzzing noise. When I put my hands on the upper corners of the...
The loud buzzing is the water pump, sometimes they are loud on the beginning, And the reason is there is no water in the pump. It should get better.
These small espresso machines have a vibration pump (this is the official name), And the name says it all.
Jan 15, 2011 | Rancilio Silvia Espresso Machine
Samsung DLP4663W. Loud buzzing noise from inside
The loud buzzing is usually due to the Color wheel being broken ir the bearings being bad.You can get replacement wheel at the following link.
http://servicemanuals.vstore.ca/
Sep 12, 2009 | Televison & Video
Loud buzzing noise
Mine is loud also when playing games. When playing DVD's it is not. I think it is a factory defect on some of the systems. I would not attempt to pull apart the DVD drive and try and fix it. It is working and on an XBOX 360 you should feel lucky that it is.
Aug 18, 2009 | Microsoft Xbox 360 Console
Alot of loud feedback through speakers, a loud buzzing noise
What sources make it happen or which do not? All buzzing = something in the amplifier end. is it from all speakers or just one?
One external source= RCA cables not grounded. Reconnect them tightly with a twisting motion to wipe off oxidation.
Apr 10, 2009 | Onkyo TX-SR606 Receiver
Loud buzzing noise
sounds like the color wheel needs to be replaced very easy repair on that model Samsung.
Jul 05, 2008 | Samsung HLR5067WX 50" Rear Projection HDTV
ADVANTAGE Waterway SVL56 Pool Pump SVL56E115 Impeller 15 Hp 3103660 Logo
457 people viewed this question
Top ADVANTAGE Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you an ADVANTAGE Pool and Spa Expert? Answer questions, earn points and help others
